Question about HP Pavilion dv6000z Notebook
Hp dx2400 ethernet port not working. Bought Dlink ethernet card, but not a slot in the system that it will fit in. A printer port has been installed instead. What can be done to repair ethernet port, it is saying that cable is disconnected and it is not.
How do I stop an HP DX2400 computer from causing my Cisco Switches to disable
Check the Event Viewer.
What about network collision between the two? Correct VLAN on the port? Are the switch ports set to auto detect? If not what is the speed? 100 Full? Sync the HP NICs.
Does the HP have any special software that dictates a certain throughput?
Oct 10, 2012 | HP Compaq dx2400 Microtower - KR601UTABA ...
Unplugged power to move now ethernet wont work
If the card from the other pc fits the slot, then it should work fine. Look at the card before you install it in the 1330n and note the model number in case you have to download a driver for it. You can also go to hp.com and search for the network card driver for the m7650n. Let me know if you still have problems with it.
Joe
Apr 08, 2012 | HP Pavilion a1330n (EL466AA) PC Desktop
Emachine t3626 internet port can it be replaced
Absolutely!
The Ethernet port on your eMachines is part of the motherboard.
It is attached directly to the motherboard.
The eMachines T3626 Desktop PC, is supposed to use an
ECS MCP61-P (AM2) motherboard. (Cannot verify)
(Elitegroup Computer Systems. (AM2) refers to the processor socket )
http://www.ebay.com/itm/MotherBoard-eMachines-T3626-T5062-T5234-W3622-/320528791641
(Also scroll down for a larger photo of the motherboard )
The Ethernet port is in the group signified by the letter A, on the left.
The group signified by the letter A, is in the I/O area.
Input/Output area. This is where Input, and Output devices are attached, TO the motherboard. (Using the motherboard's chipset)
Now look down the motherboard, to the two long white slots.
These are PCI slots. Signified by the letter I ( i )
If one of these slots is not being used, plug in an Ethernet Card, that is PCI.
If both of these PCI slots are being used, use the small white slot above them, signified by the letter H.
This is a PCI-Express x1 slot. If it is available, use it.
Use an Ethernet Card designed to fit, in a PCI-Express x1 slot.
Example;
PCI Ethernet Adapter Card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=771339&CatId=1175
PCI-Express x1 Ethernet Adapter Card,
http://www.newegg.com/Product/Product.aspx?Item=N82E16833106033
[ Note*
The PCI-Express x16 slot that you have, (Orange in color, above the white PCI-Express x1 slot), is for a graphics card.
It is ONLY for a graphics card.
The PCI-Express x1 slot is NOT used for a graphics card ]
For additional questions please post in a Comment.
(If you would like the proper procedure for installing a Ethernet Adapter Card, in your eMachines T3626, also state in a Comment)
Regards,
joecoolvette
Dec 19, 2011 | E-Machines eMachines Desktop PC
Ethernet port not functioning after lifghtening strike
Ethernet port not working after a lightning strike? Then I suggest obtaining an inexpensive Ethernet adapter card, and installing it.
One example of an Ethernet adapter card, (Ethernet Card, Networking Card - Same/same),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1275962&CatId=200
The above Ethernet adapter card is a PCI style of adapter card. It plugs into any available PCI expansion slot on the Pavilion a620n's motherboard.
This is an illustration and photo of the Pavilion a620n motherboard from HP Support,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00069442&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&site=null&lang=en&key=null&product=424215
Scrolling to the middle of the page shows first the illustration, then the photo.
In the motherboard photo the three white long expansion slots on the bottom of the motherboard, are the PCI slots.
On this page is information on how to open the computer case, and replace, or install an Ethernet Card,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=424215&
Click on ~ HP Pavilion PCs - Upgrading and Servicing Guide
This is a PDF file. You may have to allow up to 30 seconds to see the first page, and additional time for the file to fully download.
[Removing and Installing an Add-In Card is information on how to remove, and install an Ethernet Card. An Ethernet adapter card is an Add-In Card]
For additional questions, and/or clarification on what has been stated please post in a Comment.
Regards,
joecoolvette
Apr 30, 2011 | HP Pavilion a620n (PC028A) PC Desktop
When trying to install AT&T internet modem on my HP a1210n PC, ethernet did not work when cord plugged into ethernet port on back of harddrive. There aare 2 other ports that have plugs already in them...
see photo 2 here that is the LAN ethernet port
good luck gitting XP working with MS now has the PnP servers shut down. the port must show up first in the device manager.
does it?
Im sure you meant rear of PC case and not a hard drive.
the att tech has no idea at all what is on you desk.
but some PCs super old do have a card,.
yours is old , a1210n
lets look now, as He did not, ok it has one on board.
but is, 10x slower that modern PC, so guess what many folk
wise pop in a new 1gigalan card in the old slots there.
but is limited by the speed of the those old old slow slots.
what we to is first look, and see if there are to jacks there.
1 left below and 1 right not seen below, we do that first.
then use device manager and use the faster one. see?
http://www.pcdied.com/DevMan/internet.html
a1210 actual;. see red arrow,. there? bingo, ethernet. LAN jack
the leds glow at 11 and 12am, do they on jack see em/'?
Nov 05, 2017 | HP Pavilion a1210n (ED895AA) PC Desktop
How to replace ethernet card on hp pavilion a706n, it looks like it is built in to the motherboard, can I just buy a replacement and put in one of the empty slots??
It is buillt in however if you have a spare PCI slot on the motherboard you could fit another ethernet card which would override the built in one.
Sep 14, 2009 | HP Pavilion a706n PC Desktop
HP DX2400 causes Cisco 3560 ports to be err-disabled
Get a Dell? Nope or put some pci/pcie ethernet cards in them and see if that fixes it :)
Aug 20, 2009 | HP Compaq Business Desktop dx2400
Questions about replacing ethernet card on my Dell desktop
Any ethernet card will work fine. Just be sure it's the fit's the correct slot. You probably have a "white" slot which is a pci slot. If it's a longer "black" slot then it's isa. More than likely it came from a pci slot. Before you buy one, confirm the type of slot. In additon, before installing it go to control panel and system settings, hardware, device manager and remove the old one by right clicking it and select delete or remove. Shut down the computer follow instructions for new card.
Probably will have to install the drivers first then shut down and install the new card. Good Luck.
Apr 17, 2009 | Dell Ethernet Card Network Adapter
HP Pavilion dv6000z Notebook Logo
149 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
