I have a Sharpe DV-RW360 and when I tape anything the vcr comes out when it has finished tapeing why as it still has more to tape
  • Televison & ... Master
  • 5,318 Answers
This might be a mode switch problem. The mode switch tells the electronics which position the mechanism is in. Be it play or record etc. However the switch contacts can become dirty or worn, thus confusing the electronics. For example it might say that the tape has come to and end, but the electronics thinks it's in record. So it rejects the tape! The only cure is replacement, though some Servisol Video 40 sprayed on the contacts of the switch will cure dirt on it.
This is what the mode switch might look like, though the do vary.
I have a Sharpe DV-RW360 and when I tape anything  - 26383333-enrvrlnzs3c2qc3wpbgoxald-2-1.jpg
Posted on Dec 05, 2016
I put a vhs tape in an the vcr turns off by it self a green light keeps flashing by where it says cst in. I have a Hitachi DVD/VCR COMBO DV-PF2U. I also can not get the tape out
Unplug the power supply for thirty seconds and plug back in, this will reset the processor and might eject the tape. If this fails the next step is remove the top of the combo unit this will give access to the vcr tape, if the tape is spewed in the machine and wrapped around the video head and other mechanical parts use scissors to cut the tape and carefully removing the particles, press power to eject the tape for normal operation. However! if the vcr tape is okay, there may be a loading problem, broken drive belt, bad idler assembly to name a few, this is where a technician will be needed but may not justify cost.
Jan 23, 2011 | Hitachi DV-PF2U DVD Player/VCR
Mini DV Tapes Won't Play
Please give the model and the make
Apr 16, 2008 | Sony DSR-11 DV / Mini DV VCR
Panasonic AG-DV2000 Mini DV VCR will not play large DV tapes
the problem of your player is the mechanism to dv tape slut(not mini dv) need to calibrate or to tune up...only can fix this is a qualified technician....
Aug 14, 2007 | Panasonic AG-DV2000 Mini DV VCR
My camcorder is spoilt and I am left with many mini DV tapes which I cannot download to the PC without the camcorder. Is there any solution for this?
since it is in digital format a standered VCR wont read them the hi-8 tapes have a bigger VCR tape you can put the hi-8 tape in and insert that into a VCR but the hi-8 is an analog tape is digital "DV = Digital Video" so a standard VCR wont read them the only way is to borrow a friends Mini-DV camera and copy all your tapes over. they do make a Mini-DV player but even the cheap ones cost more than a new camcorder would! Sorry to hear about your camcorder I hope this helps
Aug 12, 2010 | Panasonic PV-GS400 Mini DV Digital...
DSR 11 won't record DV tape to its end
You need to use longer tapes. The DER-11 is a DVCAM deck which when recording, uses a faster tape speed then mini DV. Think of your older VCR's. They had SP, two hours, and EP or SLP, which would be six hours. The SP speed would give a better picture. DVCAM is more like an SP recording except digital and a lot better. More information is laid down on the tape.
You'll have to jump up to the full size DVCAM tapes in order to record the full hour.
Apr 10, 2009 | Sony DSR-11 DV / Mini DV VCR
Will not seat DV
most likely problem is a defective cassette housing.
Jan 11, 2009 | Panasonic AG-DV1000 Mini DV VCR
JVC BR-DV3000 Mini DV-DVCAM issue
If the problem only shows with Mini DV tapes, it can be a tape guide issue or a mchanism loading problem where the tape is not being properly "seated" into the tape mechanism. You will need to use an oscilloscope to look at the RF waveform coming off the tape to try and figure out where your problem is.
Aug 22, 2008 | JVC BR-DV3000U DV/Mini DV VCR
DSR 11 playback problem
Pete, we are having the same problem with 2 dsr-11s.
The fix for us was the "auto repeat" switch on the back of the unit. It was "on" please turn it off.
The other idea was that the tape tension is very sensitive in the units, try exercising the tape (though exorcise might be good too) by fast-forwarding then rewind the tape start to finish. Tape that were tightly wound at the factory can cause this proble as well. Good Luck. Greg VA
Apr 29, 2008 | Sony DSR-11 DV / Mini DV VCR
First power off the unit, then remove the DV's tape housing , power up the unit, and allowed the mechanism to go back to the unload mode, make sure that the tape posts are at unload mode. then unplug the vcr back again, put back the tape's housing in the load position (tape in) power the vcr back on and push eject button to reset tape mechanism.
Jan 16, 2008 | JVC HR-DVS3 Mini DV/S-VHS VCR
How can I play back a tape produced on the GRHD1U?
Tapes may be played back by the camera itself. If the tape was shot in the 720P (HD) or 480P (SD) modes, it cannot be played back on a standard DV VCR or camera. Tapes shot in the 480i (DV) mode are completely compatible and can be played back on any DV VCR/camera. In addition, tapes can be dubbed to a JVC HD DVHS VCR via the firewire connector.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Televison & Video Logo
705 people viewed this question
Top Televison & Video Experts
