Question about Ovens
I have a por883s westinghouse oven it wont turn on but display clock is on and pyro buttom works but fuction and on font work
Powerman
  • 68 Answers
SOURCE: GE Profile JGB97 Self Cleaning Oven Controls won't work
You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
I hope it works for you too. Please let me know at the following:
hutchipop@yahoo.com
Good Luck,
Charlie Popeck,P.E.
Consulting Engineer
Posted on Feb 07, 2008
SOURCE: the clock & oven on my cannon chichester cooker dosent work
Hi anyone , my chichester ignition button has stopped working - is there a battery located somewhere
Posted on Mar 10, 2008
  • 1462 Answers
SOURCE: zanussi oven wont work. clock flashing 'auto'
you need to set clock before oven will work. do you still have instruction book as it will tell you there how to do it
Posted on Jun 19, 2008
SOURCE: Westinghouse Freestyle 668 oven not doing anything , just blinkin
Yes I can help.Hold down the buttoms on the far left at the same and then set the time using the + and - buttons.Cheers
Posted on Jan 17, 2010
SOURCE: frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Posted on Aug 12, 2010
Why wont my oven work after a pyro clean
have u checked the oven clock to see if it was accidentally chnaged
Mar 11, 2015 | Ovens
My Westinghouse 668 wall oven won't allow me to set the time. We had a power outage and I have checked the power and it's fine now. But the display flashes between 0:00 and auto and I can't hold the two...
Does the rest of the oven work ok? Did the timer work OK before the outage? Is the oven under warranty? Was the power outage at your home only? Check with the manual to see if it addresses your problem, there may be a way to reset the system and then I would say that you would need to contact Westinghouse and explain the situation.
Nov 06, 2014 | Ovens
My Westinghouse multi function oven has an A flashing on the clock and no number of combinations can turn it off the oven wont work while its there
Try unplugging it for a couple of minutes. Assuming there's no major problems with it, that should reset it.
Feb 17, 2013 | Ovens
Oven clock no display and oven wont work any way to bypass clock new world cgk 21556
These things are a pain! When you first power up a lot of New Workd ovens, they come up in AUTO mode and the oven won't work, so you have to take it out of auto mode and stop the clock flashing. I'm giessing that though your clock DISPLAY isn't working, the clock is and the oven think it is.
There are 6 buttons below the clock display.To take it out of AUTO and stop the clock and oven thinking the display is flashing:
Numbering the buttons from left to right as 1,2,3,4,5 and 6 (because they have silly symbols!) press the 4th button (a picture of a hand) you will hear a little click and the oven will now work. If you have to power the unit off for more than about a minute at any time, you will need to do this again
Jul 06, 2011 | New World Ovens
I have just moved into a new house with but i can't get the westinghouse PHL768U oven to work. I need help in setting controls like time etc. I havent got any manual. Please help
Chances are, its been turned off and you have had the power turned back on... I found this out as well, that you need to 'acknowledge' the stove... press the centre button by the clock display, and this should beep.. you should then be able to have the elements turn on, and if you want, set the clock.. See the display, and there will be a small red light, that bounces round from corner to corner when you press the Mode button. ie, if the red light is next to Clock, then you can adjust the clock time etc etc.. hope this helps.. otherwise, we also had to find the Range Power switch going to the stovetop...
Jan 28, 2011 | Ovens
Cant reset clock on westinghouse 476 underbench gas oven
When I turn on my westinghouse gas oven (GOL476), it appears to ignite immediately but after 3 or 4 minutes there is a strong gas smell which lasts for sometime before it gradually disappears.
Sep 17, 2009 | Kenmore 33169 Gas Single Oven
Apr 20, 2009 | Ovens
KitchenAid Superba Double Oven clock won't light up
hold down the clock button for 3-5 secs. youve somehow toggled the clock dosplay off.
Nov 05, 2008 | Ovens
Westinghouse Freestyle 476 Cooktop Oven
After getting an electrician out, apparently the time needs to be set on the oven. As we're in a rental & don't have a manual/ couldn't download one, we got it to work after holding the first two buttons in (the timer buton + the one that looks like a hot pot) along with the + button at the far right, which made the tim tick on, so it could be set.
The oven works now! : )
Aug 20, 2008 | Ovens
Pyrolytic cleaning fault
fixed very simply just turned off oven at mains turned back on and it worked perfectly!!!!!!!!
Aug 18, 2008 | AEG B5741-4 Electric Single Oven
Ovens Logo
67 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
