Question about Camping, Backpacking & Hiking
Falcon Tactical 8MTR-T single battery. How long should it take to re-charge the battery. There was no manual with the flashlight.
    Top Expert:
  • 79,077 Answers
About 3 hours
Posted on Dec 03, 2016
Replace batteries on flashlight
Maureen, Coleman Graphite Flashlight replace batteries. Remove bottom cap, it will be on tight, if you do not have good strength in your hands use a pair of pliers or channel locks. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to change the batteries in Mag Lite
Aug 26, 2016 | Coleman Graphite Flashlight
My dishwasher continued to run all night found that it has not drained unable to pause can only turn off with power button however when it press the power on it does the same thing
pressure alterations Lightstrike 360 Tactical Flashlight . This allows you to use devices such as laser sights and Lightstrike 360 Tactical Flashlight flashlights utilizing the Tiberius 9 paintball device. If you want to, you remove the vertical grip completely.
http://topmusclemighty.com/lightstrike-360-tactical-flashlight/
Feb 11, 2016 | Dishwashers
Our flashlight stop working even with a brand new battery
The bulb may be blown. If the bulb is ok then you may have a broken wire, corroded connections or a bad switch.
Jul 20, 2014 | Eveready 6V Super Heavy Duty Lantern...
Light stopped working
I gather that you have checked the bulb with a meter to see if it is bad. If it is xenon high intensity then they have a short lifespan because of the heat. If that is not the problem check the batteries with a meter to see if they are good and if they are, replace the switch.
Apr 14, 2014 | Insight Technology M3 Tactical Illuminator...
I bought 2 norlite 8-nswat cree xr-e tactical lights. One never worked and the other one works occasionally. I tried switching parts around but could never get the silver one to work. Now neither one...
This product comes with a lifetime warranty. If you contact the Hoffco Brands Customer Service team they will gladly replace both for free!
http://www.hoffcobrands.com/contact_us.asp
Jan 08, 2013 | Hoffco 08-nswat Norlite Tactical Led...
When hooked up to charger red light blinks. Light will not come on without charger hooked to it.
  • Hi, i can help.
  • When the lights just blink like that on the charger it is saying that the battery is bad and will no longer take a charge.
  • These flashlight are real impressive but there have also been reports of the charging unit failing.
  • Make sure to clean the contacts well with rubbing alcohol.
  • I had one time that was a real pain if it was not set just perfect on the charger.
  • So there are a couple things to try but I think you just need to get a new set of rechargeable. Lithium batteries like the ones this flashlight uses can't be overcharged or over discharged of they malfunction.
  • CR123A Lithium rechargeables are cheap these days. spring on a new pair and you should be fine.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 26, 2011 | Inova T4 4 Watt Lifetime Led Tactical...
Light wont come on. Not the battery and not the bulb. What else could it be?
These are notorious for the switches failing. Mag will replace it for free if you ship it back to them.
Phone 909 947-1006
Dec 22, 2010 | MagLite Rechargeable Flashlight System
My Inova T3 with freshly charged Tenergy RCR123A Li-Ion batteries (3) runs with full light output for about 1-2 minutes and then drops off so that all you see a small round LED disc inside the lens. If you...
I'm not certain that it's the cause in your case, but a low quality battery can definitely lead to this kind of behavior. I took the plunge when buying myself 18650 batteries for a flashlight for use in the security industry, $20ea for the batteries. I'll never buy cheap again.
Nov 02, 2017 | Inova T3 Tactical Flashlight
Bad battery ???
It sounds like the battery has just enough "juice" to give the small light some power, but when the larger light is turned on it overloads the bad (or expired) battery. When you put a new battery in you can extend the life by not using the light when the battery starts to die. This is when it starts to permanently damage the battery. Turn it off and recharge as soon as it dims. Charge often, but don't leave on the charger too long unless it is a smart charger and turns off when the battery is fully charged. This will also reduce the life. You can find a replacement battery here: http://batteryinternational.com/spotlight-batteries-vector-battery.html
Jan 16, 2009 | Camping, Backpacking & Hiking
Camping, Backpacking & Hiking Logo
599 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
