Uho15sx not receiving. Bars on screen stay full.
Black bar on the top and bottom during watching the tv
If you are watching television and you see black lines on the left and right sides of the screen, check to see if you are watching an HD broadcast or a standard definition broadcast. You can do this by bringing up the TV guide menu on your remote. If the show is in HD, it should take up the full screen. However, if it is not HD, bars will be present on the left and right of the screen. That is because standard definition programing is in 4x3, which will not take up the entire screen.
If the picture you are watching not only has black bars on the sides, but on the tops and bottoms of the screen as well, your "Zoom" mode has somehow gotten off-kilter. Press the "Zoom" button on the remote until the image appears correct. If this does not work, power down the television, wait a few moments, and power the TV back on. The image should be correct now.
If the image on the screen looks stretched or squished, this is because your HD cable receiver is not set up properly for your widescreen television. Press the "Menu" button on the receiver
May 06, 2011 | Samsung 50 in. Plasma TV
How do i get a full picture on my secnium hd tv?
To get the picture full screen come to screen aspect ratio settings.
The Screen Format feature allows you to change how the image of a 4:3 picture
is displayed on your 16:9 screen. The options are Normal, Zoom or Stretch. If
your TV receives an image with a 4:3 aspect ratio, the image can be displayed in
one of three ways:
Normal The image of a 4:3 video signal is centered with black bars on the
right and left sides of the screen
To get ito this setting mode
Enter the main menu and go to preferences select the screen format; option-2; and change the settings to get a full picture.
Feb 03, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Gray bars while full screen viewing my Broksonic CCVG-4500 42 in
hi, i have a broksonic model ccv-4500 , these is a monitor or tv because i cant founder the digital cable imput. thanks.
Apr 25, 2010 | Broksonic CCVG4200 42 in. Plasma TV
Picture ratio
Programs that are recorded in 16:9 format appear full screen on a 16:9 TV. A program recorded in a standard 4:3 format will either be stretched to fit the screen or have side bars to fill the screen area. In the case of HD channels, the black side bars are part of the picture which is being broadcasted.
Apr 22, 2010 | LG 32LG30 32 in. LCD HDTV
Gray bars
Hi, you can removed this bar by using the picture size function in you menu this is du to the signal
you receive in your tv;if your tv got a full hd signal
choose the 16:9 picture format the bar will disapear
if you dont have 16:9 signal that normal but you can choose full screen mode it should gone , that is 4:3
format extend it to ful screen mode.
good luck and have a nice day.
Mar 13, 2010 | Televison & Video
Screen display mode
Because the broadcaster is giving you the bars at top and bottom there is nothing you can do except use the different aspect or screen formats that are on your TV. Please take a few moments to rate my answer. Thanks....
Nov 20, 2009 | Televison & Video
My Casio Gw-300 is not receiving the satelite signal to receive daylight savings time. The display is not showing the satelite dish or any bars in the receiving indicator
I'm having the same problem. It's been working fine for about 4 years and now there are no bars or the picture of the satellite. There is a little "C" or "[" next to where it should be though. Maybe that is some sort of error message? I left it in my window for three days straight to get full days of sunlight and the battery is full but still no signal. Did something happen to the atomic signal carriers? Or is my watch finally dead?
Nov 02, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
