Question about Kenwood Toys
Mykdc355u is powered up but no sound after battery wss unhooked and hooked back yp
2 Suggested Answers
  • 3 Answers
SOURCE: i just unhooked the battery and altenator to fix
Try to check the connection to the terminals for your battery and then you may have to jump start it to give it some juice and then let it run to charge back up since you completely unhooked it.
Posted on Mar 31, 2010
Testimonial: "Thanxs alot but actually i had forgotten to hook wire back to the alternater lol thanxs "
How do I replace the alternator?
Unhook battery, unbolt alternator, unhook alternator, hook back up new alternator, bolt in new alternator, hook battery back up.
Jun 30, 2015 | Cars & Trucks
Unhooked battery when hooked back up on the 2005 isuzu ascender vehicle idles low and dies when defrost or a/c is turned on
Common problem, will cost you about $8 and some time to fix yourself. Unhook the battery, remove the throttle body and clean it with sensor safe spray like Seafoam. When finished, hook battery back after clean throttle body is installed up and with all HVAC on off, driver around for a while so the computer relearns the newly cleaned tb.
Apr 17, 2014 | 2005 Isuzu Ascender
Unhook batteries and leave unhooked for at least 1 hour or overnight if possible. When you hook the batteries back up your climate control should have power.
Apr 10, 2012 | 2004 Ford Excursion
Dodge grand caravan 2000. car makes beeping sound. gauges jump. no power to starter.
Check the voltage on your battery to make sure its not weak if not unhook the battery neg side first then pos side for aout 2 or 3 mins then hook it back up this will reset the computer.
May 28, 2011 | 2000 Dodge Grand Caravan
I have a 2004 chevy trailblazer and whenever i turn on my a/c or heater it seems my engine losses power and wants to die.
I'm taking a wild guess that you recently unhooked or replaced your battery?
Your problem is a dirty throttle body, and if you do it yourself, can cost you about $5 for the can of throttle body cleaner. Unhook your battery again, and clean the throttle body and butterfly very well, must be shiny. Careful as the butterfly is very sharp. While removing the entire throttle body and cleaning it is best, leaving it bolted on will solve your problem too. When finished, hook your battery back up and drive around for 20 minutes or so with all accessories OFF. During this period, your computer will relearn a properly functioning throttle body.
Your computer learned some bad habits before the battery was unhooked the first time. When it was hooked back up, it thought the throttle body was clean and functioning properly. Cleaning it takes care of this problem. I do mine about once a year.
Mar 21, 2011 | 2004 Chevrolet TrailBlazer
I just unhooked the battery and altenator to fix the water pump now i have no power at all after hooking it back up
Mar 31, 2010 | 1996 GMC Sonoma
I have a power acoustik ps2-2600 it went out this morning the red light was on i checked the ground it was fine when i unhook the remote or the audio cables it turns off if i hook up the audio alone it...
unhook all the cables including power let sit for 15 minutes and than hook up the ground rca cables remote and than power in that order with the car off and the battery unhooked that hook the battery up the amp went to protect mode to keep it from blowing i hope your amp isnt like some that only the factory can reset most amps arent and reset themselves
Apr 20, 2009 | Car Audio & Video
Mp3 player won't cut on
when you plug a charger to your mp3 it plays, because you power from a charger, part of current goes to aset and make it play and also charge your battery.
when you unplug it from charger than battery does not manage to provide power to set.
get a meter and set at amps dc. and check your battery current out side.
i suspect that your battery is not holding charge.
Mar 28, 2009 | Samsung YP-K3 MP3 Player
Hello This is Bill MacLean See my earlier post on same problem of dead yp-f and also my reply to member wanting to replace battery. As you can see I had tried pretty well everything when I stumbled on a solution that worked for mine. Follow my directions in other post to remove Battery. Reassemble without
battery and hook up to usb/miniplug to computer.Unit is now powered only by computer usp and the battery is not interfering with
computer now recoginizing the unit. Reformat and reload the O/S
that came with the unit or download the firmware upgrader from Samsung. When you have access transfer some songs and unhook from compuer (remeber o use usb tray icon to stop unit as I think this is what crashed mine) Dissamble unit and replace battery and turn on. E-mail me if this works for yours of if it was a one time fluke with mine.
Bill MacLean
Jan 20, 2008 | Samsung Yepp YP-F1Z MP3 Player
No power to amp
Are you sure it has the full voltage going to both BATT and REM? sounds like the REM signal is weak.
Aug 23, 2007 | Pioneer GM-7200M Car Audio Amplifier
Toys Logo
Top Kenwood Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Kenwood Toy Expert? Answer questions, earn points and help others
