Question about Refrigerators
My tray cup is broken due to heat & water is leaking on the flour. I want a new tray cup.where to buy?
Mine is a double door fridge. Do I have option to buy on online.
    Top Expert:
  • Refrigerators Master
  • 46,307 Answers
Suggest you try the MANUFACTURER .
Posted on Dec 03, 2016
Why won't ice tray filling stop?
Michael, I suspect that the water solenoid valve needs replacement--that symptom usually causes either a slow leak and an overflowing ice cube tray or no water flow at all. To test the solenoid valve, slide your refrigerator out and view the back cover. There should be a double solenoid valve down near the bottom back of your refrigerator, one solenoid valve for the water serve spout on the front of the freezer door, and the other solenoid valve for the ice maker. I'd swap the clear plastic lines (to the door water spicket and the icemaker, put a plastic cup under the door water spicket and check in a few minutes for water leaking into your cup--if it does leak into the cup, you've found the problem! There are seval excellent videos on the web covering how to replace the valve, see: http://www.appliancepartspros.com/lg-water-inlet-valve-5221ja2006d-ap4445614.html
That solenoid is controlled by a cam driven switch built into the ice maker motor assembly which can occasionally go bad and need replacement or adjustment, but my experience points to a leaking dirt plugged-open water solenoid valve. Replacment solenoid valves are easy to replace at a cost ranging from $20 to $78 with free shipping to your doorstep--check ebay!
Jun 01, 2015 | LG LSC26905TT Side by Side Refrigerator
Need recipe to make pasta
Tips for Optimum Pasta
The dough should be evenly kneaded, and slightly moist to form a soft malleable dough. The dough should have the consistency which is not too dry or too moist.
The dough is too dry if it has a powdery, grainy consistency and breaks into small chunks. Add more liquid (water or vegetable juice) by the teaspoon until it has formed a smooth, malleable dough that is not sticking to the sides or the kneading spiral.
The dough is too moist if large lumps of dough remain stuck to the kneading spiral. Add flour by the teaspoon until it has formed a smooth, malleable dough that does not stick to the sides or the kneading spiral.
If you add a little bit of olive oil to the pasta dough, it will slide better through the outlet openings of the pasta attachments.
For the pasta dough, you can use both normal household flour as well as wholegrain flour, gluten free flour, or flour made from durum wheat semolina. Different types of flours will require a different amount of liquids. Reserve some liquid and add it slowly for best results. Document your process so you can repeat it in the future.
Vegetable juices made, for example, from spinach, carrots or tomatoes are ideal for adding color and nutrients to your pasta.
Sprinkle flour on your pasta directly as it emerges from the outlet opening and place it down separated on a smooth floured surface to dry. This will prevent the pasta from sticking together.
Cooking time for fresh pasta is much shorter than for dried pasta from the supermarket; 2-4 minutes is usually sufficient. Thinner pastas, however, may require an even shorter cooking time. We recommend you check the pasta at regular intervals until the pasta is "al dente".
Fresh pasta can be kept for 1-2 days in the fridge and frozen in the freezer for as long as 6 months. To stop the pasta from sticking, you should lay the pasta out to dry for 1-2 hours before you store it in the fridge or freeze it.
Pasta recipes
GARLIC PASTA
Add 2 cloves of garlic (crushed or pureed) to the liquid in a full load of pasta. Cook and serve with sauce and cheese.
TWO MINUTE CLAM SAUCE FOR LINGUINE
Pasta: Linguine or Spaghetti
3 Tbsp.
Olive oil
2 Tbsp.
Garlic - finely chopped
1 can
Clams with juice
3 Tbsp.
Oregano
1/2 cup
White wine (optional)
1/2 cup
Prepared pasta sauce (optional)
Fresh ground pepper (to taste)
Crushed red pepper
Saute garlic and clams in olive oil. Add oregano, pepper and crushed red pepper to taste. If desired, add white wine and/or prepared pasta sauce. Pour over pasta, garnish with minced parsley.
FETTUCCINI & CHICKEN
Pasta: Fettuccini (with 2 Tbsp. olive oil or butter)
4 large or 6 small pieces of boned chicken cut in chunks
2 Tbsp.
2 Tbsp.
Italian seasoning
2 Tbsp.
Parsley
Olive oil
Salt & pepper
Bake or saute chicken in olive oil with garlic and seasoning until done.
Place chicken on freshly cooked fettuccini and serve hot. For variety,
add sauteed mushrooms and/or bell pepper. Add Parmesan cheese.
HUNGARIAN PAPRIKA PASTA
To a regular full load of pasta add 2 tablespoons of paprika to the liquid
and stir well before adding to the flour as it mixes.
SPINACH FETTUCCINE IN CREAMY DILL SAUCE
Pasta: Fettuccine, Linguine or Rigatoni
Great with any pasta, but this is very tasty with spinach pasta! Make your liquid for the pasta with fresh spinach juice or mix spinach with a small amount of water in a blender and strain before adding to the egg and oil mixture.
1 Tbsp.
Butter
1 tsp.
