Question about Dishwashers
Dishlex globle 300 machine not draining staying full of water
Benimur
  • 6966 Answers
SOURCE: dishlex global 300 - eco
Initially, ps try:
  • unplug from the mains for say 15 minutes;
  • plug back in;
  • power/turn on;
  • press and hold the start/pause and Program simultaneously;
  • wait for the confirmation beep.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 11, 2008
  • 574 Answers
SOURCE: Dishlex Global 300. Eco light flashing and nothing happens.
could be the water inlet valve or solenoid
Posted on Jan 25, 2010
  • 713 Answers
SOURCE: Dishlex Global 300 starts to fill with water, then
ok this sounds like your water has stopped coming in or timed out b4 the pressure switch is activated. hold eco button down, u will hear a beep then a light will come up, keep pushing the button until u see the light.reply and tell me which light has come up, and i can help u fix the problem.
Posted on May 05, 2010
SOURCE: can you connect a dishlex
Hi Devilnz_05
I have a DX300WA global model and the instruction manual actually recommends that you use the hot water outlet for a better cleaning result, but of course it is not mandatory.
Posted on Jul 06, 2010
techbuster
  • 5081 Answers
SOURCE: Hi I have a Dishlex
Since the drain pump will pump the water out using the "cancel/drain" button, if it did not work then your problem is likely to be in the drain hose system or the garbage disposal downstream from the drain pump. Check for kinks in clogs in the drain hose. Grease can build up in the portion of the drain hose just before it attaches to the garbage disposal.
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
Check the link above for an detailed answer..
COURTESY: Heatman101- A senior expert in fixya
Posted on Oct 04, 2010
The eco light is flashing constantly on my Dishlex Global 300 dishwasher, it is making a noise like a pump is running continously, but the unit will not operate. Can you give me some possible faults and...
The symptoms on a Dishlex Global 300 dishwasher:
  • eco light is flashing constantly;
  • noise on pump running continuously;
  • but the unit will not operate.
Possible corrective actions include:
  • water level - pls check incoming water pressure, filter, water level sensor, water valve;
  • base/bottom overflow sensor - there is a float switch in the base of the machine inside a small plastic dish. Behind the kick panel, access through a metal lid/panel/cover secured by 2 small screws. Dry completely the area;
  • Air/dry/ventilate the unit/system for a couple of days;
  • reduce incoming water pressure.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Oct 26, 2008 | Dishwashers
Starts to fill on normal cycle then stops and fast cycle light comes on
If it's like a Dishlex 300, the fast cycle light means there is a blockage in the drain line, somewhere. Check and clean your filters. Also, check your drain hose going to the sink for a blockage.
Nov 04, 2014 | Dishwashers
Hi there, we have had our dishlex 300 dishwasher switched off for a while and today I turned it on. I started a cycle and it stopped after a few minutes and then the Eco button started flashing. I opened...
Hi just read your posting.Now the reason these dishwashers flash ECO is because there is either water in the bottom tray or your drain pump is open circuit.Is the machine making a pumping noise when it is flashing the ECO light,or is it completely silent?Please reply on additional information and I am sure I can help you.Looking forward to your reply.
Sep 12, 2010 | Dishwashers
Dishlex global 300 just installed new pump now wont fill up just stuck on drain
make sure you have the hoses attached to the water supply usually hot water under your sink.
Jul 06, 2010 | Dishwashers
Jan 25, 2010 | Dishwashers
Dishlex 300 eco light
pump auto starts if overfull
sound like the machine is overfilling
check the level ,u may need to clear pressure line
or it may be bocked with gunk
if u dont know call for service
it shouldn't be a major.
Jun 16, 2009 | Dishwashers
The door for the soap has a small crack/hole
you can patch the crack/hole with a one minute marine epoxy. It works great. Regarding the fact that the tablet won't dissolve, you may wish to try a different dishwasher tablet or powder. You may also have another problem with your machine. Are your dishes coming out clean?
May 16, 2009 | Dishwashers
Vulcan dishlex 750 eco taking alot longer to complete wash cycle.
How is the water flow into the machine. Are all your inline filters clean?
Apr 05, 2017 | Dishwashers
Dishlex dishwasher global 300. Dishwasher continues to drain with ECO light flashing. Service manual says it is due to an incorrect fill level or fill line.
Some diswashers have a sump in the bottom with a float switch. If the water level overflows the float will activate the switch which will kill the machine and run the drain pump continuously.
Jul 01, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
