Hi, my cold-room has a flashing code " EE " on the control panel.I wonder what this means ?
onthejob5130
  • 640 Answers
SOURCE: control panel flashing F02
the water in your drain pump is still forzen...its taking to long to drain...ckeck drain hoses too...onthejob
Posted on Jan 09, 2009
SOURCE: Panel is flashing a 20 code and water is ice cold.
I was just told by Noritz America that flashing 20 is hard water issues. Any confirmation on just what this error code means?
Posted on Apr 05, 2010
hvac1960
  • 2133 Answers
SOURCE: we have ducted air which
When EE:EE is displayed on remotecontrol , press "Energy Save" &"Zone Control" buttons simultaneouslyfor longer than 3 secs. The error code will then be displayed on the LCD.Then write again. Thanks.
Posted on Jan 31, 2011
ginko
  • 19396 Answers
SOURCE: Panasonic CWXC203EU the
Hi.
EE means energy efficiency. hen EE is displayed there can be a defective thermistor or insufficient ventilation.
The following works on some A/C system: "When EE is displayed, press "energy save" and "zone control" simultaneously for about 5 secs"
Try also testing the system in auto mode, check ventilation and if possible test thermistor by reading impedance with a multimeter.
Posted on Aug 11, 2011
http://shop.panasonic.com/shop/model/CW-XC203EU?support
I saw no EE mentioned in the legend or otherwise, perhaps the model and serial # you will get an answer from the manufacturer.
Posted on Jun 07, 2014
EE error code on reliOn blood pressure monitor?
Corrupt memory causes this.
Just guessing on your make and model type!
1 - Unplug the washer from power for 10 minutes to attempt to CLEAR THE CORRUPTED MEMORY on the main control board.
NOTE: You can try unplugging the washer multiple times to attempt to clear the corrupt memory. Unplugging the LG washer with the EE error code may clear the error code and no other action is required. The washer memory will be cleared or reset and the EE error code is considered fixed or repaired.
2 - If the code does not clear on the washer after unplugging it multiple times, this means the main electronic control board is faulty and needs to be removed and replaced.
3 - To be sure the main control board is the problem, run a TEST MODE if you want to continue the troubleshooting process or just replace the main control board and that will fix the EE error issue.
NOTE: How to run a TEST MODE on an LG front load washer is explained below...
4 - If you have unplugged the washer for 10 minutes and have done this multiple times and the EE code DID NOT CLEAR, you can run the TEST MODE and the EE error may come up with the FIRST PRESS OF START/PAUSE BUTTON DISPLAYS EE ERROR CODE. If this is the case,then you have a bad or faulty Main Electronic Control Board and you need to replace it.
Dec 16, 2017 | Washing Machines
Temp display is flashing "ee" but seems to be cold inside.
EE mean that the cable between the mainboard and the display have a problem. I think it doesn't affect the coldness of the unit.
There are an explanation manual behind the back bottom panel.
In my case soon after having reset this error, the cable melted and took in fire.
How to check:
There is a black panel under the two drawer with 2 screws (left/right). The board is behind, the cable which melted in my case was a grey one connected to a black one.
Aug 28, 2013 | Haier Dd400rs Refrigerator
Flashing EE:EE on airconditioner wall control
your system might need reseting look for a reset switch on your thermostat or your inside unit usually means dirty filter
Jan 04, 2013 | Heating & Cooling
My microwave is showing EE on the control panel and then stopping what could cause this
Hi.
If the microwave was built by LG, then error EE means "EEprom Failure".
The eeprom is a memory chip built into the oven electronic control board. The error usually means that the electronic board must be replaced. In some case the alluminium insulation foil that protects the board must also be replaced. A radiation leakage test must be done after carrying the repair. The repair must be performed by a technician.
Regards.
Ginko
Dec 15, 2011 | Sharp Microwave Ovens
When I plug it in the screen shows EEE, and beeps continually. It is around 65 degrees in the area. Nothing clears it or stops the beeping. It worked great yesterday.
The error code E:EE means the breadmaker thinks the temperature is too cool i.e below 59 degrees F or 15 degrees Celsius.
As you say the temperature is actually 65 degrees - then this means that the temperature sensor on the Bread maker has failed and will need to be replaced.
The EEE code and beeping will continue until the failed sensor is replaced and as this is a component failure it cannot be reset unfortunately.
Thanks for using FixYa.
Sep 11, 2011 | Regal Ware K6725 Kitchen Pro Bread Maker
Panasonic CWXC203EU the unit is flashing error code EE and only when you unplug it shuts off the control do not work blows s a littlle cold air but after a shor time it shuts off
Hi.
If when EE is displayed the unit also becomes non-responsive and does not turn off, then the problem may also be a defective controller board. Other parts, included the ones mentioned before, must be tested before replacing the control module.
Regards.
Ginko
Aug 11, 2011 | Heating & Cooling
We have ducted air which cuts out and shows on the control panel where the clock is says EE.EE
Jan 31, 2011 | Fujitsu Heating & Cooling
Repair of room air conditioner /window unit
You need to check the main breakers in the breaker panel......
Sep 01, 2008 | Heating & Cooling
Thank you. there are some other signs i don't know about.
The black triangle means AUTO, means the fan speed adjust by itself from high-mid-low speed depending in room temperature but the unit is cooling for this function the same COOL mode. Plasma is in the remote control but it never mention in the manual.
If the unit dont cool check your temperature setting and mode setting it should be in cool mode and temperature setting should be 18C. But if still don't cool check some error code like blinking light at the indoor panel check how many blink appears to get the correct error code.. If the light is blinking 3 times it means that the room air or coil sensor is defective.
abc4048.jpg.
Apr 28, 2008 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
