Question about Printronix Office Equipment & Supplies
I am from pakistan and i am using p8215 printronx.i purchased ribbon cartridge from USA.i installed ribbon it gave message another rigion ribbon installed.plz help
  • 51 Answers
SOURCE: Samsung CLX 3175FW printer toner cartridge
you need to get into technical mode, simply press menu > # > 1 > 9 > 3 > 4 and then press ok tech should be shown on the lcd screen, now go to the menu and data setup, look for memory clear or clear all memory, it should ask you for a destination country, if you choose your country at this prompt and press ok it should accept the toner
Posted on Nov 14, 2009
  • 3 Answers
SOURCE: ribbon failure
check ribbon sensors and clean it
Posted on Feb 19, 2010
  • 2973 Answers
SOURCE: i buy a nokia express music from korea but i use
There should be no problem in using the phone in Pakistan unless it is locked to a particular service provider. If so, then have it unlocked and start using it. Since it is a quad band it should work in pakistan.
Posted on Dec 25, 2010
SOURCE: i bought my hp photosmart
Have you reset the region from the menu?? To do so kindly follow the procedure below
The language and country/region setting determines which language the HP All-in-
One uses to display messages on the color graphics display. Usually, you set the
language and country/region when you first set up the HP All-in-One. However, you
can change the setting at any time by using the following procedure.
1. Press Setup.
2. Press 6, and then press 1.
Finish setup
This displays the Preferences menu, and then selects Set Language & Country/
Region.
A list of languages appears. Press or to scroll through the list of languages.
3. When your language is highlighted, press OK.
4. When prompted, press 1 for Yes or 2 for No.
The countries/regions for the selected language appear. Press or to scroll
through the list.
5. When the country/region you want to select is highlighted, press OK.
6. When prompted, press 1 for Yes or 2 for No.
If you require more assistance, feel free to reply to this post,
Thanks for asking FixYa!
Regards, Bilal
Posted on Feb 09, 2011
SOURCE: I bought a Hiti P510S
I am having the same problem with mine. Did you ever find the solution?
Posted on Nov 15, 2011
I bought my hp photosmart c3183 from middle east but the cartridges 131 and 135 are not available in pakistan, instead hp 92 and 93 are used in pakistan for this printer. i installed 92 and 93 cartridges...
1. Press Setup.
Finish setup
Region.
through the list.
Regards, Bilal
Feb 09, 2011 | HP Photosmart 3310 Printer
How do you load a new ink cartridge?
Replacing the Print Cartridge
1 Open the front cover, and then open the top cover by pressing the blue levers on both sides of the top cover.
2 Remove the old print cartridge containing the used ribbon and dispose of it.
3 Remove the plastic stopper from the new print cartridge.
Note You can reuse the print cartridge until it breaks. If you purchased refill ribbons, follow the instructions that came with them.
4 Turn the black spool on the right clockwise to tighten the ribbon as shown.
5 Install the new print cartridge by inserting the recessed first, and then placing
the cartridge into its four holders.
6 Press down on both sides of the top cover to close it securely.
7 Close the front cover.
Brother Customer Service at 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada).
Vertical Black Lines When Receiving
The sender's scanner may be dirty. Ask the sender to make a copy to see if the
problem is with the sending machine. Try receiving from another fax machine.
If the problem continues, call Brother Customer Service at 1-800-284-4329
You can save money by purchasing the 2-PK Refill Ribbon Rolls (PC302RF).
Installation instructions will be included. If you handle the print cartridge (frame)
carefully, you can reuse it until it breaks.
Jan 17, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
I am changing the ink cartridge i put the new one in and it keeps saying End of life and it has a new cartridge what do i do
Here is the solution that will reset the count and allow your fully functional toner cartridge (the one the printer tells you is empty) to continue to work.
Open the front cover.
Press options button.
Press the start button.
Press + or up arrow button 10 times.
Press set button.
You have to do this with a long pause or the system will reset and you will have to start over.
Good luck.
May 24, 2010 | Brother DCP-7020 All-In-One Laser Printer
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
Brother fax 575. need oem manual
Look on pages 12-9 thru 12-11 in this link to Brother for your Fax 575 for ribbon / cartridge installation instructions.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_FAX_575_EN_75.PDF
Nov 11, 2009 | Office Equipment & Supplies
Nov 11, 2009 | Samsung CLX-3175FW Multifunction Laser...
Trying to install ribbon and correction tape which goes first and how
Hi there.
Lets start with ribbon ( the black plastic cassette). You need to place the cartridge on the carrier, engaging the back of the cartridge first.
Press the cartridge into place. Guide the ribbon between the print wheel and the paper path. Turn the drive wheel ( small blue or orange dial) in the direct of the arrows (counter clockwise) to take up any slack.
Here is the USER MANUAL page for you along with some pictures.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_ML_100_EN_216.PDF
Kind regards,
Duane ONeil
www.FJAProducts.com
800-982-9989
Jun 04, 2009 | Brother ML-100 Typewriter
My printer prints out blank pages
try installing the driver for the printer
Mar 12, 2017 | Dell A940 All-In-One InkJet Printer
Brother Typewriter
Dear Chruchbells,
You may be right about typing on the coreection riboon. Tell your friend to take out the ribbon cartridge and reinsert it. It needs to click all the way down, or else if it is at the ink cartridge level, it will type white!
http://www.brother-usa.com/manuals/default.aspx?ProductGroupID=10
Dec 02, 2007 | Brother SX-4000 Typewriter
Top Printronix Office Equipment & Supplies Experts
Toby
Toby
Level 1 Expert
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