1 cup
Heavy cream
1/4 cup
Parmesan cheese
2 Tbsp.
Fresh dill
1/2 cup
Tomatoes - diced
Salt & pepper to taste
Melt butter with garlic in pan. Add cream, salt, pepper, and Parmesan cheese. Stir until cheese is melted. Reduce heat, add fresh dill and diced tomatoes. Remove from heat and gently pour over pasta.
RUSSIAN BORSCHT P ASTA
Measure 2 cups of flour. To your liquid ingredients add oil plus egg. Use beet juice instead of water and 1 teaspoon ground sour salt. Serve as a side dish with sour cream.
PASTA WITH SUN DRIED TOMATOES & PINE NUTS
Pasta: Spaghetti, Fettuccini or Linguine
1/4 cup
Olive oil
1 clove
2 Tbsp.
Italian herbs
1/4 cup
Sun dried tomato - cut tomatoes in 1/8" slices
1/4 cup
Pine nuts
Saute garlic in olive oil, then add herbs. Remove from heat and stir in sun dried tomatoes. Toss lightly with cooked pasta. Top with pine nuts. Serve with Parmesan cheese.
BASIC PASTA WITH FRESH TOMATOES
Pasta: Any of your favorites
6 Tbsp.
Olive oil
2 Tbsp.
Garlic - minced
2 Tbsp.
Basil - fresh, minced
1 cup
Ripe tomatoes - diced
Parmesan cheese
Saute garlic. Add basil to hot skillet. Remove from heat and stir in fresh diced tomatoes. Pour lightly over fresh pasta. Serve with Parmesan cheese.
ARTICHOKE & BUTTER PASTA
Use 2 measuring cups of flour. Fill to "Oil+Egg+Liquid" line with: 1 egg, 2 tablespoons melted butter and fill to top of "Oil+Egg+Liquid" line with liquefied (pureed) artichoke hearts (cooked, or cooked and marinated) after straining artichoke juice through sieve. Serve with remaining artichoke hearts.
SOUTHWEST CHILI PASTA
Use 2 cups of bread or semolina flour. For your liquid, use: 1 egg, 2 teaspoons oil, 1 tablespoon chili powder, 1 teaspoon salt, 1 teaspoon onion powder and fill with tomato juice to top of "Oil+Egg+Liquid" line on your measuring cup.
LEMON PEPPER PASTA & SHRIMP
Pasta: Lemon Pepper Linguine, Spaghetti or Fettuccine
1/4 cup
Olive oil
1 lb.
Fresh shrimp - peeled, deveined and butterflied
2 Tbsp.
Garlic - minced
2 Tbsp.
Oregano
1 Tbsp.
Lemon pepper
1 tsp.
Minced parsley
1 cup
2 Tbsp.
Jan 07, 2015 | Cook's Essentials CooksEssentials Pasta...
Refrigerator leaking
very simple solution there is a drain cup usually in the fridge at the top by the lights or on the back wall make sure it isnt plugged . now the other thing you will need to do if that cup isnt plugged is pull the fridge out from the wall there will be a black or white tube running down your fridge to a tray or a dish on top of the compressor that is your drain it runs over the compressor so the heat can evapourate any water make sure its not plugged and water can run out of the tube . if you go inside the fridge and that drain cup is covered in ice then u have a defrost problem will need a technician to replace either the defrost timer or heating element or your thermastat good luck
Oct 02, 2013 | Whirlpool Refrigerators
Water is leaking into my fridge from defrost.
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system.
If in case the water is leaking on the floor then:--
There are several things to check for. The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchanger tubing can separate and also sweat and drip on the floor. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
Unplug the unit from main power outlet and empty whole unit and keep both the doors open and then connect the power after 24 hours and recheck.This procedure is called manual defrost reset.If this helps then its OK,but if this procedure not helping then its the faulty defrost unit and it needs to be replaced.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | GE Refrigerators
Water leak
A number of fridges deal with condensate by feeding it down to a tray on top of the motor where it evaporates due to the heat from the motor , by pulling the fridge out you should be able to see if this is the case , if so has your tray rusted away and is leaking straight to the floor
Or
The insulation on the fridge shell may have broken down causing ice to form between the outer shell the filler and the inner lining.
This will condensate and will run down onto the floor.
May 25, 2009 | KitchenAid Refrigerators
Refrigerator has water leak
Had the same problem with mine. Got a technician to have a look. Inside the fridge at the back there's an overflow tray. CHeck if this is not blocked. Clear it by putting a tray behind your fridge under the overlfow pipe and pour hot water through the overflow tray inside the fridge. Sometimes food gets stuck in there and nobody thinks to clear this out. Mine was easily unblocked and now its stopped leaking.
Apr 14, 2008 | Refrigerators
Have a 17 year old Kelvinator N640T side by side no frost fridge freezer. Runs well except ice builds up on the bottom of the freezer compartment and when it builds up too much some melts spilling water...
You problem lies in a blocked drain or a broken drain connection to the metal drip tray at the bottom of the freezer heat exchanger. You could try blowing the drain out from beneath the fridge, which is difficult as it is very hard to access. Alternatively you will need to remove the tray. This means you have to remove the contents of the freezer, remove the lower long white metal cover and blow out the drain. Then test the drain with a cup of water. If it leaks into the bottom of the freezer compartment you will have to remove the drain and epoxy the joint together again.
Not a job for the faint hearted!
JB
Apr 07, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
