Question about Bowflex Exercise & Fitness
Bowflex treadclimber treads unbalanced how to fix
  • 679 Answers
SOURCE: Bowflex Treadclimber tc 1000 turns off
Problem could be low colant, water pump, fan not kicking on (bad sen or bad fan motor) radiator dirty,
so the Treadclimber not working properly.
I hope this helps u
Thanks for using FixYa.
Posted on Jan 30, 2009
SOURCE: We just purchased a Bowflex Treadclimber 1000.
putting the drive sensor wire back in the correct place workedgetattachment.aspx&hm__qs=file%3d3d2f2ee0-2668-46ea-b32c-db049d56cb37.jpg%26ct%3daw1hz2uvanblzw_3d_3d%26name%3daw1hz2uwmdiuanbn%26inline%3d1%26rfc%3d0%26empty%3dfalse%26imgsrc%3dcid%253aimage002.jpg%254001c99c08.13bd6320&oneredir=1&ip=
Posted on Mar 03, 2009
SOURCE: the machine will quit wright after you start and
Had my TC5000 for a year and this is the first time this happened. I use it everyday. Googled "Bowflex Teadclimber error codes" and found this link which is a pdf manual.
I'm going to try this fix now, hope it works for you and me
Here's what it says for ERR LS:
Belts stop turning and “err LS” or “err OS” is displayed Calibration Re-calibrate machine using Owner’s Manual calibration procedure. Speed sensor 1. Cycle power off and on. 2. Put the machine in calibration mode (see Calibration procedure in Owner’s Manual) but do not start the calibration routine. 3. Remove right rear plastic cover to view LED diagnostics on control board. Caution: Machine is on. Current is active!! 4. Locate LED D on the motor controller board. LED may be lit or unlit. 5. Manually advance the treadle with your foot, and check if LED D is blinking. 6. If LED D is not blinking, then the speed sensor is not supplying a signal. Check that the speed sensor wire is plugged into the motor controller board, to the connection labeled “P1”. Check connection of speed sensor to jumper wire. Check speed sensor adjustment (use business card to set gap between sensor and pulley). If LED D still does not flash replace sensor. I/O cables If LED D is flashing when the belts are turning but err LS or OS persists check connections and for signs of visible damage to any of the three I/O cables. If no damage, check continuity using a multi-meter. If a multi-meter is not available contact customer service for replacement cables and further assistance.
Posted on May 30, 2009
  • 6 Answers
SOURCE: calibration fail message on bowflex
Unplug your machine, restart it and try to calibrate it one more time. I had to do this with mine and it did take more than one try to get it to recalibrate again.
Posted on Jul 29, 2009
SOURCE: bowflex tc 1000 treadclimber
TC1000 from Bowflex, works okay for 15 mins then the speed surges ahead and stops dead with error E1
Posted on Jan 12, 2010
Tread climber starts up and shuts down in a few seconds. Starts clicking
Bowflex Treadclimber Shuts down - Questions - Fixya > Forum > Treadmills > Bowflex > Bowflex Treadclimber
Bowflex Treadclimber, shuts down related issues. ... After a few times of shutting down due to the heat. Ad ... It shuts down about 60 seconds after it starts.
Customer Reviews: Bowflex TC3000 Treadclimber, Inc.The second time I used it I slowed down the speed and worked on getting the ... After researching the TreadClimber for over a year (the cost was a big factor .... We were never able to make the treadles go up and down more that a few inches. ..... a great workout However it continually shut offs while working out and Bowflex ...
Comments for Bowflex TreadClimber Problems
Oct 30, 2013 - NOTE: My comment about Bowflex Treadclimbers is also one I left in another area. ... seems like no one sprung the extra few bucks to pay for someone to put the ... In my case , after the initial startup, the machine stops EVERY time at ...nearly spine snapping shutdown at exactly 32 minutes after starting. 5.
[PDF]Bowflex® TreadClimber® 1000, 3000 & 5000 - Nautilus
Jan 27, 2016 | Bowflex TreadClimber TC10
Why does my Bowflex TC5000 cut out?
If you're running the machine on a dedicated circuit then your unit is drawing too much current. This can be caused by friction and drag. Solution: Lube deck/belt. If problem persists, replace deck/belt. If you ignore this fix this will blow your controller. .
Apr 29, 2014 | Bowflex Tc5000 Climber Treadclimber...
How to use the lock lever to make the treadclimber just a treadmill
Just push down and over on the locking lever and it will keep the treads in one position.
Mar 15, 2014 | Bowflex Treadclimber
I have power, and the treads are not moving
The motor was damaged and needs to be replaced. Any and all moving parts under water can sustain damage to include rollers, guides, thrusters, metal gears, and other associated parts. Claim with the insurabce company if insured.
Feb 26, 2014 | Bowflex Treadclimber
Slippery treads
see the video and fix it. God bless you
Feb 08, 2013 | Bowflex TreadClimber TC10
Bowflex TC5000 won't start! Lights on circuit board show power.
see the video and proceed according and fix it. God bless you
Jan 08, 2013 | Bowflex Tc5000 Climber Treadclimber...
The display on my tc3500 bowflex tread climber stopped working
adjust the REED swithc see the diagram , clean it, and tight the connector very well.
2) Tight the ribbon cable inside, clean it, for keypads operations.
God bless you see the b. diagram attached.
Nov 25, 2012 | Bowflex Treadclimber
Treadclimber tc3000 treads/STEPS WILL NOT GO UP & DOWN EVEN
Sounds like the hydraulic cylinders are bad. Try replacing them and should fix the problem.
Apr 29, 2010 | Bowflex Treadclimber
Black dust coming out
I just got a BowFlex TreadClimber TC3000. I have been using it for about 1 week and I noticed black dust coming out of the back. It was near the treadles. I called BowFlex and they said that this is normal during the first few weeks of use. This is the coating coming off of the treads. They said I could vaccum it up. They also mentioned that they only time to really worry is if there is white dust. That is the actual treads wearing off. Hope that helps!
Mar 19, 2009 | Nautilus Exercise & Fitness
Bowflex treadclimber 5000
Hi ddmyatt.. They sell what is call dry lube at sports store's. for spraying under the tread's and on the wheels that the tread run's on.. Lift the tread and spray as far under it as you can on both side's. She'll be lot's quieter then before and lots easier on the motor too..
Nov 03, 2008 | Bowflex Treadclimber TC5300
Exercise & Fitness Logo
54 people viewed this question
Top Bowflex Exercise & Fitness Experts
Glenn Mayer
Glenn Mayer
Shehu Pro
Shehu Pro
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
