VRT front load washer stays locked. Door is open now. washer makes a clicking sound engaging the lock and then releasing it however it does not release. What needs to be replaced?
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: HE 3t Front Load Washer
Yes, there is a manual release for the door. Follow this link for step-by step instructions:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Let me know if you need further assistance. I hope this is helpful to you.
Posted on May 28, 2008
Samsung front load washer door will not lock
Hi
Are there any error codes on the display
Regards
Phillip
Dec 25, 2014 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Samsung VRT with a DS or D5 code? Door closes but won't lock
bad door lock switch mechinism or the control board is bad at the emergency door lock circuit? where the wires from the door swtich attache, check ur schematic and will need a multimeter
Dec 18, 2014 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
My Samsung VRT washer was working fine. The cycle appears to be finished but the door remains locked. I get no response from any of the buttons. You would think that the washer wasn't getting any...
I don't know if I have the same model SAMSUNG front loader, but I have a similar problem. The door has decided to stay locked at the end of the cycle. I can turn it off and on and even send it through another cycle, but at the end of the washing, it drains, goes to END but does not go the extra step of unlocking, like it usually would about 1min after ending the cycle.
My clothese have been through about 6 different cycles, hoping it will magically clikc open at the end. I assume they are very clean, but getting dizzy.
Any help out there?
Aug 12, 2011 | Samsung WF337AA Front Load Washer
Door is open, lock is engaged.
Solved - installed new door locking assembly.
Sep 18, 2009 | GE Energy Star WCVH6260F Front Load Washer
My washer is making a buzzing sound and does not start making sound from where latch is will not release the door its staying locked . the code its showing is FL and DO.
if you open the dispenser door on top of the washer, and feel around the front you should find a little green ripcord. pull on the cord until the door releases. most likely the wax motor in your door latch is fried.
Jul 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Cycle finished but door won't unlock, please help
normally, front loading machines have this bypass cables in case this things happens, if there is a small opening at the front to acces the drain filter, open it up then look for a small plastic pc with a ring at the end. this is the pull release cable of the door lock. pull it downwards and the door will be released.
if you do not have the small opening to access the drain filter, you can tilt the machine to its back, ( be carefull, its very heavy) then reach for the plastic ring underneath to pull to release the door lock.
tnx 4 using fixya..
drcool
Aug 30, 2008 | Hotpoint WMA40 Front Load Washer
May 28, 2008 | Washing Machines
Door clicks and wont open and washer runs but wont do anything
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure You should remove machine's top cover and then you will have an access to the door lock unit. Be aware you should discconect machine's power cable first !! Good luck!
Jun 15, 2007 | GE WBVH6240F Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
