Question about Cell Phones
What is chinese rhythmic boxing - Cell Phones
    Top Expert:
  • Cell Phones Master
  • 50,411 Answers
What does this have to do with FIXING ANYTHING
Posted on Dec 03, 2016
Make these letters info to words:ehmoscntirhty
hysteric month
mythic hornets
mythic thrones
rhythm notices
rhythm section
rhythmic notes
rhythmic stone
rhythmic tones
thorny chemist
Mar 13, 2014 | Computers & Internet
I have the chinese input software in my handphone.. bt yet i still couldn't type my msgs in chinese characteristics.. i cant even find "chinese" in my typing language option~ can anyone please...
Create a new massage, tab and hold on to the massage box area, once hold a new box will pop out, there will be an option for input option. From there you can change how to input your language.
Mar 14, 2011 | Sony Ericsson XPERIA X8 Cell Phone
#2 clyinder not firing in a 02 eldorado with 19000 miles on the car
There are several possibilities.
Based on the year (2002) and low miles (19,000) it probably has the original Plugs, Wires and Coil. Rubber insulation on Wires does dry rot over a period of time. Spark Plugs should be changed about every 3 to 4 years regardless of miles. Wires should be replaced every other Spark Plug change. Translated you should be on you 3rd set of Spark Plugs and 2nd set of wires.
When working in the engine compartment and with the electrical system remember: ther is 40,000 to 75,000 volts present. Bad Wires could mean an electrical shock!
You can cheaply purchase Ignition (Spark Plug/Wire/Coil) Test Kits at most auto parts stores or even at Harbor Freight.
1) Remove the #2 Wire connection to the #2 Coil position.
2) Insert the tester into the #2 Coil position. Clipping the other end onto the engine block or onto a good ground.
3) Start the Engine.
4) You will be looking for a good strong (blue) and rhythmic spark. If it is not strong (yellow or orange) nor rhythmic, the Coil is malfunctioning and should be replaced.
5) If it is a good rhythmic spark, Turn OFF the Engine.
6) Disconnect the Tester and reconnect the #2 Wire to the #2 Coil position.
7) Disconnect the #2 Wire from the #2 Spark Plug.
8) Connect the Tester into the end of the #2 Wire. Clipping the other end to the engine block or a good ground.
9) Start the Engine.
10) Again you are looking for a strong (blue) and rhythmic spark. If is not strong (yellow or orage) and rhythmic, the Wire is bad and should be replaced. Wires should always be changed as a Set is the standard rule.
11) If it is a good rhythmic spark, Turn OFF the Engine.
12) Remove the #2 Spark Plug out of the engine.
13) Check the Igntion end of the Plug for carbon, dirt, or being fouled. Check the Gap.
14) Insert the #2 Spark Plug back into the #2 Wire.
15) Using the Spark Plug Tester. Connect the Tester to the #2 and clip the other end to the engine block or a good ground.
16) Start the Engine.
17) Once again you should be checking for a strong (blue) and rhythmic spark. If it is not strong (yellow or orange) nor rhythmic, the Spark Plug could be malfunctioning.
18) Clean the #2 Spark Plug.
19) Regap the #2 Spark Plug.
20) Retest the Spark Plug.
21) If there is now a strong (blue) and rhythmic spark, then the #2 Spark Plug is now good.
22) If there is not a strong (yellow or orange) nor rhythmic spark the #2 Spark Plug is malfunctioning and needs to be replaced. Again the standard rule is to replace the Spark Plugs as a set.
The several other possibilities relate to sensors. However without additional error codes or the check engine light on, we will assume that the problem can be solved with the solution above.
Let me know if this helped, or if you have additional information or questions. Feel free to contact me at FixYa.com!
Feb 17, 2010 | 2002 Cadillac Eldorado
Rhythmic grinding noise front end - 98 chevy astro AWD
Could be low on oil, trans doesnt have fluid, wheel bearings are gone, or could be something stuck under the vehicle and either the tires or the drive axle is rubbing against it.
Feb 09, 2010 | 1998 Chevrolet Astro
According to the obd code i am getting a misfire in the number one cyln and it kind of sputters what is causing it
1. Bad or fouled Spark Plug at #1 Cylinder.
2. Bad or misfiring Wire going from the #1 on the Distributor/Electronic Ignition Coil to the #1 Cylinder.
3. Misfiring at the #1 on the Distributor/Electronic Iginition Coil.
a. Unplug the #1 Wire at the #1 on the Distributor/Electronic Ignition Coil.
b. Using an Auto electrical testing: Probe, wire and ground clip electrical, stick the Probe into the opening at the #1 Distributor/Electronic Ignition Coil. Use the grounding clip - clipped to a portion on the engine.
c. Start the Vehicle and check for rhythmic spark.
d. If there is NOT rhythmic spark, the Distributor/Electronic Ignition Coil needs to be replaced.
e. Turn off the engine.
f. If there is rhythmic spark: Reconnect the #1 Wire at #1 on the Distrubutor/Electronic Igntion Coil.
g. Disconnect the #1 Wire from the #1 Spark Plug.
h. Again using an Auto electrical testing: Probe, wire and ground clip. Insert the Probe into the end of the #1 Wire and clip the ground clip onto the engine.
i. Start the engine again.
j. Again Check for rhythmic spark.
k. If there is NOT rhythmic spark the #1 Wire needs to be replaced. (Replace all Wires as a Set).
l. If there is rhythmic spark then the #1 Wire is fine.
m. Turn off the engine,
n. Remove and Inspect the #1 Spark Plug. Clean if necessary and Regap.
o. Reinstall the Spark Plug and reconnect the #1 Wire.
p. Restart the engine.
q, If the code reappears:
r. Replace all the Spark Plugs.
Let me know if this helped or if you have additional information or questions. Feel free to contact me at FixYa.Com.
Feb 09, 2010 | 2000 Lincoln Town Car
My mp3 player is in chinese and i need to change it back to eng.
Give this a try:
1. Hit settings icon at the bottom right of screen- box will be ticked
2. Hit the sixth box on the screen- tick box
3. There are 3 options boxes hit the first one - it is for language settings
4. Then hit the third box it says English
Hope this helps you
- Neal
Apr 27, 2009 | Mach Speed TRIO Onyx MP3 Player
Rhythmic clicking sound when the monitor is on
I just recently posted about this and you might have the same issue with the TDA7268 Audio Amp chip used in the 150MP that I am and currently trying to resolve.
-Ben
Mar 25, 2008 | Samsung SyncMaster 150MP Monitor
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
