Question about KitchenAid Refrigerators
Kitchenaid refrigerator model KBFS20ETSS01. New H2O heater installed. Ice maker has not worked since. Checked for stuck ice. Has an arm mechanism. Do not hear tray filling. Could water line clogged?
  • KitchenAid Master
  • 4,655 Answers
The water line could have ice blocking its path to the ice maker but not as likely as a defective dual water control valve.
Kitchenaid refrigerator model KBFS20ETSS01.  New H - 26382968-2kjj5caiihmmmwocsurhrifz-2-0.jpg
Try replacing the dual water control valve first=> Water Inlet Valve WP67006531
Posted on Dec 03, 2016
Buzzing sound Kitchen Aid fridge Model KBLA20EMSS
It may be the arm in the ice maker is down. Even though the ice maker does not have the water hooked up if the arm above the ice bin is down it will still cycle the ice maker try lifting up the arm it should stay up this signals the ice maker that the bin is full and should shut off the ice maker. Hope this helps.
Dec 31, 2013 | KitchenAid KSCS25FKSS Side by Side...
This sometimes happens with my KitchenAid ice maker.
Usually there is a piece of ice stuck on the side where the sensor is that causes the ice to drop. I usually carefully chip away at any ice that is stuck. Once the stuck ice is removed, the ice maker works fine.
Sep 18, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
KitchenAid Superba KSRG25FK Side by Side-where is the arm of the ice maker?
Hello ksraine,
I understand that you are looking for the arm on your ice maker. I believe you are talking about the ice makers that have the little wire arm that goes up and down as it makes ice to know when to stop making ice. The ice maker that you currently have installed on you side-by-side does not have the wire arm. Here is a picture of a complete ice maker that is factory installed on your unit -justinbur167.jpg Thank you for choosing
Apr 25, 2011 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker not making ice
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
Jul 13, 2010 | KitchenAid KTLA19EMSS Stainless Steel Top...
I've got the LFX25960ST model. The icemaker
its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
Jul 24, 2009 | LG LFX25960 Bottom Freezer French Door...
Ice maker
The is a small heater in the boottom of your ice maker that is most likely not working. The heater comes on when the ice reaches a frozen state to allow the ice to melt just enough that the rotating arm can push the cubes out and into the tray.
Unfortunately, it will most likely cost more to have a technician fix the existing ice maker than it would to just have anew one installed.
I would opt for the new ice maker.
Jun 04, 2008 | Amana SXD524VW Side by Side Refrigerator
Ice maker will not push out ice cubes once frozer
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
The heater, or evaporator fan and heating system must be checked, and fan, or solenoid, or element must be replaced.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
May 12, 2008 | Whirlpool ED2FHEXN Side by Side...
Kitchenaid KSCS250SS not producing ice
From my experience, a frozen water line coming into the icemaker indicates a bad water valve/solenoid.
The solenoid is usually located at the bottom of the rear of the unit.
The icemaker arm could be a culprit if it was detached somehow, and was really in the stop mode. But, that would not cause the ice build up in the water tube.
Jan 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Frozen ejector arm
sounds more like the heater in the ice maker is bad. The cycles of the ice maker are: 1. water comes in to fill ice maker. 2. water freezes in ice maker making. 3. heater comes on to help ice release. 4. motor comes on to eject the ice and start all over again. if the heater doesn't come on the ice will not eject. replacing the icemaker is typically what needs to be done in this case.
May 02, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
57 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
