Question about Frigidaire FAS156N1A Air Conditioner
A/C UNIT FANS BLOWS NO COLD AIR COMPRESSOR KICKS ON THEN OFF
FRIGIDARE/ELECTROLUX A/C UNIT MODEL FAS155MJAI 5-6 YRS OLD HELP!!!!!!
KATHY
  • 2,237 Answers
Check fins in the condenser coils (the fins on the outside part) for obstructions or alot of bent fins. should be free and clear. but chances are the freon level is low. can be serviced, but may be cheaper to replace.
Posted on Jul 20, 2009
Auto/On set to ON. Fan runs.
Sounds like the thermostat, the way to verify is to unplug indoor unit, remove thermostat, take pic of wiring with phone or label the wires as to the terminals. Carefully twist the yellow,(Y) Red (R) and the green (G) together. Plug the furnace back in, if the unit operates normally, replace the thermostat. I am basing this on the fact that the blower speed is changing. This could also be an anomaly within the circuit board in the furnace section, not likely though as the outside unit (condenser) is not controlled n by the indoor board unless this is a heat pump. hope this helps. D
Jul 21, 2015 | Dometic Rooftop RV Air Conditioner
I have a dometic penguin ac rooftop unit. Model no. 630215.421. Fan blows Compressor does not kick on. Fan blows just no cold air. If put on auto and go up or down in temperature On the thermostat The fan...
Bad run capacitor or bad compressor. If you hear an occasional click from the compressor try a new run cap and then a hard start kit. Otherwise it's more economical to purchase a new unit.
Sep 25, 2013 | Dometic Rooftop RV Air Conditioner
Amana Prestige II air conditioner. The fan unit on the top of the ouside unit stopped spinning. I gave the fan a good push and it started spinning (and continues to spin) however the air now blowing into...
You need to replace the fan capacitor. Your compressor is probably in thermal overload you can cure this by turning off the disconnect your ac voltage and taking a cool water hose and running over the top of the compressor for a while. Then turn your disconnect back on and listen and feel of the big copper line to see if it gets cold and also listen to see if the compressor kicks on.
Aug 08, 2011 | Heating & Cooling
Hello, Our Eletrolux side by side is 4 yrs old and just today it quit pumping cold air. I cleaned the coils and noted the coil fan is operational and the compresor seems to be working but it is not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Electrolux EI26SS55GS Stainless Steel ...
Last night the frigidare AC with breaker in line
if the breaker reset and the display lights are lit its not the cord sorry to say could be compressor or fan motors.
May 06, 2010 | Maytag M7Y12F2A Air Conditioner
Compressor will not stay on.
very good possibility that it is low on freon. If indoor unit is blowing ambient air, not cooling is happening. If this is the case and you are sure the compressor is running and then shutting off, the compressor could be overheating and the internal overload is taking out the compressor. If outdoor fan runs and compressor runs, probably cause. If capacitor is bad, unit would most likely not run that long. While unit is running, feel the large line at the condensing unit. If it is cold, and stays cold, could be something else going on. If stays warm, most likely low on freon.
Apr 19, 2010 | Intertherm P3RA-030K Air Conditioner
Fridgidare/Electrolux top freezer not freezing fan stays on.
Look for ice buildup on the back wall of the freezer.
If ice is there you have a defrost parts issue.
If not, check the compressor to make sure it is running.
Mar 04, 2009 | Electrolux Refrigerators
No cold air
if unit is more than 5 yrs old dump it!!! most frigidaire models just dont last...that is why they are so cheap...get it???
Jun 09, 2008 | Frigidaire FAH085N1T Air Conditioner
Fan runs but no cool air on both freezer side and cold side
If you hear the compressor try to start then click off, you probably have a bad compressor or a bad relay. If it is less than 5 yrs old the compressor is still covered by warranty and will be replaced free of charge. The relay is only covered for a year. With it being a Maytag, I bet it is compressor. There have been a few models with control board problems that have caused this symptom, but that's not likely to be your problem.
Oct 06, 2007 | Maytag MSD2756GES Side by Side...
Frigidaire FAS156N1A Air Conditioner Logo
478 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
