Question about Whirlpool Washing Machines
Model# wfw8400two2. Whirlpool frontload washer. Whats the sze?
  • 27 Answers
  • 1294 Answers
SOURCE: washer possibly locked
Click on 'washing machines'(below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you hv your manual on line, if available! And dont forget to rate me, on this great site. Possible your belt is off.
Posted on Jan 27, 2008
SOURCE: water leaking from my whirlpool frontload washer
open the door and check between the drum and door frame. There is a large rubber bladder completely surrounding the drum. Pushing the drum further back into the machine will let you see the entire thing and unfold it. These often get small laundry like socks stuck there as well as sharp objects like nails. You may have a tear in it which will leak like that. Replacement parts run about $70.00.
Posted on May 24, 2008
SOURCE: Whirlpool ghw9100lw frontload washer
Did you firgure out what to do? i have the same problem but have no idea what to do
Posted on Aug 02, 2010
blueextc3221
  • 15935 Answers
SOURCE: washer frontloader whirlpool
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Posted on Sep 28, 2010
livewire874
  • 618 Answers
SOURCE: I have a whirlpool frontload
Means the drain is taking too long . Most likely that the drain sump filter is blocked. Remove the lower front panel and unscrew the large white thumb screw attached to the pump. Water will come out so collect it then clean and replace.
Posted on Feb 27, 2011
What does Lc mean on my Whirlpool frontload washer?
lock
LoC or LC - Whirlpool Home Appliances
producthelp.whirlpool.com/Troubleshooting...Front_Load_Washers/.../LoC_or_LCApr 22, 2017 - If you try to push buttons, you may see the code "LoC" or "LC" ... For each second CONTROL LOCK is held down, the display will count ... You may still touch START to pause the cycle, or touch POWER to turn off the washer.
What does Lc mean on my Whirlpool front load washer Google Search
Jun 24, 2017 | Whirlpool Washing Machines
Light continuously blinking and washer does not start on whirlpool frontload washer
need more info model # or picture of data tags\
sound like door lock
Nov 25, 2016 | Whirlpool Washing Machines
I have a whirlpool frontload washer with model number WFW83005W00 and I have an error code F21 that flashes and then the washer stops working. What does this mean and what should I do?
Feb 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet front load washer is giving a F 11 error.
power failure--------unplug the unit for 5 minutes and see if it clears that code
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Jul 10, 2010 | Whirlpool GHW9100L Front Load Washer
Whirlpool doet washing machine
the door on any frontload whirlpool washer cannot be changed from side to side.only the dryer
Sep 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking from my whirlpool frontload washer
May 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
