Port is not working properly
Please send to step by step procedure
to start the port
  • 9 more comments
  • morrad1 May 11, 2010
    update the driver than it should work properly
  • Kevin May 11, 2010
    it would help to know what port you are trying to start.
  • Douglessd
    Douglessd May 11, 2010
    More information please. What kind of computer are you using? Which port is giving you trouble? Are you seeing any error messages?
  • Syednoor May 11, 2010
    please explain the question briefly what port is not working
  • Project NOMAD
    Project NOMAD May 11, 2010
    Which port ? Serial USB Video Ethernet etc etc. ?
  • Abhinandan  Patil
    Abhinandan Patil May 11, 2010
    which port you want to start?
  • Trivious
    Trivious May 11, 2010
    Port? Can you elaborate? Is it an HTTP port, a Serial port? Is it hardware or a firewall - software port?
  • James Trageser
    James Trageser May 11, 2010
    Please Clarify... Thanks :)
  • James Trageser
    Could you please clarify your question for us? You didn't give us much to work with here :)
  • mikeph82 May 11, 2010
    what OS are you using?
  • Bob Kitaji May 11, 2010
    Can you describe which port you're talking about? What are you trying to connect?
  • 601 Answers
Hi...
Which port are you mentioning about.
Reinstall the chip set driver and all the port and plug and play type.
Still let me know
Thanks
Smith
Posted on Aug 09, 2009
How do I repair the USB port on my Dell S17-162B?
Well Mr.Brown,
It's not much difficult but i suggest you to send it to DELL support if it lies in warranty.
any way here i am providing complete step by step procedure to do it.
1) First open the screws of main compartment which reveals backside(you can see the CPU FAN)
2)Then open the Screws of Hard disc portion backside
3) Open all surrounding screws which supports whole body
4) make sure one or two screws are at battery compartment open them also
5) Ultimately you have to open whole body of laptop which Reveals the Motherboard.
6) Now carefully disconnect the removable sockets and find your Faulty USB PORT on that Board.
7) Replace it with new USB PORT by re-solder it.
8) Then carefully connect all the components and sockets that you had open previously.
Then fix all the screws of backside.
I hope you understand above procedure to replace your USB PORT. Please give your rating which help to improve the service. Thanks a lot to giving me such opportunity to help you.
Dec 07, 2011 | Dell Computers & Internet
I960 won't print despite new print head
Hello!!
Switch off the printer and disconect the USB cable for 30 seconds. deep clean on the black head to get it work properly.
Feb 08, 2008 | Canon I960 InkJet Photo Printer
Acer aspire ax1700-u3700a. The dvi port has stopped sending signals to the monitor but the vga port works. I use the vga port but the computer sometimes gives blue screens then strats back woring normally....
I can see you do have two issues here.Let us first fix the DVi port.Please see follow the steps below.
1. Please check video configuration by looking it up on the PC control panel.
2. Please make sure you choose the both DVi and VGA port by simply placing "tick" on the box.
On your second issue.Please follow the steps below
1. The "blue screen" normally comes up if you a faulty VGA cable or the connection is somehow loose.Please check if it is properly plug-in.
2. If the problem continues,I would suggest please contact the manufacturer or the store where the
item was purchase
Sep 04, 2011 | Acer Aspire AX1700-U3793A PC Desktop
Spedometer in console will not work
Proper way to start the diagnosis procedure would be to eyeball the speed sensor and make sure the harness/connector isn't damaged.
If it looks fine, please send me your vehicle information and I will research the diagnosis procedure regarding whether the sensor is faulty. If it is not, then the next step would be to see if the cluster is bad.
I will be happy to help you further.
Mar 27, 2011 | 1991 Toyota Pickup
Actullay, sir, i broughted this scanner systems about 10years old that time in pakistan win xp is not produce properly i have orignal cd of scanner but this driver the said cd valid for win98 and millinium...
How to make any Acer/BenQ/Vuego/Brisa parallel port scanner work in Windows XP (note: this procedure does not work in Windows 7 or Vista, only in XP):
Instructions for installing Acer brand parallel port scanners in Windows XP:
For this driver to work in XP you must install the MiraScan software then install the scanner manually.
Step 1. Download MiraScan v3.424 from the web: ftp://12.145.38.159/scanner/drivers/parallel/mirascanv3424p.zip
Step 2. Unzip and install the Mira Scan driver that you just downloaded. After installation , system will suggest you to add a scanner
Step 3. Then, add an imaging device
Step 4. Then the Scanner and Camera Installation Wizard comes up. Click Next at the bottom.
Step 5. Then on Scanner and Camera Installation Wizard screen it will ask you which scanner or camera do you want to install? You want to go where it says "Manufacturer" and then click on "EPPSCANNER" and where it says "Model" it should say "color flatbedscanner". Make sure it is highlighted, also. Click on Next at the bottom.
Note: For additional screen shots of this procedure and installation procedures, please read the pdf file posted here: ftp://12.145.38.159/scanner/manuals/scpinwxp-eng.pdf
The Screenshots show to be for Mirascan v3.423 but the procedure is same for v3.424
Note: Adobe Acrobat Reader is required to view or print this file.
Note: This solution does not work on all computers but many report success with it. The hang-up is caused from certain chipsets in the computer motherboard.
Sep 04, 2010 | Acer ScanPrisa 640P Flatbed Scanner
The left button below my mouse pad is not working on hp pavilion
blkcooper
Give Hp a shout.. and they will send you one. when you get it, come back onlie and I do a step X Step procedure for you
Jul 22, 2010 | Microsoft HP Pavilion DV6276US Notebook PC
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
I need a driver soft ware to work with windows xpsp2 for acerscan prisa 310p email: elfondkya_ihabmoh@yahoo.com
Instructions for installing Acer brand parallel port scanners in Windowsmag-glass_10x10.gif XP:
Step 1. Download MiraScan v3.424 from the web :
Mirascan_v3424p.exe
Step 5. Then on Scanner and Camera Installation Wizard screen it will ask you which scanner or camera do you want to install? You want to go where it says "Manufacturer" and then click on EPPSCANNER and where it says "Model" it should say color flatbedscanner. Make sure it is highlighted, also. Click on Next at the bottom.
scpinwxp-eng.pdf
The Screenshots show to be for Mirascan v3.423 but procedure is same for v3.424
Note: not all XP systems will work with parallel port scanners. If the procedure doesn't work for you, then you must obtain a newer USB type scanner.
Mar 22, 2009 | AcerScan Prisa 620U Flatbed Scanner
Driver for Acer Vuego 610P
Mirascan_v3424p.exe
Note: For additional of this procedure and installation procedures, please read the pdf file posted here:
scpinwxp-eng.pdf
from Vuego Scan
Nov 26, 2008 | AcerScan 610P Flatbed Scanner
Problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Jul 02, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
