Question about Toshiba Office Equipment & Supplies
Developer setting mode in toshiba e studio 207
I need to replace Developer, What service mode have to run in Estudio 207
  • 126 Answers
SOURCE: Change the developer in afficio 450
To remove the Dev. unit.
1. Open the right upper cover and front cover.
2. PCU. (☛ 3.11.1)
NOTE: Spread paper on a clean flat surface that is free of pins, paper clips,
staples, screws or any other metal objects.
3. Loosen [A] (! x1)
4. Rotate bracket [B] left.
5. Development unit [C]
NOTE: Pull slowly to avoid scratching or nicking the development roller.
6. Set the development unit on the spread paper.
7. If you are temporarily installing a used development unit for test purposes,
perform SP2-220 and 2-802-1 after installation (☛ Chapter 5, “Service Tables)
Replacing the Dev. material.
1. Development unit (☛ 3.12.1)
2. Remove the development roller (☛ 3.12.3)
3. Empty toner [A]
4. Turn drive gear [B] to ensure that no developer remains in the unit or on the
developer roller.
NOTE: Dispose of the used developer in accordance with local regulations.
Work carefully to avoid scratching or nicking the development roller.
5. Pour approximately 1/3 of the developer [C] evenly along the length of the
development unit.
6. Rotate the drive gear [D] to work the developer into the unit. Repeat [C] and [D]
until all toner is in the unit and level with the edges.
7. Reassemble the development unit
8. Cover the toner entrance hole [A] with a piece of paper.
9. Install the development unit in the machine.
10. Turn on the main power switch, make sure that the machine has warmed up,
then perform the TD sensor initial setting using SP 2-801.
NOTE: When performing this setting, cover the toner entrance hole with a
piece of paper. This prevents used toner falling from the PCU into the
development unit during the TD sensor initial setting and interfering
with the Vref setting (toner density reference voltage).
11. After performing the TD sensor initial setting, remove the sheet [A] from the development unit.
This is how you replace and reset (calibrate) the new Dev. material.
Posted on Jan 20, 2009
  • 10515 Answers
SOURCE: On a Toshiba e studio
The procedure is explained below :-
Technical Service Procedure
Correct procedure for service of TOSHIBA e-Studio 161
When the spanner light and the developer (sun) light are illuminated it is time for a service.
* Try and run the PM Service and drum life counters together.
* Part that are required for a 50,000 copy service (OD 1620 DRUM, D1620 DEVELOPER, BL1620D DRUM BLADE)
* Clean and inspect drum unit.
* Clean all optics and glass.
* Clean and rewire transfer corona.
* Clean and check main charge needle electrode [saw tooth]
* Clean and check fuser units including blades, rollers and scraper fingers.
* Clean erase lamps and ozone filters.
* Clean and check all feed rollers.
* Clean machine inside and out.
* Replace the required parts.
* Reset mini maintenance counters:
* [CLEAR] > [EXPOSURE] > [CLEAR ]> [EXPOSURE] and the machine will die.
* Input [20] [START] [01] [START]"000""000" will flash on the display.
* Reset the drum life counter:
* Input [24] [START] [07] [START] "000"000" will flash on the display
* Reset developer life counter:
* Input [42] [START] [01] [START] "000""000" will flash on the display.
* Once all the part have been replaced and the counters been reset, check the copy quality.
* Notes: Application of the patting powder is for reducing the friction between the drum and cleaning blade. If the application of
patting powder is neglected, the drum and cleaning blade may be damaged. Please clean off the patting powder before putting the
cleaner unit into the machine.
Developing doctor gap adjustment
1) Loosen the developing doctor fixing screw A.
2) Insert a thickness gauge of 1.5mm to the three positions at 20mm and 130mm from the both ends of the developing
doctor as shown.
3) Push the developing doctor in the arrow direction, and tighten the developing doctor fixing screw. (Perform the same
procedure for the front and the rear frames.)
4) Check the clearance of the developing doctor. If it is within the specified range, then fix the doctor fixing screw with
screw lock.
* When inserting a thickness gauge, be careful not to scratch the developing doctor and the MG roller.
Follow these steps to change a tray's paper size setting.
* The paper size setting cannot be changed when the machine has stopped temporarily due to running out of
paper or a misfeed, or during interrupt copying.
* During printing (even in copy mode), the paper size setting cannot be changed.
