Question about Furniture
I have a Centrex Wine fridge 82 lt 25 bottle Model ctwc 82d. Need help to reset temp controls,red & white
SOURCE: i want the bottom to be reds and top to be whites
I don't think you'll be able to do this without some modifications to the unit.  The wine cooler is designed to blow cold air into the bottom section, and the top section cools down by spillover of cool air flowing between the glass door and the temperature control panel.
I guess if you could figure out a way to turn the panel that separates the top from the bottom you could make it work.  You'd have to switch the temperature sensing leads on the thermostat inside that panel(that would be pretty easy) and you'd probably want to flip the LED indicators so they read right-side-up.  The main issue would be that the screw holes for mounting that separator panel are all on the bottom, but when you flipped it, they would be on top with no holes in the walls to screw them into.  If you are willing to do that, you might be able to make it work as you would like.
Good Luck!
Posted on Oct 24, 2008
  • 3 Answers
SOURCE: wine fridge light does not turn off
You may know this already, but for what its worth. There is a small switch on the bottom vent grill for on/off of light. Check there first.....
Posted on Feb 01, 2009
SOURCE: lost manual for wine fidge
Push the red and white buttons at the same time for about 3 seconds-the temp will start to flash-then press the white button to lower the set temp-when you have it where you want it then push the set buttom
Posted on Jun 11, 2009
SOURCE: Everstar Beverage/Wine Cooler HDBC36ID not cooling
I returned our unit to Home Depot with relative ease... I think they were all aware there is a problem with these units.
They refunded the full purchase price (even though I was well past the 12-month warranty period). I put the money toward a GE Profile unit that's a little bigger - more expensive, yes; but it works, priceless!
Posted on Mar 24, 2010
mrbobfixit
  • 259 Answers
SOURCE: Are red wines stored on the top or bottom of the
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Posted on Jun 14, 2010
I have a wine enthusiast wine cooler model 272 03 27. Not cooling,compressor kicks on. The fans are running.The temperature never gets below 64.Is it the temp sensor or Control board? Thanks Randy
It sounds like it is in the correct temperature range. You may ned to adjust the temperature to a lower setting.
°C °F Wine Style 19 66 Armagnac, Brandy, Cognac 18 64 Full Bodied Red Wines, Shiraz 17 62 Tawny Port 15 59 Medium Bodied Red Wines 14 57 Amontillado Sherry 13 55 Light Bodied Red Wines 12 54 Full Bodied White Wines 11 52 Medium Bodied White Wines 10 50 Ros?, Light Bodied White Wines 9 48 Vintage Sparkling 8 46 Fino Sherry 7 45 Non-Vintage Sparkling
Dec 01, 2016 | Furniture
Beeping will not stop on wine cooler - red wine side
Beeping usually indicates that something has gone wrong. Probably not cooling properly. The water coming out would indicate that the unit has defrosted. Turn the unit back on again and see if the red side is cooling properly. Some wine fridges have independent evaporators which allows different cooling temps in different parts of the cabinet.
Jun 26, 2014 | Danby DWC2727BLS Silhouette 54-Bottle...
Euro grand bar fridge glass front. Have just replaced curcuit as supplied as apparently all had 100 % failure rate! We bought 3 including dual zone wine fridge. Have replaced boatds, but not not cooling...
If these were bought new, it sounds to me like the company still has a problem with their control boards. I would get the manufacturer on the phone and ask to talk to someone in Engineering.
If bought used, be sure they are set up for the proper supply voltage.
Nov 17, 2013 | Furniture
Does anyone know how to lower the temp below 45 degree's.
Dear friend,
ngfam at you service! happy to assist!
No they have no bypass!
How old is this wine cooler! MY ADVICE BUY ONE NEW!
It cost $241 to buy a new one at the site below!
NOT WORTH THE MONEY FOR A COMPRESSOR
Or model #HBCN05EBB FOR $249 96 BOTTLES CAPACITY
http://www.buy.com/prod/bc112g-30-bottle-freestanding-wine-
refrigerator/q/loc/63024/203111423.html
If the dishwasher is 10 years or older its not worth investing money tofix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Jul 07, 2008 | Haier BC112G Wine Cooler
I have a magic chef wine cooler (Model MCWC50DBT) and the labels keep falling off of the bottles. The temperature is set to red and we don't seem to have any other problems.
All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
May 27, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Fridge is in lock mode
Please press the white wine key and interior lamp button together for 3 seconds.
Jan 09, 2008 | Refrigerators
I want the bottom to be reds and top to be whites
Good Luck!
Dec 27, 2007 | Danby DWC283BLS Wine Cooler
Lost manual for wine fidge
Oct 18, 2007 | Haier HVF060A Wine Cooler
Furniture Logo
115 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
