Question about Hilti TE 7-C 120V Rotary Hammer Drill
Hilti te-72 hammer failure
How can I open Hilti te-72, to see what is wrong with hammer?
I oppend at the back, but I can't open the front side.
At the back fall off some broken pieces, form the middle.
    Scholar:
  • Hilti Expert
  • 123 Answers
Do not put it in hammer mode and try to unscrew the chuck! This will break the housing internally. To remove the chuck you will have to put a chisel in the chuck. Lock that chisel in a big vice. You will then have to put a pipe wrench on the chuck to unscrew it. It is regular threads but there will be loctite on it. Once that is off your will have a spring and two roller bearings to remove before you can slide the bell off. You will then have 8 5MM screws to remove. This will remove the chuck. You will then have a snap ring to remove. After that you can remove the whole cylinder assy. More then likely your connecting rod is broken.
Posted on Oct 09, 2009
  • 31 Answers
I thought hilti had life tim guaranteeplease chck this out first bfore stripping, please leave feedback
Posted on Jul 20, 2009
The chuck should unscrew on the front of the machine. Put it in hammer only mode and use a pipe wrench to remove chuck then there will be a snap ring to remove further in the tool. I suspect that the conrod that drives the piston has broken as that recently happened with my te 72.
Posted on Aug 19, 2009
Where can I get a new side handle for my hilti te 2s
Try http://www.hilti.com/holcom/page/module/home/home_dispatcher.jsf
Jun 22, 2012 | Dewalt Hilti Te 2 Rotary Hammer Drill
Reset service light on hilti te 706
I have one Hilti Mechie , TE 706 Avr, Now Red Light Only Blinking ,Mechine Not Working
Jun 12, 2012 | Hilti TE 70 Hammer Drill Performance...
I have hilti te 72 it works but will not hammer
More than likely the con rod is broken. To check remove the shift lever on top by removing the center phillips head screw. then with internal snap ring pliers remove the snap ring.put your phillips screw back in with out the shift lever. Take a pair of pliers and grab the screw and pull the shift boss out. You then can see if the con rod is broken or not. The bad news is those parts are hard to come by.
Dec 15, 2010 | Hilti Drills
Hilti TE 17. Hammer doesnt work. Rotary does.
Most likely the O-rings are worn - tool has no compression to move the hammers inside.
Less likely: the connecting rod for the piston is broken so piston isn't moving - or 2nd hammer is broken into pieces.
I would open it up & check the orings first
Jul 31, 2010 | Hilti Drills
The chuck on my old Hilti TE 60 is stripped.
Are you talking about the cap nut that threads onto the chuck? It is very rare that it would strip out. Word of warning if you do find one and thread it back on. You need to have a chisel in the chuck and have the chisel end locked in a vise. This protects from breaking the gear housing on the inside where the shift dog rides up and down.
Those parts are no longer available but you can still find some used on Ebay. Also the TE-72 used the same chuck parts.
Apr 27, 2010 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Will the bits from the te-c3x fit my te-17
Yes. New bits will fit old Hilti drills. Old Hilti bits do not fit the new (last 15 years) Hilti drills.
Apr 07, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
I need brushes for a hilti te-72 where can i buy parts
go to Hilti.com and you can use their locator to try and find local suppliers or order them direct. You can also call them at 1-800-879-8000
Mar 14, 2010 | Hilti Drills
Hilti TE 12. It will not hammer.
the rotory cam has been broken inside if not producing the hammer effect
Mar 11, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
HILTI TE 72 STOPPED HAMMERING BUT STILL WILL DRILL
It could be that your connecting rod is broken. You can check by taking your shift lever off of the top of the gear housing and then removing the snap ring to remove the shift boss. That will allow you to look at the crankshaft and connecting rod. If it is broken I would check with Hilti to see if they still carry parts for the TE 72.
Mar 07, 2010 | Drills
Hilti TE 7-C 120V Rotary Hammer Drill Logo
3,805 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
