Question about Cell Phones
How can I recharge using youcher - Cell Phones
Can I use rechargeable batteries?
didnt specify device --rechargeable batteries are a power source like regular batteries but you can recharge them when they get low and not change them out and buy new --so unless their is a special warning on the product specifically stating no rechargeable batteries you can use them
Aug 30, 2016 | Audio Players & Recorders
I charged my KX-TGA652, it keeps saying use rechargeable battery. Does not seem to hold charge
It does take rechargeable batteries. Remove the back and change batteries for Ni-cad or similar rechargeable batteries. Trying to recharge normal batteries is dangerous. Any rechargeable make of battery will normally work and they recharge when phone is in cradle
Feb 21, 2015 | Panasonic KX-TGA652B Cordless Phone 2 Pack
Kobo not accepting a charge
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
Jul 28, 2014 | Kobo Arc
My zpad won't hold a charge
Lithium ION batteries are useusally rechargeable. The use mode for these batteries is that there
used up.
Jun 05, 2014 | Tablets & eReaders
Can i buy a charger for my vivicam8690 instead of using batteries ?
The 8690 uses AAA batteries. You're perfectly free to use rechargeable batteries. However, since the camera does not include recharging circuitry, you'll have to recharge the batteries using a separate charger. Any department or electronics store should be able to provide you with rechargeable batteries and a charger.
Apr 30, 2011 | Vivitar Cameras
Can i charge the camera away from the docking station ?
Yes, assuming you're using rechargeable batteries. If you're using rechargeable AA batteries, they can be recharged using any standard AA charger. If you're using the Kodak Rechargeable Battery Pack, it can be recharged using any of several Kodak chargers.
http://store.kodak.com/store/ekconsus/en_US/AddItemRefID/pageType.product/externalRefID.EKN031207#accessories
Jul 16, 2010 | Kodak EasyShare C533 Digital Camera
Rechargeable batterie won't work in my Camera.
Not sure what camera you have, but some cameras require a very steady power supply voltage. Also not sure how old your rechargeable batteries are either, but batteries (alkaline and rechargeable decay over time. With the rechargeable ones, the more you use it, the less it can charge to full capacity over time. For example, if your rechargeable battery is supposed to charge up to 1.5V, over a period of a year with constant recharges, you can test with a volt meter and see that it never really goes back up to 1.5V, but more like 1.48V, 1.45V or maybe even 1.4V.
Depending on the camera or other item you use rechargeable batteries on, it can adapt to low voltages with special circuitry inside (but only to a certain limit, when a battery is old, it is old).
You can try buying a new set of rechargeable batteries and use it few times and see if this fixes the issue. If not, your camera may be faulty and just draining the battery (not too likely, but it happens).
Check out this site for some useful info.
http://www.steves-digicams.com/nimh_batteries.html
Apr 30, 2008 | Canon PowerShot S5 IS Digital Camera
Using rechargable battery with new camera for the first time
If you are using a rechargeable battery, yes you should fully charge it before you use the camera for the first time. Rechargeable batteries are normally supplied without a charge from the factory, but not always. Fully charged batteries may be in storage for a long time before the camera is purchased and unlike modern dry cells, rechargables will not hold a charge for years.
Fully charge your battery, then run it until it has completely exhausted. If you plan to put the camera in storage at some point in the future, always recharge the battery every couple of months or so, to keep it in good condition.
Of course make sure the supplied battery is in fact rechargeable and not a lithium which should not be recharged.
If you found this info useful, please give me a thumbs up...
Mar 11, 2008 | Kodak Easyshare M753 Digital Camera
Battery life is to short!!!!!
Its the camera, I have the same one and it eats batteries like nothing. I suggest rechargables.
Feb 17, 2008 | Fuji FinePix A700 Digital Camera
Charged and ready to shoot
Why do you say they've expired? Rechargeables last for 1000 cycles, which should give most people several years use. If they're corroded, go to Radio Shack or Best Buy for replacements. Be sure to charge AT LEAST 14 hours to get the most out of the batteries.
Dec 05, 2006 | Fuji FinePix E550 Digital Camera
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
