Question about York Exercise & Fitness
Can somebody please give me the length and width of a York t200 treadmill
  • 12 Answers
SOURCE: york treadmill
Depending on where you let the smoke out, but I would say yes. Remove the covers, I would look at the lower board first see the blackened areas. But the important question is why did it blow in the first place?
Serving the Twin Cities
Posted on Mar 13, 2009
SOURCE: Hi, have lost the manual for my treadmill York
Error 7 is a Safety Key Error....
That's the red circular magnetic insert that slots into the front of the console...
The manual says : Simply secure the safety key in place and then
try again..
hope this helps
Posted on Apr 20, 2009
  • 1833 Answers
SOURCE: I have a york T200 treadmill that is stuck on an
York treadmill shows E7 - it means that the safety is not positionedcorrectly or the safety switch inside the unit is faulty. It's a magneticswitch. When you place the safety key (it's made of magnet) this switch willactivate. Then only treadmill starts. Check the safety key is positionedcorrectly or not. If it is in position then you have to replace the safetyswitch inside the control console. First try turnthe treadmill off at the electrical outlet and then back on again. If it doesn'twork, treadmill needs safety switch replacement. Hope this will help you. Good Luck.
Posted on Sep 09, 2011
  • 12223 Answers
SOURCE: I need a key for a York treadmill 2750 can anyone help?
Dear Sir:
You have 2 options: you can buy from or you can buy the small magnet from any Hardware store, Since the Key is a small magnet piece.
sincerely. God bless you
Posted on Apr 24, 2012
  • 65 Answers
SOURCE: need to re-assemble my fitline t200 treadmill
are you needing a manual?
Posted on Jul 13, 2012
How do I lubricate with oil my t200 gfit treadmill? Please show pictures. Thanks
You have to use silicon lubricant not oil. chek the video.
If you wish to get some details about treadmill ; check the site linked here. Pull up older posts. Treadmill walking belt lubrication
Dec 04, 2016 | Exercise & Fitness
How do you solve a rectangle is eight inches longer than its width. find the dimensions of the rectangle if the perimeter is 60 cm
The rectangle is 11cm by 19cm.
The perimeter is 60, so the width and length must add to 30. The length is 8 more than the width, or width+width+8=30. Solve that for width, then you can calculate the length based on the width.
If this is homework, be sure to show your work.
Oct 11, 2013 | Lands Phones
How do you calibrate a york treadmill?
yes you must read the instruction manual for software calibration.
or open the hood motor, and read the instruction attached.
or you must call to York supply for customer service and ask them where is located in case that you will not find them.
God bless you
Jul 12, 2012 | Exercise & Fitness
I need a replacement walking belt for my NB 1500 treadmill. How do I get this part?
You can order one from or from Amazon. Just measure your deck length, thickness, and width then search for a matching belt size.
Oct 22, 2011 | New Balance Balance 1500 Treadmill
E1 error on york treadmill
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Jul 21, 2010 | York Exercise & Fitness
York t500 treadmill model no:LQ6010 showing err07 when turned on
that's the red magnetic circular thingy on the console.
Simply secure the safety key in place and try it again
Jan 19, 2009 | York Barbell Home Use Fold-Up Treadmill
Exercise & Fitness Logo
37 people viewed this question
Top York Exercise & Fitness Experts
William McDowell
Are you a York Exercise and Fitnes Expert? Answer questions, earn points and help others
