Question about Kitchen Ranges
Sunrise x60-10br (or x60-10rr), natural gas, stove top burners light, then go out (fade out) after five to sixty minutes. Not sure if pilot lights were all lit or if burner(s) were match lit before use. Why & is the regulator an issue??
  • 213 Answers
SOURCE: ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Posted on Nov 21, 2007
SOURCE: stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Posted on Feb 08, 2008
rickzilla
  • 706 Answers
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Posted on Sep 01, 2008
buffalonyman
  • 1865 Answers
SOURCE: You have to light burners on stovetop with a match all the time.
The pilots for the range top are beneath the top of the range top. YOu will see them if they are there. YOu stove may use electronic ignition and you can hear the sparking when you turn the knob to the "light" position.
If it is electronic ignition, make sure the stove is plugged into an operating outlet
Posted on Apr 15, 2009
Maytag317
  • 1136 Answers
SOURCE: pilot light keeps going out on one side of my
HI, Try using a needle to clean out the pilot orfice. Most models have an adjustment for the pilot light. It would be located near the manifold under the top panel.
I hope this helps you. Please let me knwo if I can assist you further.
Vic
Posted on Jun 05, 2009
Right, front flat burner does not light and barely heats. My Hotpoint stove is five years old and gets very little use. What's wrong? Can I fix it? Can you help?
Hello and Welcome to FixYa!
Please provide us with the model details of your unit and What exactly, you are facing. Is the burner properly getting the supply. And is it partially lighting or didn't lighting at all. Is the unit repaired ever since the problem started? Some details of the trouble, you are facing, will help suggesting more precise solutions to the problem,
Feel free to Ask,
Concerned.
Jul 15, 2011 | Hotpoint Kitchen Ranges
I smell gas and my burners wont light - is there a pilot light in these ranges?
The best way to find out if if your stove has a pilot light, is to lift the top panel of the range . The pilot will usually be located between the burners. Typically you will have two pilots. One for the left and one for the right. The pilot light will ignite with a match without having to turn the burner knobs to the "on" position. Good luck
May 20, 2010 | GE Spectra JGBP35 Gas Kitchen Range
For the GE XL44 model, where would i find the pilot light? the stove is not working
There is not pilot light on the stove top since the burner is activated by a spark generate by high voltage to a small ceramic disk with a wire protruding from it by the burner.
You have the have AC Power to the stove and you should hear a clicking when you slightly turn on the burner. Once the burner is on fire then turn the burner control to the desired temperature. If the burner will not light after 4 seconds of clicking sounds turn the burner control off and make sure the round gas diffuser on top of the burner is correctly seated on the burner. It should lock in place and is removable for daily cleaning of the stove. Now try the burner control again in the light position for no more than four seconds to see if it lights.
Do you smell gas? Do you hear clicking when slightly turning the burner knob? If yes to both the stove is working and the top of the burner is not seated correctly. If no on either or both you may have a stove, electrical or gas problem.
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Holiday Stove Pilot Light won't stay lit.
Wow this problem sounds exactly like my landlords problem only he is just now saying he is learning of the problem. You even have the age of the stove correct.
Jun 16, 2009 | Cooktops
My ventless propane heating stove shuts off by itself
I have a Rinnai Ventless heater hooked up to a 20 lb propane cly with a Moble home type regulator in line, and when I light it the pilot light lights and stays on. When I turn it to the heat position the pilot light go's out and that it!
Jan 28, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Delay in oven burner to light after pilot is lit.
Usually delayed lighting on a standing pilot system is caused by a gas pathway that is dirty from spilled food or grease. If you can remove the burner assembly and clean it that will correct the problem. If there is a removable plate above it then you can remove that and get access instead of removing it. Pilot ignitions work by creating a column of gas between the pilot and the burner that is established when the burner is turned on kind of like a fuse. A small tube my be used to establish the column of gas between burner and pilot and it may get blocked with food that overflows. Sometimes the pilot is just located right next to the burner and may get partially blocked or the orifice in the burner next to the pilot may be blocked. Cleaning all this helps. Be very careful with gas. Work in a well ventilated area. Turn on gas very briefly to run an ignition test. Turn off the gas and vent it off if it fails to light in about 5 seconds. Unburned propane drops to the floor and collects. Natural gas rises. Be aware of this when you ventilate.
Dec 23, 2008 | Magic Chef Ovens
Can't get burners lit.
1. make sure the gas is turned on.
2. Make sure unit is pluged in.
3 make sure all burner and burner caps are aligned.
If you hear a spark and you small gas it should light.
Make sure the burner heads are not clogged.
If this top has pilot lights make sure the pilots are lit
Nov 23, 2008 | Cooktops
Ge spectra gas stove top not lighting
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 Gas Stove
Hi I have a GE X44 gas stove. The 4 top burners work just fine, but the oven no longer turns on. I don't see the blue flame inside the oven. Is it safe to relight the pilot light?????
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
42 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
