Question about Cell Phones
Mic solution - Cell Phones
    Master:
  • 519 Answers
Samsung corby gt b 5310 mic problem solution,mic connection out on the pcb.so i,need solution mic diagram where i connect their mic track ?So plz help me....
Jun 09, 2012 | Samsung GT-B5310 Corby Pro GSM Slider...
Spice m5454 mic ways
spice m5454 mic not
Nov 26, 2011 | Cell Phones
I'm trying to wire a galaxy desk mic to a cobra 200 10 meter mobile
  • The Galaxy desk mic (power mic) is already wired four pin and the Cobra 200 is a 4 pin already as well. So unless someone has messed with them the mic will plug right up to the radio as is.
  • But if someone has repined the mic then follow the pinout I listed below to get it rewired for the Cobra 200
  1. Pin #1 on mic connector - Black wire.
  2. Pin #2 on mic connector - White wire.
  3. Pin #3 on the mic connector - Blue wire.
  4. Pin #4 on the mic connector - Red wire.
  • If you look on the end of the mic connector it will have the imprint of the number for each pin on the mic.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 02, 2011 | Cobra Radio Communications
I have an Asus P5QL PRO Motherboard and I'm trying to connect the FP audio and I need some help on how to connect it up properly. On the heaphones lead I have 4 connectors: EAR R EAR L RETURN...
Hi
Pin arrangement for Front panel Audio is usually:
Pin 1 Left MIC-IN Pin 1 right GROUND
Pin 2 Left MIC VVC (or MIC Power, or MIC BIAS) Pin 2 Right empty
Pin 3 Left R EAR (or R OUT) Pin 3 Right R RETURN
Pin 4 Ground or Empty Pin 4 Right empty
Pin 5 Left L EAR (or L OUT) Pin 5 Right L RETURN
This arrangement should apply to both the HD AA/FP or the Standard AC'97 Headers.
I hope this helps
Aug 28, 2011 | ASUS P5QL PRO Motherboard
Cobra 29 has a 5 tone roger beep . It works fine with a stock Mic . But when I use a d104 I get about a 2 second hum instead of the beep.Any ideas on what is causing this. Thanks
The d104 is a power mic. For what you have explained you have something gone array in your mic or the mic plug. The fact the d104 is a power mic should not make anything hum. With a lot of power behind your CB and the power mic things can sequel with the mic gain turned to high. But a hum is more than likely a bad mic. Try another one. The same kind of mic should be fine.
Jan 24, 2011 | Cobra Radio Communications
How do i turn off my built in mic off
The built-in mic is actually always enabled. It only gets disabled once you connect an external mic just as you have done. Disabling it disables the mic capability which means that it also disables your external mic capability. If you have any problem with the built-in mic being on all the time you could try to go to the volume controller and mute it from there. The downside here is that you would actually need to unmute it each time you use your external mic.
Apr 28, 2010 | Computers & Internet
Regarding the canon hv20 camcorder. When using an external canon MIC a) How do you know the mic is working and you are not picking up sound on the internal MIC b)On connecting the external MIC an icon...
If you put the camcorder in manual mode, there is a microphone sensor that will move when sound is picked up by the external microphone. In manual you can keep everything else automatic. The off for the mic means that the built in mic is turned off when an external mic is attached.
Sep 16, 2008 | Canon HV20 HDV Digital Camcorder
No Sound Coming out my Microphone
i know this might sound a little obvious and maybe irrelevant to the problem, but did you press the switch on the mic? it will turn the mic on and off. make sure sound and mic are unmuted in windows volume control. if both are these didnt solve the problem, test the mic on another computer. if the mic works, maybe its not the mic that has the problem. if the mic doesnt work, then your mic may be defective or damaged in some way or other.
Mar 28, 2008 | Philips PH62080 Uni-Directional Microphone...
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
