Question about Alessi Kitchen Appliances - Others
How do I get the base back onto the Alessi electric kettle MG32 after taking it off to fix the switch, which keep cutting off?
jerryg50
  • 1667 Answers
SOURCE: Alessi Electric kettle
The switch is most likely defective and has to be changed. It is also possible that the heating element is pulling too much current and also has to be changed.
An appliance service tech would have the tools to test the kettle and determine the exact fault.
Jerry G.
Posted on Apr 29, 2008
cactus bob
  • 267 Answers
SOURCE: GE Model 168950 Electric Kettle base unit bad
di you try calling GE @ 1800-ge-cares ? dont except much but my parts book only says :PRIVATE BRAND GE , MADE IN CHINA , NO PARTS ORDERED , NO PARTS , 0 IN STOCK ...........
Posted on Feb 20, 2009
  • 3600 Answers
SOURCE: Our cuisinart electric tea kettle stopped working.
Most likey a burned out heating coil. You can buy them let me know the model number and I can give you a web site to go to buy it.
Posted on Aug 06, 2009
co7196
  • 3433 Answers
SOURCE: Kettle will not stay on
Sounds like the switch is weight sensitive. A safety feature to prevent overheat as contents run low? The baseplate is probably not moving freely enough to move accordingly.
Posted on Sep 13, 2009
  • 351 Answers
SOURCE: Where can I buy spare parts for the Alessi 9093 cordless kettle?
This site seems t0o have the parts yo are looking for ..
Alessi 9093
http://themagazine.info/products/-/167.html
Posted on May 11, 2010
Can I get element replacement
According to their website and the parts available no. Write to their customer service and protest that you don't want to discard a perfectly good kettle because the element has gone. These days kettles are classed as a throw-away item.
MG32 Electrical appliances Alessi
Nov 04, 2015 | Alessi MG32 Cordless Electric Kettle
Removal of triangular headed screws
Appliances like these are not designed to be opened. If it is faulty it should be replaced by a new one.
Jun 21, 2014 | Alessi MG32 Cordless Electric Kettle
Fix bad contact on oster electric kettle base
Replace the contact assembly. Call the manufacture about how to purchase their parts. I would also replace the one on the tank at the same time since they work together.
Apr 29, 2012 | Alessi MG32 Cordless Electric Kettle
It blew my fuse box, i have changed the fuse the light comes on but it is not heating up approx 5 years old
This happened to my Alessi kettle also. I changed the fuse in the plug but the kettle is dead! Red lights are on but the heating element in gone. From what i can gather parts are not available to fix it.
Feb 15, 2011 | Alessi MG32 Cordless Electric Kettle
What is the best way to clean this kettle - particularly the rim in the top where the limescale has built up and the resin base
Fill it with vinegar and leave to soak overnight/for two nights if really bad.
Any parts which are impossible to fill with vinegar - lids/spouts, soak a cloth or tissue in vinegar and wrap/wedge into....and leave to soak overnight.
Dec 06, 2010 | Alessi MG32 Cordless Electric Kettle
Flash from beneath kettle. Now not working. It is not the fuse in the plug
get it serviced the think is the heating coil may have got burnt out if you need to replace it remove the cover below and take out the coil carefully with the terminals ..now replace the coil of same wattage usually 700watts in the same way
there can also be a problem with some wire got burnt due to heating .try to find the wire located near/attached with the heating coil and check whether everything is correct
Dec 04, 2010 | Alessi MG32 Cordless Electric Kettle
My daughter bought me an Alessi cordless kettle for Christmas 2008. After 9 months it simply stopped heating water! The red light was lit on the base, so we knew the fuse hadn't gone, but it was completely...
Have you tried using it on a different socket outlet ? Possibly there is a problem with the wiring at this socket.
If the electricity supply "trips" at the consumer unit it is either the RCD which trips due to e.g. the base of the kettle becoming wet or alternatively the MCB tripping due to an overload which shouldn't happen unless there is a fault in the kettle.
When you got a replacement kettle presumably they replaced the base also?
Sep 01, 2010 | Alessi Al384730-640 Cordless Electric...
MG32 Cordless Electric Kettle: Power light shows on my kettle but water does not...
sounds like there's water in the element. Empty it out and let it dry out completely for a few days, and then try it again.
If the element is a concealed element (ie- you can't see the coils when you open the lid up) then there's probably a water leak into the sealed compartment.
Contact the manufacturer for a recommended repairer.
May 17, 2010 | Alessi MG32 Cordless Electric Kettle
Sep 13, 2009 | Alessi MG32 Cordless Electric Kettle
Kitchen Appliances - Others Logo
137 people viewed this question
Top Alessi Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
Bill Boyd
Are you an Alessi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
