I have a 60lg tv pictureifnmeasimg up how can 8 fix it
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Did you mean: "I have a 60-inch LG TV picture is messing up. How can I fix it?"
Posted on Dec 03, 2016
Turned on TV today and get has grainy screen. Sound works. TV is about 8-9 years old. Can this be fixed or give up and get new one
a repair shop can tell you if it can be fixed and at what cost . then you can decide fix or toss
Nov 22, 2015 | Televison & Video
TV not going on. power light bliking 8 times.
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 06, 2012 | Sony KP-51WS510 51" Rear Projection...
I have a 8 years old apex tv. while watching tv the picture went out but it still has sound. i can't see the channel numbers or volue bar is it worth fixing
I WOULD SAY NO ! THE PICTURE TUBE IS PROBABLY AS MUCH AS THE TV IS WORTH. i had a very nice sony trinatron tv. the picture tube whent on it at about 5 years so I CALLED FOR REPAIR AND THE PICTURE TUBE WAS 2-300 DOLLARS. good-day !
Jan 20, 2012 | Apex Digital Televison & Video
I have several horizontal lines at the top 4" or so of my TV. The lines are approx. 1/4" thick and flicker.
If you get this result from multiple inputs (IE HDMI, composite etc) it is likely a defect/failure in the screen. This is not something you will likely be able to fix yourself.
I recommend contacting Sony on how to proceed on getting it fixed. If it is still under warranty they will likely send a tech to look at it or may even send you a replacement.
Below is the number and hours of operation for Sony TV Support line.
Priority Service: 239-768-7547
Hours:
  • Mon-Fri 8:00am-12:00am (Midnight) ET
  • Sat-Sun 9:00am-8:00pm ET
Feb 28, 2011 | Sony Bravia Z KDL40Z4100 TV
My Sony WEGA KDE50XBR950 began to display the following error message: Fan Problem - Shutting Down, and then automatically shut down after a minute or 2. Is this a standard message when the fan stops...
I had this same problem last wk. It is either the heat sensor or the fan problem. My was the heat sensor and I took it to a local TV shop and they replace it for $250. For such a good TV, it is worth the $250 to fix vs. trying to buy a new one of such quality for $1000, that may not even have such as good pictures.
I bought a new 60LG 1 month ago for $2200 and it is no where as goo as this old 720P Sony in picture quality.
One question, do you still have the original TV stand that come with this TV? If you are not using it, I would like to buy it from you. I mounted the TV originally, but now want to take it off the wall and use a TV stand in another room. Please email me at ib1kid@yahoo.com
Dec 31, 2010 | Sony WEGA KDE-50XBR950 50 in. Plasma HDTV
Hello. I just connected my polaroid 32 in LCD HDTV to my computer and there is no sound? I played around with the audio settings on my computer but no luck. How can I fix that? thanks!
You'll need to run an audio cable from your computer's sound card to the TV as well. Depending on your TV's inputs, you will have to get a cable that has a 1/8" stereo plug on one end and either RCA male or 1/8" stereo plug on the other (depends on whether your TV has a 1/8" audio input for the computer connection or RCA inputs.
Feb 04, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Can't get PBS in Nashville Tennessee which is channel 8 in the
This is a common antenna issue.  Check online for information.  There is a website dedicated to this issue.
May 19, 2009 | Televison & Video
Thin white horizontal lines across top of TV
replace vertical out put ic and related capacitors
please refer to a qualified tv personal to check tv
Jan 17, 2009 | Televison & Video
Red fade, red flashes screen turns off followed by tv turning off.
Replace HV block when self-diagnostic LED blinks 8 times =
Sony part # 8-598-955-32....if that doesn't cure it, the red CRT
would be next..................T.
Dec 21, 2007 | Sony KP-51WS500 51" Rear Projection...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
