My Sukam falcom plus inverter charging light is blinking from hours what does that mean and it's not able to support even a fan when the mains go off.
  • 38 Answers
SOURCE: the charge light keeps blinking
There are many possible scenarios as to why this might be the case. The most logical would be that the battery has trained itself to not register a charge, this is a common problems with cell phone batteries due to incorrect charging procedures. Go ahead and power cycle the phone (take the battery out and let it sit overnight), if this does not resolve the issue, go and purchase another battery (make sure it works with your phone model) and try charging that one. hope this helps.
Posted on Oct 13, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: I have a Rheem Furance
You will need to reset the furnace by turning the power off to it. Then as the furnace tries to light, watch the LED for blinking. Hopefully it will give a code other than 1. Try checking the air filter for blockage, make sure all hoses are free of moisture and any drains are not blocked. Check the air intake and exhaust pipe for sags where water could block it.
The sequence of operation is this:
Thermostat calls for heat, the LED may blink telling you it registers the call. The inducer (exhaust) blower starts closing contacts in the pressure switch (small disc shaped thing), the igniter glows orange (seen thru a small window high up on furnace front), gas valve opens allowing main burner to light, flame travels to all other burners, flame rod senses flame within a few seconds and keeps gas on. Room air blower starts within 90 seconds.
Any deviation or delay in this sequence and it goes into lock-out.
Posted on Jan 22, 2011
kel1guy2002
  • 3740 Answers
SOURCE: I got an error of ER 05. What does that mean?
Hi and welcome to FixYa, I am Kelly.
E05: Flashing Fault LED: Flashing Alarm: Beeping = Output on inverter is shortcircuit
- Disconnect your output terminals and see if you still have the code. This is telling you there is an external short.
- If you still have the error with the output terminals disconnected start looking for internal inverter shorts to the output connector. (Chaffed wire / hot wire signs / internal + lead ground)
- If you have Circuit Breakers / fuses on your output side open all the CB/s or remove all fuses then turn on the CB's / install fuses one at a time until you note the Er05 error. Then troubleshoot the shorted circuit with an Ohm Meter.
Thanks for choosing FixYa,
Kelly
Posted on Mar 19, 2011
SOURCE: my sukam sinewave inverter its
Hi rutabairu,
We are extremely sorry if you have been inconvenienced through a Su-kam product. However, we pride ourselves on prompt and effective customer service. Please provide us with your name, contact number and address. Please give us the complaint number and date as well and we assure you to look into the matter at the earliest. Mail us at custserv@su-kam.com, We would do our best to resolve your grievance at the earliest.
Hoping to hear from you soon.
Sarita
Su-kam Executive
custserv@su-kam.com
Posted on Jul 26, 2011
SOURCE: my carrier split type non-inverter aircon always blinking
I got the same problem in Samsung aircon. The unit I purchsed died slowly. After that Samsung replaced it with the one have the same problem. They are swearing that the green light blinking problem as a normal function and refusing to fix. Their user manual says it is a problem. I think the affected consumers should join hands to take legal action against this scam.
Posted on Dec 20, 2011
How do i fix a blinking screen
What do you mean by this blinking screen? The light at the screen ON and OFF continuously? If so, it is due to its back-light problem. . Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jul 27, 2016 | Televison & Video
My Sukam Inverter is not working, even if the power is on, and its continuously beeping! so how can I direct the power, and so that the switches connected with inverter also works fine?
The first thing I would check is to make sure that the polarity is correct... IE: That you have red connected to positive and black to negative, assuming you're connecting it to a battery that is.
Many inverters will actually self-destruct if the polarity is backwards... But some of the better ones will beep instead.
May 25, 2016 | Inverter Electronics - Others
My sukam 850 having issues ,does not take even 5 watt load as soon as given load it start beeping showing battery low ?
Are you powering this from a vehicle? If so have you tried running the engine to see if that makes a difference?
Oct 16, 2014 | Electronics - Others
Sukam 800VA inverter continuously beeping with 3 lights blinking. What could be wrong?
check batry voltage or 2nd problem in realay and capicitors or
3rd ic before that disconnect output line
May 05, 2014 | Computers & Internet
I have a Rheem Furance that has turned off. Just a few hours ago the main fan turned off. The Furnace doesnm't light even the draft fan does turn on and then the main fan blower motor turns on. I can hear...
Jan 22, 2011 | Heating & Cooling
Nothing comes on picture blank
Ok
A few things to try
1.) Check the laptop on an external monitor, do you get a picture
2.) Is there power to the laptop from the battery and the charger? Try to see if the charger indicator lamp is blinking green rather than steady green
3.) Can you hear hard drive / fan noises and are there any lights on the laptop?
If the charger is blinking, indicates that power is not making the circuit, check tightness of charging port, if tight, assume fault on motherboard / blown main fuse
If picture on external monitor and not on laptop, assume backlight on screen dead or possibly the inverter
If no noises from HDD or Fan and No lights on laptop, then fault with motherboard
If you do get fan noises etc, but get BLINKING lights on laptop, assume possible fault with graphics chip, repost with details of blinking lights / colour and specific model of laptop
Jan 12, 2011 | Samsung Computers & Internet
My SUKAM Shiny 400va sinewave home ups is powerd half when utility power off. overload light glowing. But this ups running perfectly at the same load before.
There might be a problem in the battery acid concentration. Take the battery to a battery recharging shop. The specific gravity of the battery has to be 1.22-1.25 for a fully charged battery.(if your battery is lead acid type) Handling lead acid battery(or any other battery) without proper knowledge and supervision is very dangerous.Be cautious.
Dec 03, 2010 | Electronics - Others
14.1VDC going into inverter but no ACV coming out. Red fault light is on. Disconnected fan motor and checked with meter and shows open even on high ohm scale.Are Xantrex fan motors known to go bad?If the...
If you don't have enough current to run the inverter, even at 14.1 v, it will go into protection. Make sure the wiring is heavy enough to provide the current needed to run the inverter. There should be a label on the fan saying what vosges it needs to run. Try powering up the fan outside the inverter.
Nov 24, 2017 | Xantrex Technology Xantrex Xpower 1750...
47LC7DF, Green light comes on, blinks with remote
When you say that you have replaced the main board i assume you mean the power board? If the green light comes on and blinks when the remote is touched it was never a issue with the mainboard, if it was you wouldnt have any signs of power. In most lcd tvs you have the main board which is normally the power board, the signal board which recieves signal and hold settings of the tv which can be all in one, the other is the inverter board, which scrambles the signal to what you see on the screen, and next we have the back light which lights the screen so you can see the picture, sometimes in certain models as i have learned you can have power/inverter boards which means the inverter and power are all on the same board, in your case i pressume the inverter board is seperate board and probably the issue you need to address, you can buy these online probably the same place you got your new mainboard from. Hope this helps pls post bach what happens.
Feb 01, 2010 | LG 47LC7DF 47 in. LCD HDTV
Dead appearing ups/inverter
keep on your main switch. off all the lights fan and other electrical items, let that inverter get charge first
Jun 18, 2009 | APC Back-UPS CS 500VA UPS System
Televison & Video Logo
145 people viewed this question
Top Televison & Video Experts
