My tv has been powered off for a month and finally I went to power it on and ittyrns on but the screen is white. What is going on?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Need to know your TV manufacturer and model number. You, having that info can get detailed instructions a user manual in a readable PDF format. To do the search, and with the carefully typed information, type it in to a search engine window with the quotes, e.g., "Manufacturer Model Number" "user manual"
Of course, replace your own TV's manufacturer in place of the word there - same with model number.
Maybe that will get you the help you need.
If no physical damaged occurred, i.e., lightning, surges to damage circuits, then a reset may do the job.
Good luck.
A
Posted on Dec 03, 2016
5 Suggested Answers
jrweighing
  • 183 Answers
SOURCE: I have 40? LCD Samsung flat screen TV model:
check power supply capacitors..i repair these every day and the power supply is prone to faulty capacitors..the capacitors should have flat tops and if they are bulging or leaking brown fluid, replace
Posted on Oct 17, 2009
  • 18 Answers
SOURCE: Sharp 26'' LCD HD screen went white, sound is fine
Go ahead and try unplugging the video (yellow) cable and plugging it back in.
If that doesnt work, do you have any spare video cables try those.
Then unplug your tv for 2 mins and hope for the best.
GOOD LUCK.
CNBY
Posted on Jun 03, 2010
SuperTech-11
  • 1591 Answers
SOURCE: one day my tv was
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
I get mine at www.digikey.com online for less than a buck a piece plus shipping, and they usually arrive next business day.
Posted on Jul 13, 2011
  • 333 Answers
SOURCE: hi i have no power going to my tv when its plugged into to power
Look for a reset button
Posted on Feb 23, 2013
GOOD LUCK.
CNBY
Jun 03, 2010 | Televison & Video
After 14 months of having my TH-p42pz80u, the power went off, and I had a flashing red power light. TV wouldn't come back on, so I unplugged the power cord from the back of the set, and plugged back in....
2 possibilities... First, your lower-left buffer is bad. Second, your panel is bad. First possibility is the most desirable. You should contact Panasonic directly for service information on this TV. They are having some panel problems on a few models... they may have issued a warranty extension for this model. Panasonic likes to have their hands in the repair process anyway. I highly doubt you could just order a part for this model without using an authorized servicer. Best wishes.
Apr 17, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Vizio screen went white
Im sorry but did you figure this out yet. my tv just did this today too. it broke now.
Jan 28, 2010 | Televison & Video
Philips Magnavox Projection T.V
you need to replace a cople of the opticoupers most likely, if you want to repair this and save yourself a lot of dough, contact me at techman32k-at-yahoo dot com
Larry Dillon
Aug 06, 2009 | Televison & Video
I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
Jun 17, 2009 | Vizio L32 32 in. LCD HDTV
LG 22" LCD Screen went white
same things happened to me...did you solve this?
Jun 08, 2009 | LG 42LC2D 42 in. LCD HDTV
Olevia LT26HVE Power issues?
Finally recieved an email from syntax olevia customer support after 1 month. a standard desktop computer power cord is all you need for your Olevia LT26HVE flat screen. We lost ours in a move and FINALLY have it up and running again...for only 9 bucks at RadioShack!
Dec 07, 2008 | Syntax LT26HVE 26 in. HD-Ready LCD...
Horizontal line problem
1. solder the vertical ic first. otherwise replaced the vertical ic.
2. solder the yoke wires.
3. replaced the vertical ic supply capacitor.
Jun 26, 2008 | Quasar SP-2723 27" TV
Pink screen
When the "pink screen" happens on my Polaroid FLM-1911 TV, I unplug the power cord from the back of the unit, wait 30 seconds, and replug it. This fixes the problem.
Oct 23, 2007 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
