Question about Plumbing
Mywaternotcuttingoffsometime when i open my pipe used the water close the pipe the pump still runs i have to open a pipe and close it off and then the pump will cut off
    Problem Solver:
  • 14 Answers
The pump needs to bring the pressure back up to a preset amount that your pressure switch is set at. It may take some time depending on how low the pressure went to when the water was running.
Posted on Dec 03, 2016
    Top Expert:
  • 51,186 Answers
Perhaps you need a new pressure switch .
How do I prime my flotec 4022 pump
A number of Flotec pump manuals are available here: http://www.flotecpump.com/ResidentialResourcePage_resourcepage_ownersmanuals.aspx . The site lists a FP4022-10 pump with the direct link to the manual here: http://www.flotecpump.com/resources/images/514.pdf .
For this type of pump, there should be a priming plug or priming tee. Remove the plug (or tee) and pour water into the pump. Keep adding water until the pump and all of the piping to the well is full of water. If a priming plug or tee was also added on the suction side of the pump, open that section and fill all of the piping on the suction side with water. Replace the plugs/tees then open a faucet in the house. Start the pump. After 2-3 minutes, turn off the pump if no water has come through the unit. Add more water through the priming plug or tee (or multiple plugs and tees). Then repeat closing the priming ports and start the pump after opening a faucet. Once the pump is actually pumping water, turn off the open faucet. Wait for the pump to shut off once it reaches full pressure. Open one or two faucets to check that the pump is properly sensing the pressure changes and maintaining system water pressure.
If the unit didn't pull water from the well, check the piping for air leaks. See the full trouble-shooting guide in the manual. Page 9 has the priming information and page 10 has the trouble-shooting guide.
I hope this helps.
Aug 27, 2016 | Flotec Plumbing
Tip
Jet Well Pump Well Jet Water Pump
One of the most frustrating things in plumbing can be the priming of a jet well pump. Well jet water pumps are sometimes difficult to get working properly because it is very difficult to get all of the air out of the system and the pump. Well domestic water systems are great for those that need them but you need to know how to approach the air removal part.
Here are some things that will help you prime both deep well jet pumps and shallow well jet pumps.
  1. Always install a tee and a valve at a high point directly above the outlet of the pump. This will give you a place to pour water in and allow the air to get out easily.
  2. Always install a “throttling” valve on the “out” side of the pump. This will let you keep back pressure on the pump. This is especially needed for deep well applications.
  3. Install a switch close to the pump to make starting and stopping the pump easy.
  4. Make sure that the “suction” pipe coming to the pump runs continuously uphill and is not trapped anywhere.
  5. Make sure that the suction pipe is at least as large as the intake fitting on the pump.
  6. Make sure that all fittings on the suction pipe are air tight
To prime the pump begin by filling the pump and suction pipe slowly with water, allowing the air to escape as you fill. This may take quite a bit of water depending on the size and length of the pipe.
When you can get no more water to go in the pipe, then close the valve on the fill and start the pump with the “out valve” closed or mostly closed. If the pump starts to go on and off rapidly, open the out valve just a bit more, till the pumps runs continuously.
If the pump starts to pump and then stops because of an air pocket, then you may need to restart the whole procedure and add more water. Keep doing this till all of the air is worked out of the system. For some systems this can be a long and laborious procedure.
Keep working the procedure and eventually you will have your system pumping.
http://www.fixya.com/support/r3691134-pressure_switch_adjustment_water
http://www.fixya.com/support/r3690937-pump_problems_pressure_switch
http://www.fixya.com/support/r3690698-pump_problems_water_tank
http://www.fixya.com/support/r3689163-water_problems_pump_problems
on Dec 23, 2009 | Plumbing
Super pump 11 keeps blowing the threaded adaptor off the discharge. I replaced the 11/2 inch pvc adapter twice. Both times the adaptor blew off. Any ideas.
Something is causing the pump to "dead head" which means it is trying to pump water through a closed pipe. Check any valves, the filter, heater etc.. downstream from the pump. Your water flow is being severely restricted. Hope that helps.
May 11, 2013 | Hayward Pool & Spa
GroundFOS water pump won't stop running after replacing PVC pipes
you may have to blead air from the water lines. air pokets will not let your pump regulaet. as your pump feeds water into the filter and all your house hold pluming it must reach a set presher. if ther is air trapt in the sistem it can not build enouph back presher to force the pumps PSI regulaeter switch to ingaidge. air is lighter then water ther for thes to difrent forces pushing against one another couses a flucksuaition and can not regulaet. blead all lines from the pump to all outlets"fosets,spikets and filltering sistem. let pump run while going to all outlets one at a time opening and closeing "cold side first" them to releave the air from the lines. donot forget eny outside fosets this should solve the problem. thank you for leting me help you today .
