Question about Whirlpool Kitchen Ranges
My Whirlpool electric range Model GR448LXPB electronic oven control panel doesn't light up, not even the clock, the oven light doesn't come on when the door is opened, but burners come on.
    Sergeant:
  • Whirlpool Expert
  • 448 Answers
Look for unplugged wire on control board or replace main control board
  • 1073 Answers
SOURCE: oven burnout
replace the oven control
Posted on Apr 25, 2008
SOURCE: Inglis electric freestanding range model #IRE3230- Oven no longer working
If the oven and the electric panel no longer work, this is an electronic problem. The burners and the oven light will not be effected, nor will the fuses. The electronics card will need to be replaced by an appliance technician.
Posted on Nov 25, 2008
SOURCE: whirlpool electric range won't work
We read on another site that sometimes an electical surge messes something up and that if you unplug the range for a few minutes it will reset. So we unplugged our range and when we plugged it in again it worked fine.
Posted on Mar 24, 2009
SOURCE: F2 Error on Whirlpool Dual Fuel Range
I was baking and the stove suddenly changed to Maxi Broil and then to ERR F2EO Stuck Key. I cannot seem to change it by start or off or even turning the unit off and then back on. Any suggestions? Thanks.
Posted on May 29, 2009
  • 10865 Answers
SOURCE: No electrical power to ovens and control panel.
It appears that you have lost one half of your power. That is you no longer have 220 volts but do have 110, enouch to power the electronic ignition. I would check the circuit breaker first to see if it is sending power on both hot wires or just one.
Posted on Jul 17, 2009
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
I have a whirlpool gold electric range,accubake model gy397lxus.oven not heating and range top not heating,digital control blank unless i rotate a heat selector for range top to on,the light indicators for...
I have look up your unit, I found the thermostat located inside the back panel the would only take out the function to your elements in your oven.
High limit thermostat
This link shows its location and price of the part. Now for you display issue, before continuing, push and hold the clock button on the panel until you hear a beep, if the unit is set to Sabbath mode this will clear that. If not I will continue, by the way missing a version number to model number, like a number (0 or 02). Have you have a power outage recently? I am not locating any line fuses the would take the display out. If the clock doesn't reset then I would think about checking warranty or can your dealer to inquire on your warranty.
Control Unit
Good Luck and I hope this helps.
Aug 17, 2011 | Whirlpool GY397LXUS Stainless Steel...
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
My oven is reading f0
F O CODE / DEPENDING ON WHAT WHIRLPOOL MODEL THE PROBLEM CAN CHANGE . F O analog to digital failure/ disconnect for 30 sec .. if display reappears . replace the control .. other models it states a failed transistor . also replace the electronic rane control/clock.. . hope this helped mm
Jul 14, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
GE XL44 Gas Range JGBC15GER2. Can't see clock on stove; very dim. Do I need to replace the clock/timer?
yes it is called a electronic oven control go to ap wagner.com and enter the model number and you can get priceing
Oct 18, 2009 | Whirlpool GR460 Electric Kitchen Range
May 11, 2009 | Whirlpool RF315 Dual Fuel (Electric and...
Whirlpool electric range won't work
Mar 24, 2009 | Whirlpool RF368 Electric Kitchen Range
My kenmore electronic stove is having a beep with code F1 on the
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oct 24, 2008 | Kitchen Ranges
Frigidaire electric range
is there voltage going to the erc (electronic range control)?
Feb 09, 2008 | Kitchen Ranges
Kitchen Ranges Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
