Question about Home
31day clock.I need to know where the chains with the weights go?
I received this Daniel Dakota 31day clock from my father and it came in some prices. The pendulum was there and two chains with what looked like weight attached to them. I need to know how to attach the chains.
SOURCE: weight watcher scale not calibrating weight correctly
Press the scale once with your foot. All screen options should display to initialize and then go to 0.0. Now step on the scale. It should read out your correct weight. If not, first remove and replace the battery for reset. If still not, replace the battery. If still not it's ready for return or replacement. Hope it works! Dave - CA
Posted on Aug 25, 2008
SOURCE: TV weight
Weight - in pounds - what is the weight?
Posted on Oct 04, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Duet GHW9400PWO: Replacement of the rear counter weight
This is a simple repair. All that should be required is to remove the back panel to access the counterweight. I've performed this repair on several occasions. Loosen the bolts that sandwich the weight between the mounting plates and the whole weight should slide out of its mounted position on the back of the tub. Insert the new weight by sliding it in place and then re-installing the mounting plates and bolts. Tighten until snug. Do NOT overtighten as you may crack the weight. I hope this helps you.
Posted on Nov 05, 2008
  • 76 Answers
SOURCE: 2001 dodge caravan sport 3.3 need to know what weight oil it take
The correct oil weight is 5W20, but 5W30 can be used also. Be consistant when using oil, try to use the same brand and always use the same viscosity. This vehicle requires 4.5 liters of engine oil.
Posted on Dec 06, 2008
tobibus2000
  • 506 Answers
SOURCE: two 25.0-N weights are suspended
a) for the rope use F=T1=T2=mg=25N,
b) for the chain, use F=T=(T1+T2)=mg=(25+25)N= 50.0N
Posted on Jul 16, 2011
Daniel Dakota Westminister Chime clock not keeping time. The pendulum moves but the hands do not. Any idea what is wrong? Thanks! Donna Hartman
Hello, Donna -
I found and looked through the owner's manual for the Daniel Dakota Westminster Chime clock:
https://secure.img1-fg.wfcdn.com/docresources/23391/13/139903.pdf
If you have not already done so, you may wish to insert fresh AA alkaline batteries in the clock. (Page 4, Image 9 of the owner's manual in PDF format) Follow those directions.
Then, look on Page 5 [Image 7, PDF document] regarding setting the time.
Step #8 states:
Never turn clock hands counter clockwise as it will interrupt the chime sequence and damage the clock.
Did you or do you know if someone else reset the time on the clock by moving the clock hands counter clockwise? If so, that is the cause of your problem.
A local clock repair shop may be able to fix your clock, or tell you if it is worth repairing.
Jan 05, 2018 | Chime Home
I have a Dakota Daniels grandfather clock. The chimes work, the pendulum works, but the clock hands don't move.
Change the batteries. The weight makes the pendulum and chimes work, but the clock in this thing is battery operated :>)
Accurate hourly Westminster chime movement tolls the hour - Automatic night shut off
  • Cathedral pediment, blue moon metal dial with raised roman numerals
  • Pendulum, weights and chains are made out of metal - Real tempered glass
  • Sturdy construction - Made of MDF & solid wood - Batteries (3-AA & 2-C) not included
  • Dakota Daniels grandfather clock Google Search
    Dec 12, 2016 | Dakota Watches
    My clock will only run with added weight on the clock chain. I added the cuckoo bird weight to the clock weight chain and it keeps good time. If I remove the added weight it will stop.
    I think your clock needs to be lubricated. A special light weight oil in a syringe will do the job. Just a little bit will Do.
    Jun 23, 2016 | Watches
    I have a daniel dakota grandfather clock and there is a wire that is not connected to anything,
    An electrical wire? Does everything work that you expect to work? If so, wrap that wire with electrical tape so it can't contact anything... and forget that it's in there.
    Aug 01, 2014 | Jenlea Daniel Dakota Floor Standing...
    Clock manuals
    Firstly do you know what each of the weights are for?
    1. The heaviest weight will chime the melody.
    2. The middle weight will keep the clock ticking.
    3. The 3rd weight will strike the hours.
    The chains run on sprockets and these sprockets move one way only. If you pull the chain the side that winds up will be the side where the weight will hang. If you need more information you are welcome to email me at amazingforklifts@gmail.com. I do fix these clocks for a living.
    Dec 03, 2013 | Home
    My grand fathers clock keeps time but will not chime ?
    Have you checked the travel path of the other two chains ? If not, be sure that they aren't hung up on something inside the clock. Also, do you have a switch that allows you to turn the chimes on/off? Lastly: are the three weights each on their proper chain? They each have different weights and are sometimes numbered on the bottoms. 12_10_2013_7_43_52_am.png
    Oct 30, 2013 | Home
    Purchased a grandfather clock at a flea market and need to know how to wind it. Has chains not a key.
    Pull the chains ... there is a weight on one end and the other end is free. Pull the free end down which will pull the weight up. It is the falling weight that operates the clock. There are probably several weights, each weight has a different purpose. The falling weight actually operates the pendulum. You will probably have to wind the clock (pull the chain) on a daily or weekly basis depending on the movement of the clock (i.e. 1 day clock or a 8 day clock) If the weights are missing, you will have to replace them. Contact a clock repair shop in your area.
    If you had a Coo Koo clock, one weight would run the clock and a second weight would run the bird. A third weight would run a music box or other clock feature.
    I hope this answers your question. Congratulations on your purchase.
    Thanks for visiting today.
    Jan 30, 2011 | Kitchen Ranges
    Home Logo
    52 people viewed this question
    Top Home Experts
    john h
    Tom Chichester
    Are you a Home Expert? Answer questions, earn points and help others