Feb 17, 2013 | Grundfos MQ3-45 1 HP Pressure Booster...
No heat running hot i changed thermostate
You have a blocked heater pipe or pipe running to heater, some vehicles have a electric valve on the inlet pipe of heater that open & close allowing water through, they sometimes become stuck & need replacing. Also the system may have air in the system, you will need to bleed it.
But If you have water bubbling up in the header tank (expansion bottle) if you see when engine warms up water rising in it & also dropping in it, then your water pump will need replacing, because it is not pumping the water around the system.
Jan 22, 2013 | 2000 Dodge Durango
Ventilate!....shows in window and machine will not ventilate when knob is opened. it has regularly been de-scaled but we do live in a hard-water area.
Generally you can clear the ventilate error by pressing the button for Hot Water and then opening the steam knob. You should hear the pump run and water should start to flow from the steam wand. If it doesn't, try removing the frother nozzle so just the chrome pipe is showing.
To remove the frother nozzle you slide the outer sleeve off, and then grip the nozzle with one hand while twisting the cap to loosen it. Then it should slide off the metal steam pipe. Or you can check that the tip of the nozzle isn't clogged.
If you have the frother removed and the steam pipe is definitely open and not clogged and you still hear the pump running but no water is coming out, the next step is to prime the pump.
If you still have the squeeze bulb pump that came with the machine, you can use that - or if you don't have it, a turkey baster will work. You want to take the water tank off and set it aside, then pump water into the valve in the center where the tank had been sitting. You choose "Hot Water" and open the steam valve so the pump starts and then pump water into that valve with the Turkey Baster. You should hear the pump catch and start to move the water - when this happens immediately close the steam valve so the pump stops - then replace the water tank (filled with water please) and open the steam valve again and let water run out of the steam wand for several seconds.
That should clear the ventilate message.
Oct 21, 2010 | Gaggia Titanium Espresso Machine
Karcher 320H i have the same pressure coming out as i put in from the tap, the motor is running ok
You have an air lock in the pump and or piping.
  • Open all drain cocks and remove the spray hose
  • Connect the inlet water hose and turn it on slow
  • allow water to run from all open ports for 2 minutes or so
  • leave the water running - close drains start motor
  • Shut down reconnect spray hose restart
  • You should now be smiling
Mar 08, 2010 | Plumbing
No pressure
Well, you can dismantle the pump head and check if the
impeller is damage. If damage, replace the impeller. Then reassemble the pump and reinstall to its position. Set the discharge gate valve at full close position. Then, fill the priming pipe full with water. Then, switch the power on, and slowly open the discharge gate valve to the desired pressure. Send in your e-mail for further assistance.
Oct 24, 2009 | Plumbing
How do i prime an onga pump from repressuring to primiing
Open the priming port at the discharge pipe. Close the discharge valve and fill the priming port with water until it is full. Power up and switch on the pump. While running, slowly open the discharge valve until the water
pressure gage at the pump is 20 psi. That will be the running pressure of the pump, and the maximum opening of the discharge valve.
Sep 27, 2009 | Plumbing
How to set up my onga pump and filter its about 8 years old but looks like the currant model.just got it and they didnt have instructions bugger.
We begin at the suction line. I'll assume that you will be using this as a
pool pump since you have a filter. At the suction line, install a horizontal
or a vertical check valve along the suction pipe. Then the suction pipe
is connected to the bottom pipe adapter of the filter. The top pipe adapter of the filter shall be connected to the pump suction adapter. At the pump discharge adapter, install a GI Pipe Tee. At the bottom of the GI pipe tee, put a GI nipple going to the pump discharge adapter. Opposite it shall be the pipe plug to serve as the priming port. At the GI pipe cross, install a GI nipple about 6-inch long with a service **** to balance water flow. At the end of the service **** install another 6-inch GI nipple to attach a gate valve to control water flow. After the gate valve
is the discharge pipelines going back to the pool.
Note: Pump must be installed within 3 to 5 meters near the water source. You may install more than 5 meters but suction could be difficult for the pump.
Priming the pump:
Open the plug at the tee that serves as the priming port, Fill this up with
water to full level with the service **** at full close position. Once filled
up, replace and close the priming port. Put the power on, and start the
pump running, then slowly open the service **** or flow control valve
to appropriate level.
Just send your e-mail for further assistance. Thanks.
Aug 19, 2009 | Plumbing
Plumbing Logo
151 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
