Question about Haier 1.5 cu. ft. Large Capacity Portable Washer HLP24E
How can I reset a Haier Portable Washer? I have HLP24E. It shows UL (unbalanced load) after I choose Rinse&Spin or Spin, and never spins even the washer is empty..
  • Rob Kudyba May 22, 2017
    @gutbucket77 how did you know which hose to drain? I'm having the exact same problem. I took off the hose and it was in near-perfect condition. Tilting the machine half way caused some water to leak out. Would be great to know how to get it all out!
4 Suggested Answers
  • 4 Answers
SOURCE: Keeps on rinsing and spinning over and over again
Aha! Mine was doing the same thing and I also noticed that there was some excess water in bottom of the tub - not the tub that the clothes go in but the one that that tub is sitting in. Does that make sense? Anyway, I cut the zip tie that holds the drainage hose, brought the hose as close to the house as possible and siphoned the excess water out of the tub. After this I tried a small test load and it worked no problem. I think the fact that there was this excess water left in the machine made the load too heavy to start the spin cycle.
Hope this helps.
Posted on Jan 22, 2009
GodBlessU
  • 3513 Answers
SOURCE: Haier Top Load Washer doesn't spin
Hi
There can be two possibilities,one if it has a belt, it is either stretched or slipping or if it doesnt have a belt then there is a clutch like device between the motor and the basket, which is either broke or cracked.
Or follow this easy steps...
Unplug the washer and turn off the water faucets.
Disconnect the water hoses and the drain hose and pull the washer away from the wall, leaving yourself enough room to work behind the appliance.
Lay an old towel down to kneel on and soak up any water that leaks from the hoses.
Remove the rear access panel.
Locate the motor. The rubber drive belt goes around a pulley wheel attached to the motor.
Press on the belt. If it gives more than ¾ inch or so, it needs to be tightened.
Loosen the mounting nut for the motor and push the entire motor to increase the tension on the belt.
Hold the motor in place and tighten the mounting nut.
Make sure you don't tighten the belt too much or it will break. You should be able to press on it and feel it give just slightly.
Replace the drive belt if it shows signs of wear.
Thanks for contacting fixya.com
Posted on Oct 13, 2009
Testimonial: "Thanks! I guess you're right. The belt seems to be too loose and shows signs of wearing. Already ordered new one. Thanks again!"
davidspra65638
  • 8488 Answers
SOURCE: What's causing a Haier HLP24E mini washer to keep throwing a UL unbalanced load error code right before spin cycle?
check level of machine if ok check inside see if springs ok
Posted on May 02, 2018
Testimonial: "Level is okay, and the springs are ok."
Whirlpool cabrio top load washer ul on final spin
It senses that the lid is unlocked, even if it isn't. Could be a defective interlock.
Feb 24, 2018 | Whirlpool Washing Machines
Wtw6600 washer has UL code and has trouble agitating and spinning.
The UL code means Unbalanced Load. Open the lid and move your clothes around so they are distributed evenly. Your spin cycle will then work normally.
Apr 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
Nov 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Im getting a uL message on my spin cycle and I dont know why.
The "uL" message stands for "unbalanced load." Open the lid to the washer and redistribute the load if the "uL" display appears on the appliance.Redistributing the load should correct any imbalances in the washer and allow the washer to turn freely. Close the lid and press "Start" to restart the washer.
Jul 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Code ul appears shortly after start up
I think ul is unbalanced load, not unlocked lid.
Jul 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Hope this helps.
May 28, 2008 | Haier HLP21E Top Load Washer
Washer makes loud thumping after finished spin cycle
I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
Haier 1.5 cu. ft. Large Capacity Portable Washer HLP24E Logo
1,008 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
