Affinity washer sensor light is unlit. Cycle starts by discharging H20, then stops. Tried power down, then power up. No change.
  • yadayada
    yadayada Dec 03, 2016
    What do you mean by "discharging H20"??
SOURCE: H20 Reciver power up problems
same problem on two different h20 receivers - called directv and explained the situation each time. since these are leased receivers, new ones on the way.
Posted on Sep 21, 2008
futureloginn
  • 734 Answers
SOURCE: Fridgidare Affinity washer door won't open after wash cycle
Try the following site for full information on unlocking Dryer -------
http://www.freepatentsonline.com/4908957.html
Posted on Dec 04, 2008
vanni7
  • 163 Answers
SOURCE: frigidaire affinity dryer has power but won't start up the cycle
Hi!!! you have a problem with the thermal fuze change it and you will be okay..
Posted on Jan 21, 2009
onthejob5130
  • 640 Answers
SOURCE: My front load washer affinity pauses 3 or 4 times during a cycle
the unit is waiting for something,,,like water ,,,or a slow drain..you must see where the unit is ,in the cycles,,and make sure that action the unit is trying to do is able to do...onthejob
Posted on Feb 01, 2009
SOURCE: My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
Posted on Sep 11, 2010
Affinity top loader
Good Afternoon Friend,
I understand that your Affinity washer starts to fill with water and stops, while the counter continues counting down. I also see that nothing is happening while this is going on. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire Washing Machines
Why some on my cycles wont work nor my light s will light up on my affinity to load washer
I understand that some of the cycles will not work on your Frigidaire Affinity washer, model# ATF7000E. I also see that the lights won't light up either. I suggest giving your appliance a hard reset, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. After restoring power start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire Affinity ATF7000E Front Load...
Door lock light won't come on
I understand that the "Door Lock" light is not coming on, on your Frigidaire Affinity washer, model# ATF7000E. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer light status has changed successfully. Hope this is helpful.
-Best regards-
WP
May 31, 2014 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire affinity front load washer buzzes and will not cycle what wouldcause that?
Good Morning Friend,
I see that your Frigidaire Affinity washer, model# ATF7000E, is buzzing and will not cycle. Some possible causes of this could be:
-Your washer is overloaded with clothes. Try taking some clothes out and restarting.
-There could be an article of clothing that might have slipped in between the gasket and the drum that might be stopping the drum from spinning. Check to see if there are any clothes that might be missing and possibly stuck between the drum and gasket.
If you have tried the above solutions and are still having trouble, I suggest giving your washer a hard reset. You will do this by either unplugging it or shutting the power off at your home's circuit breaker for 2-3 minutes. After the time has passed, restore power and start a cycle. If your appliance is still buzzing and not spinning, I suggest that you contact your local authorized technician for further assistance. They will be able to diagnose your washer and determine the cause of the buzzing and why it is not spinning. Hope this is helpful.
-Best Regards-
WP
May 05, 2014 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire Affinity is brand new. Just did our first load of laundry and mid cycle it stopped and the PAU is lighting up intermittent with the time left. I have tried everything I can think of and it...
Hello Mary Fortner - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Dec 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity Washer making clicking sounds after power outage.
Sounds like either the control board or the timer is faulty at this point. Contact a professional so they can diagnose the unit fully and repair where needed.
Jul 28, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have the frigidare affinity front loader washer and just started it up. It stopped about 5 mins into the cycle and the indicator light says dr. I tried to shut the door but that didn't work. So I...
You need to replace the door lock mechansim. Fairly easy to do yourself, just pull the spring strap off the rubber door gasket and remove 2 screws holding door lock. Install new door lock and re-install door gasket and spring strap, and WALLA! she works:)
Nov 28, 2010 | Frigidaire Affinity ATF7000E Front Load...
I have Frigidaire Affinity washer that beeps and blinks "dr"
Hi. the "dr" represents a faulty door mechanism. you will need to replace this device asap.
Click here to purchase your new door mech.
May 24, 2009 | Frigidaire ATF6000ES Front Load Washer
Pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
Apr 22, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
