Question about Electrical Supplies
I need a wiring diagram for my Ryobi RG 950 Generator CDI system
I don't have a spark on the plug I need a diagram to figure it out if it is the coil or CDI thanks daniel
    Top Expert:
  • 41,738 Answers
Request the diagram from Ryobi.
Posted on Dec 03, 2016
Why no spark?
Hi Daniel is there a side stand switch fault or possibly the pick up coil at the fly wheel??
May 26, 2015 | Motorcycles
No spark from plug
Could be a wiring problem, Bad CDI unit, Bad Coil, Bad HT lead or a bad spark plug.. first thing to do is to take the spark plug cap off and hold the wire near the engine and see if a spark arcs onto the engine. if it does then its your spark plug or spark plug cap. If that doesnt work get a test lamp and check the voltage to the wire going into the coil, if it flashs the light then the coil is bad. If that doesnt work then it could be a wiring issue, so i would try unplugging the kill switch first. if that gives no joy then its a wire harness or CDI/ Magneto issue. So my next step would be to go to a salvage yard or mechanics with the bike and ask them to test the CDI (by using one they know is good or checking the wires).. they will tell you what the problem is from there. Tell them what you have done so far so they don't waste time.
Sep 09, 2012 | Motorcycles
How to test CDI unit for KTM65 2009 to diagnose if faulty or not.
If you are able to use a digital volt meter and work your backwards from spark plug wire to coil to cdi to stator you can figure out where voltage stops.thats a fairly newer bike unless you really submerged that bike under water i dont think its the cdi box.it could be coil wire it could be coil.you want to check or change the cheaper parts before you go right to cdi because there not cheap.I have a yamaha banshee 350 and she was breaking up real bad.I thought because it was only happining on top end that the cdi was breaking down or stator was going bad.Found out with meter it was the coil wires and spark plug boots.These items have to have a certain amount of resistance or the do not conduct correctly.And spark plug wires and boots are not that exspensive.So thats why I say start from sparkplug boot and work your way back.Try that and Good Luck.
May 09, 2011 | 2009 KTM 65 SX
I have a Roketa MC-07-50t that won't start. The Spark plug is not getting a spark. We have replaced the C.D.I. Still no spark. Help.
4bbd330.jpegthis is a asic wiring diagrame for a pitbike and if you carefully follow this with yor new cdi mabey coil and spark plug you should deffo get a good spark and if that fails then you need a new stator plate or inner roator kit off ebay    ... hope this helps    email josh_radford2k10@hotmail.co.uk
Oct 06, 2010 | Cycling
No spark at plug. so iam guessing coil is shot. mac 110
Hi
You will have to remove the engine from the houseing to get to the coil.Not a easy job. It does not have points
Sam
Jan 07, 2010 | Poulan Pro Chain Saw 46cc 20"
No spark on 1998 Cagiva Canyon
did you check the primary coil? the ignition coil?if you think that these are all good,then you must replace the CDI.You cant test a CDI if this is good or not because it is a form of IC or integrated circuit,unless you have a manufacturer's diagram of it.You can check it by by detaching into its plug and get and replace an old CDI which you know is working,for example,get the CDI of the other motorcycle (if it has)the try to plug-in ,and if it fires,then thre you can surely know that the problem is on the CDI.
Nov 17, 2009 | 1998 Cagiva Canyon 500
Yz125 no spark
G'day i am a . YZ 125 j ...lets see now! You could perform these tests yourself.Check your plug CAP,if in doubt replace it with a new one. Take the below ohm figures and see if they match up. Pulse coil: white/blue and white/red= 310 ohms. low speed coil: Green/white and Black/red= 900 ohms. high speed coil: Green/blue and black= 55 ohms. hope this has helped in some way to helping you solve your problem.If it has please leave feed back.Ride hard , see ya,Tabbycat
Jul 22, 2009 | 2003 Yamaha YZ 125
No spark
Check the side stand kill switch if your bike has one. It kills the engine so that you don’t start out with the side stand down. If broken or out of adjustment, it would kill the spark. Check for a broken wire at the side stand switch and coupler. Try moving the kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it. Check the fuses. How good is the battery? Try a jump start from your car battery. Is the handlebar kill switch on? Check the operation of the ignition switch and all kill switches with a volt ohmmeter. Install new spark plug.
If that doesn't do it, check the wiring harness. Did a wire come unplugged? Are all wires clean and with solid connections? Any abraded or pinched wires? Is the bike in neutral and the neutral light is lit up? If no neutral light, check the neutral switch and neutral switch wire on center casing. If still no spark, get CDI system and coils checked at the dealers shop. You can screw up a CDI unit checking it yourself.
Jun 18, 2009 | Honda XR 200 Motorcycles
500cc jetski no spark on both plugs
Bad source coil in the stator, bad CDI, bad spark plug coil(may be coil/CDI combo), bad kill switch, or a loose wire connection.
May 10, 2009 | Jet Inflatable Boat Motorized Scooter
I have acquired a CDI 1998 to my Yamaha XJ600 Diversion 1993
hi mate. the cdi was changed in 1995 to accomadate a thottle sensor.pre 1995 the cdi was a square item. post 95 there tapered..
Nov 11, 2008 | 1993 Yamaha XJ 600 Diversion S
Electrical Supplies Logo
98 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
