Question about Boss CHAOS CH450 Car Audio Amplifier
I turned my car on and when the amp turns on one speaker pushes out and the other pushes in and stay like that and dont produce any sound. i checked the wires and fuses and everything is correct but i cant figure it out. wat happened
  • 655 Answers
Hello mikhail_1994,
I'm assuming that the amp was installed and was working properly.
It sounds like the output is shorted. The CH450 may be operated as a 2-channel amp or both channels can be bridged for mono powering subs at an impedance of 4ohms or more.
I'd test the sub voice coils and then test each channel of the amp separately.
Hope this helps.
Posted on Jul 20, 2009
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
I dont have any sound on my p50xha10us
Just check this set connected to any external audio devices, such as an amplifier. Use TVs'audio out connections to the audio in connections of the amp, and see whether the amp produces sound. If yes, the fault will be either to the inside speaker of your set, or its audio output card. If there is no sound produced by the amp too, the digital processor section of the TV's main board is faulty. The main board has to be replaced.
Sep 27, 2012 | Fujitsu P50XHA10 50 in. Plasma Television
My jvc kd-g820 will not produce any sound and not accept cd
try to find the reset a little indent on the face or hole when you remove the face and push in for 2 to 3 secs with a pen or paper clip. Then try your cd again. Still dont work check to see if you have another cd jammed inside and your trying to put two cds at once.
Ok for your no sound problem. a bad speaker, short speaker (one 1 speaker shorts out all will not work cause the radio is in a protective mode), factory amp needs to be turned on, bose system or amplified system in car needs to be rewired to bypass factory amp), buy special car harness to make factory amp compatible with aftermarket radio, late ford models the back speakers are crisscrossed.
Next time please give car info and type of system you got in it so I could narrow down the possible problems a little bit easier.
Apr 08, 2010 | JVC KD-G820 CD Player
I have a kenwood kac-8452 4 channel amp that makes the speakers pulse after the volume gets turned up to 10. I also have a kenwood amp doing the same thing with my subs. any ideas?
Its not pulsing, its called clipping. The sound is being clipped due the amp being pushed past is power capacity and distorting the signal. This will damage your speakers very quickly. No amp should be turned more then 3/4 up. If its not loud enough you need to purchase a larger amp or be comfortable with the wattage it produces at 3/4 volume. You may also have speaker wires touching/crossed causing th issue.
Sep 10, 2009 | Kenwood KAC-8452 Car Audio Amplifier
Amp is on but no sound.....also amp stays on when car is turned off
sound is more like a speaker conection problem. than your amp. check your speaker connections first. to make sure they are plugged in all the way. and fit tight on the speaker. it they are . and it is still cutting out. you may need to trace the speaker wires. and see if they are getting pinched in the door jam. that is a usual culprit for speakers cutting out.
Aug 03, 2009 | Car Audio & Video
Won't stay on, turns off by itself
With a 1.5 Volt Dry Cell (AA Size), connect two pices of wire with the Cell. Momentarily touch the wires with speaker several times. It should produce click sound when wires are touched. If not then speakers are defective and need repair. Do not touch the wires for more than a second, touching the wires for a long time may damage the speakers.
Jul 06, 2009 | Kenwood KAC-X501F Car Audio Amplifier
RX-797 no sound output except when "Pure DIrect" button pushed
Here are some things to check:
Is the loudness control turned off or set to a very low level? If the PURE DIRECT button is turned on with the LOUDNESS control level at 0, you won't hear anything.
Have you removed the jumpers from the PRE Out/MAIN IN jacks? If so, the unit will only perform as a power amplifier.
Is the CD DIRECT AMP turned on?
If so, the unit will only make sound if the PURE DIRECT button is on.
Check the CD DIRECT AMP and the PURE DIRECT buttons are both turned off. This should produce sounds. If ti doesn't, check that the A and B buttons are on for their speakers. Both can be on.
Apr 25, 2009 | Yamaha RX-797 Receiver
Power problem amp
Sounds like its going into protect mode-try disconnecting the speakers from the amp entirely and turn the system on if it stays lit up- then ya know its the speakers (one of them at least) thats making your amp shut itself down. If thats the case look into replacing the speaker thats causing the problem.Also make sure that you have sufficient wiring to your amp - at least 8 gauge if you can. check all terminals /power/ground make sure everythings connected tight and not grounding out anywhere
Mar 29, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Sony amp 1000w
Check the wiring of the speakers (both inside the box and between the box and the amp). It sounds like one speaker is wired incorrectly at one connection point.
Sep 09, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp guard
Other sites I've read about this problem suggest that first you try checking the wiring to the speakers for a fault to ground OR you have speakers with too low impedance. If those check out ok, the unit needs to go back for service.
Apr 14, 2008 | Clarion DXZ645MP CD Player
Boss CHAOS CH450 Car Audio Amplifier Logo
124 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Jerry Umali
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
