Question about Lands Phones
How to get rid of 'caller on other phone - Lands Phones
This is a nuisance call what do I do next
go away from here thats what.do not post this here ever.
Jan 03, 2018 | Computers & Internet
Phone adds #1 to local calls in caller ID
talk with your service provider
if the number 1 is placed before a local number then logically when calling that number, the number would be recognized as a local number and be charged as such
Form what you say , if the number was from a caller in a different state and the number was prefixed by say 6 then the system would recognize that as a long distance call
again talk with your service provider and if accurate contact your state governor or senator and make an issue of the law requiring the prefix number on caller id
Nov 21, 2017 | Panasonic KX-TG5439 5.8 GHz Dual Handset...
Callers' name doesn't show even though i have them in my contacts
Solution 1
Some caller's names does not appear even though they are on your contact list because you have then copied twice on your phone. What you'll need do it to delete one contact each for the caller id's that don't show when they call in. Once you get this done, your phone phone would begin to show contacts on your phone.
If you want to know if this true, then get someone around you and save his/her name twice then ask him/her to call you. You'll notice that the caller id would not appear, but once you get one of the contacts deleted and ask him/her to call you back, you'll discover that the caller's id would begin to show.
Solution 2
For your access point, just define it the next time you switch on your phone and save it. Then it would not have to change the next time you turn your phone on/off.
Solution 3
To get rid of the welcome go to Menu > Tools > Settings > General > Personalization >
You can set it from here.
Hope this helped.
Aug 18, 2009 | Nokia 5320 XpressMusic Cellular Phone
Callers cannot hear me when I am talking to them.
not sure if its the same problem but i had that with a different model and was told when i placed the charger in the phone it moved the mic slightly and thats why it was not working as it should i used my hands free every time i made a call mine was so bad ..it was a manufacture fault so i was lucky and had the phone changed free !!! hope this helps
Apr 20, 2009 | Nokia 6300 Cellular Phone
No caller ID displayed
If you have digital telephone with cable. First thing you should do is contact the billing department of your service provider. Make sure you are in billing for caller id. If you are let them know you are not receiving service you are paying for. Have them check your number in the switch. Which is the system that allocates each call that is made to and from your number. If this feature is not activated properly in the switch you might be paying for a service that is not properly activated. If all is correct with service provider. Try using another phone that has the caller id feature just to make sure it's not the actual phone. If both phones still doesn't display caller id. You should have your service provider send out a technician to troubleshoot your home telephone lines to make sure all phone jacks and telephone lines are secure and corrosion free, and have them verify service while there. You should also ask about a credit for the time the service was activated until the time the service actually worked.
Oct 14, 2008 | Lands Phones
Want to turn off answering machine and any messages (please enter your remote access code)
ffffffffffffffffffffffffffffffffffffffffffffffuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuucccckkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk
Jun 25, 2008 | AT&T 5840 5.8GHz...
try with ur handsfree that u got with phone or replce ur mic or clean the hole near ur swich side from where u speak. reply me
Mar 06, 2008 | Samsung C417 Cellular Phone
Caller id
see if this corrects the problem. . .press and hold menu/voice mail button to enter the menu. . .press the zero/oper button to go to the message waiting programming option. . then press the edit/flash button to reset tne Message Waiting Indicator. . "DEL" will begin flashing..press the redial/save/ pause button to delete this indicator.. . a long beep will sound to confirm a reset/removal of notification..press menu button to exit. Theo
May 31, 2007 | Xact Communication XG2206 Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
