Question about Magic Chef Refrigerators
Magic chef refrigerator will not defrost and ice maker will not work
  • 552 Answers
Verify that the doors are closing properly. If they are not you will have to manually defrost it to get it running right again. I doors are ok, think about finding a control board
Posted on Dec 09, 2016
  • Rhonda Mcdowell
    Rhonda Mcdowell Dec 09, 2016
    Thank you. Bought new refrig it was getting old
There are two sides to the Dual Water Control Valve. The ice maker side is still working but the water dispenser side is possibly defective. Sea Breeze Model Number?
Magic Chef Refrigerator Parts
Dec 15, 2013 | Magic Chef Refrigerators
The problem is with my magic chef top/bottom fridge/freezer. the freezer is working fine, but the refrigerator is freezing its contents.
Either defrost problem or clogged drain... Is there snowy frosty ice on back wall in fridge? If so, hire a professional. If not - you can take back wall off in the freezer and defrost the drain.
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - Refrigerator repair Houston, Katy, Spring and Woodlands, TX!
Aug 29, 2011 | Magic Chef CTB1521 Top Freezer...
I have Magic chef Model # CTB1923ARW. We find water all over the refrigerator section. This unit does not have Ice maker
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Lightly hook the other end over the glass rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Sep 27, 2010 | Magic Chef Refrigerators
The icemaker wont produce ice like it was when we first moved in
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
Sep 22, 2010 | Magic Chef CTB1821AR Top Freezer...
Ice maker does not work
magic chef mini fridge stops colding
mod#MCBR171W 1.7cu ft
Jun 30, 2010 | Whirlpool 17.6 cu. ft. Top-Freezer...
Ice build up in freezer...Auto Defrost not working Model unknown...smaller model...about 5 feet tall...2 feet wide...freezer on ice maker. Bought in 2002....noise during defrost quit about 2 months...
If it is a magic chef the model number will be on the back of the fridge and will have to order the exact defrost timer for this model. Only place to get will be from
Jan 31, 2010 | Roper Refrigerators
Refridgerator leaking water
You will have to check the defrost drain in the freezer by removing either the back or bottom of the freezer . Thaw ice if found in freezer and check to see if the drain hole is clear. Do not use anything to chip at the ice. Clear ice by warming it with warm water or possibly a hair dryer.
Jun 26, 2008 | Magic Chef CTF2125 Top Freezer...
Water squirting from ice maker
Does it do it all the time or only when the ice maker call for water... you may have a bad water valve 67006531 VALVE, DUAL WATER or a ice dam in you icemaker let me know
Aug 25, 2007 | Magic Chef (CSD2610KRW) Top Freezer...
Refrigerators Logo
47 people viewed this question
Top Magic Chef Refrigerators Experts
Level 1 Expert
John Tripp
John Tripp
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
