Question about Refrigerators
I have a F&P Fridge Model c270 that the thermostat is not working and within 24 hours drops the temp to -8c.
Have turned it off for 24 hours then changed the thermostat setting and within 24 hours - back to -8c... what level of confidence should I have in changing the thermostat will fix the issue -- and where can I find the cheapest replacement part?
  • 1 more comment
  • Pete
    Pete Dec 03, 2016
    Hi Phil, you have already posted in your original post that the fridge is a C270 (which is the model number of the single door fridge). On the grey label showing the model number and serial number, there is also a number referred to as product ID
  • Phil Siefert
    Phil Siefert Dec 03, 2016
    Hi Pete - found what you were looking for Product code: 20657
  • Pete
    Pete Dec 03, 2016
    Cut's in at +5.5?C+1.1?C, Cuts out -26?C+1.5?C
    Ambient heater - 5.58K ohms
    Thermostat - CONTROL DANFOSS XXX3.5 deg C Cutout
    Part # 813491P - which replaces or equivalent to 883707P, 813491P, K59-A6821-001, RFP091.
    Capillary length is 1100mm.
    Also, check that the system is fully flooded and check that the sensing tube is in thermal contact in the sensing well. No more than 30mm of the sensing tube should show through the end of the well.
    Before replacing a temperature control, firstly ascertain that it is in fact defective. If complaint is ?too cold? ? try a warmer setting and vice versa. Always check that the system is fully flooded and check that the sensing tube is in thermal contact in the sensing well. No more than 30mm of the sensing tube should show through the end of the well.
    Habit-Forming:
  • 36 Answers
More information required. What is the product ID on the grey label on the bottom right of the cabinet when you open the door?
Have you transported the fridge recently?
Posted on Dec 03, 2016
Testimonial: "It is a Fischer and paykel c270 - no recent transport"
My fridge keeps freezing everything what is the best temp to have it set at. It is an aurora model RB411M3
I recommend moving the thermostat to the exact center position, unplug, then plug in the refrigerator. Wait 24 hours for the fridge thermostat to reset and to thaw automatically. Then, I recommend a fridge thermometer, available at most grocers or kitchen supply stores. If you can't find one, use a digital thermometer with a probe. Place the thermometer hanging from the center of the center shelf. Keep the refrigerator temperature at or below 40° F (4° C). The freezer temperature should be 0° F (-18° C). Allow 24 hours for any thermostat changes.
Apr 08, 2017 | Refrigerators
Everything freezes
Make sure it is level.
Nov 25, 2013 | Hotpoint Refrigerators
Freezer side works fine but refrigerator side is freezing temp stays in 20's
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Oct 15, 2011 | GE PSS25NGM Side by Side Refrigerator
Kenmore side by side Model #106.55532400 Orignally the frig. side would not cooled down below 40F even when the digital control was lower to 33F. The unit was unloaded and turned off for 24 hours, doors...
Yes the thermister is the electronic thermostat...on models such as yours that has a computer control a thermister is used..on models that the knob is turned to set the temp. and has no digital dispay a thermostat is used
The part number for the thermister is 2188819
It fits by air damper in the fresh food compartment in the upper left corner of the fresh food compartment
GENE
Sep 09, 2011 | Kenmore Side by Side Refrigerator
I have a refrigerator Bosch Model KSU45621AU Auto frost and the Fridge compartment is not running at a cold temp can you help Please. Thanks Ali
Top of Form
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
So try this test from the outside and make your observations so that we come to the solution.
May 28, 2011 | Refrigerators
My fridge & freezer is not getting cold. The temp is 56 for the fridge and 38 for the freezer. What could be the problem.
Top of Form
Nov 25, 2010 | Maytag MFD2561HE Bottom Freezer French...
The freezer is cold but the refrigerator is not as cold as it should.be I have the temp up to 45 I have vac out both back and front.
Top of Form
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.SInce there is formation of Ice then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
Nov 24, 2010 | Washing Machines
My fridge temp is at 64 but my freezer temperature keeps dropping
If the freezer is not cooling as desired it is possible that the blower is blocked.
Now Shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
Oct 28, 2010 | Frigidaire FRS-26DR7D Side by Side...
Cooling has stopped in the upper refrigerator section. Frezzer section ok. Indicator says 64 degrees (upper). I push the button for temp and it says 36... then reverts back 15 seconds later to 64
Since the freezer is working the duct can be blocked . So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
Oct 09, 2010 | GE PFS22SISSS Stainless Steel French Door...
Refrigerator is not cold (50);freezer is working; vents not blocked. What can I do? Fan is working, & compressor does kick on.
Nine out of ten times it turns out to be a defrost issue. What most people dont understand is the refrigerator gets its cool air from the freezer. If the evaporator coil in the freezer becomes a block of ice then the airflow from freezer to fridge section is blocked. The block of ice along with already frozen foods in the freezer compartment help to keep those foods frozen. Therefore you assume the freezer section is fine. However, the lack of cool airflow to the fridge side quickly turns that 38 degree air into 50 degree air. You could try unplugging the fridge and leaving doors open for 24 hours, this will thatw the evap coil. Plug it back in after the 24 hours, and within 12-24 hrs everything should be cool. If the fridge continutes to cool for about 3-6 days and then fails again, you certainly have a defrost problem. This is long winded, but hope it helps
Mar 01, 2010 | Refrigerators
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