* A5 (ST) size paper can only be selected in upper paper tray.
* Do not load paper that is a different size than the paper size setting. Copying will not be possible.
Hold down the [PAPER SIZE ENTER]
key for more than 5 seconds to
set the selected paper size.
The currently selected
paper feed location
indicator will blink and
the corresponding paper
size (which is currently
set) indicator will light
steadily. All other
indicators will go out.
If the machine has two paper trays,
use the [TRAY SELECT] key to
select the paper tray for which you
wish to change the paper size setting.
Each time the [TRAY
SELECT] key is
pressed, a paper tray will
be indicated with a
blinking paper feed
location indicator.
to select the paper size.
The indicator of the
selected paper size lights
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 01, 2010
  • 263 Answers
SOURCE: How to install developer in a new Ricoh Aficio
I suppose you have the developer in the developer unit, YES????
If so you just need to do developer initialization.
Press yellow key.
press on the key pad 107.
Old red key at least 3 sec.(if you did everything well you are in SP MODE)
Press 1 (to copy sp)
Search 2 drum (one time on the left key)
Press ok
Search SP 214 Developer initialization
Press execut
Hope you understood. Good luke.
Posted on Feb 17, 2011
Testimonial: "Thank you so much! This is what I need"
  • 81 Answers
SOURCE: what is the simulation code
THIS SHOULD ONLY BE DONE IF YOU REPLACED THE DEVELOPER, OTHERWISE IT CAN DAMAGE THE DEVELOPER CURRENTLY IN THE MACHINE turn off machine . turn it on holding 0 and 5 when machine starts enter code 200 after about 2-5 min it will go ito adj. mode. press the enter key on the bottom of the display.
Posted on Aug 09, 2011
SOURCE: Developer leakage while copying
1. Check the spiral beneath the mag roller. The spiral is not a single piece. there is a joint in the edge (a lock). this may be worn out. You need to remove the mag roller to check this.
2. Check the grid of the main charger. Replace the main charger if required.
Posted on Nov 28, 2012
Estudio 355 developer appear on copy
Since developer material is spilling, so the developer material is less, thus blur print will occur. The fastest way to solve this issue is to replace a whole new developer unit with new developer material, but this might be quite costly. Otherwise, u need to ask technician to check your machine. Then only can confirm the defects.
Jan 04, 2015 | Office Equipment & Supplies
Konica minolta bizhub 3010 cof 32
When was the last time the developer and drum where replaced? Does the machine say "REPLACE DRUM in the upper left corner of the operation screen? More then likely your drum and developer need to be replace if not those then the DEVELOPER CARTRIDGE NEED TO BE REPLACE when was the last time that was replaced? Every four drums the developer cartridge needs to be replaced. When the developer was replace was a F8 run from service mode?
May 16, 2014 | Minolta Office Equipment & Supplies
E studio 600 error cod f 105 how can reset
sir i have a toshbia estudio 600 the copy is coming light but i put the toner manually in the developer tank the copy is o.k. toner is full and the developer also new
Dec 01, 2013 | Toshiba E-STUDIO 650 Copier
Error code CF70 on toshiba e-studio 600
toshiba e studio600 error codes cf 70
Jul 20, 2012 | Toshiba E-STUDIO 650 Copier
Toshiba E studio 207 C97 error solution
sir i have Toshiba 207 copier sir now write on screen call for service C97 PROBLAM
Jun 22, 2012 | Toshiba E-Studio167 Copier
What is the simulation code for developer setting of toshiba estudio 166.
Aug 06, 2011 | Toshiba Estudio 200L Copier
Toshiba estudio 167 - time for maintanence appear so what can i do??
you need to replace some parts on the copier (consumables)
KIT - 2340 Developer Maintenance Kit - Kit Includes: Drum Blade, Recovery Blade, ( 2 ) Drum Picker Finger, Main Charge Grid, Main Charge, ( 2 ) Transfer Separation Wire, Developer - Genuine Toshiba Part -- resells for about $240 , youc an buy this at any online store .. example , please rate me 4 thumbs up
Dec 29, 2010 | Toshiba E-Studio167 Copier
Estudio 207 fax memory full
U can try reset ur MFP to default mode by pressing " *+1+3 " and ON the MFP.
Nov 30, 2009 | Toshiba Office Equipment & Supplies
106 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
