Question about Carrier Heating & Cooling
I have a carrier debonair 250 thermostat ..2 issues 1. When I manually put the heating temp I want the flames go on.....10'sec later on ......ten sec off. Then the fan blows cold air no heat 2
  • Carrier Master
  • 16,373 Answers
This is most likely the flame sensor in the actual furnace and not the thermostat. Post the model of the furnace.
Posted on Dec 03, 2016
I have a carrier furnance model # 398AAV036060 serial # 0293A03686 it comes on for a few minutes the cuts off please help
Check for smell of gas first, call gas company if leak detected. May be a loose thermostat wire, dirty main control board, dirty/ lint filled gas tubes, mine had both. Cracked or dirty ceramic igniter (This is a BIGGIE!) or dirty flame sensor. Dirty fan sensor, or flame over sensor, and or burner safety sensors. Shut off power for 10 minutes, follow owner's manual to restart, wall thermostat might usually get set to lowest temp setting, then power turned on, then set thermostat to desired temperature?
Nov 16, 2017 | Carrier Heating & Cooling
How to clear"service filter"after i changed the filter on Debonair 220 Carrier thermostat
Press mode and program together and hold to enter configuration. Press mode until option 11. 11 is the run time before reminder, put this to 0.
Aug 07, 2017 | Carrier Heating & Cooling
I have a carrier debonair 450 it is blank and not working it does not take batteries. needing help
Carrier Thermostat 33CS450-01 User's Guide ...
homeappliance.manualsonline.com > ... > Carrier Thermostat
Appliance manuals and free pdf instructions. Find the user ... Carrier 33CS450-01 Thermostat User Manual. Page 1 ... Carrier Corporation 04/06. Use with most ...
Sep 10, 2015 | Home
Jandy lite 2 pool heater will not stay lit.
I'm having the same issue as the above user with Jandy Lite 2 (which from what I can tell stands for the number of times that you can get this POS to work annually)!
The unit LIGHTS OFF, but WON'T STAY LIT! Igniter engages, gas valve opens, unit lights, burns for 10 seconds, and flames out. Error code FL 2, after third attempt, already replaced the flame sensor....
May 12, 2013 | Pool & Spa
I have a gas dryer, model MDG7657AWW that will not stay heated. Every time I put it on, the flame comes on for about 21 seconds & then shuts off. I replaced the igniter, hi limit thermostat, cycling t
On a gas dryer the heat normally only comes on for 30 seconds or until the drum temp reaches 160f at which time the flame is shut down by the cycling thermostat. The drum temp then starts to drop. When the drum temp reaches 105f then another blast of heat is issued for 30 more seconds.That is how they work. Put it all back together and trow a load in there.
Oct 28, 2011 | Dryers
I have a model LDG712 gas dryer. The flame ignites and burns for about 20 seconds. The flame then stops burning and it about 1 minute and 30 seconds or more before it lights again. The glow bar...
The flame should cycle on for about 50 seconds on the first cycle and approx 20 sec each additional cycle. I would check your airflow out of the dryer it my be restricted not allowing the flame to pull through the burner tube causing the unit to "short cycle". Its not likely a thermostat issue but if you were to replace a thermostat I would replace the cycling thermostat should be part number 3387134. Hope this helps.
_MJ_
Dec 15, 2010 | Maytag Dryers
Pool heater gas fire lights up and turns off 10 secs later
Assuming you don't hear any banging noises, that cycle is by design. There is a fault. 2 possible causes are the ignition board is bad, or the ignition sensor is not returning a voltage indicating the flame is lit. Take this out and put the ignition piece on your stove flame. Check for voltage while on flame (DC millivolt setting on multimeter). Put one probe on ground other on sensor lead. If it doesnt have voltage this is bad. If you do, its possible your board is bad.
Apr 26, 2010 | Hayward H Series Induced Draft Abg 100,000...
Blank thermostat
Check voltage at unit. Also check the 5 amp fuse in the unit. If this unit has a float switch in the drain line check that. Rus
Dec 03, 2009 | Carrier 36KCARMS Air Conditioner
Furnace runs OK, but blower runs again a few seconds later
Could be a defective thermostat in the plenum.
When a gas furnace shuts down the fan(blower) will run until the plenum cools to the safe range. Usually 1 and 1/2 minutes.
Intermittent operation is a defective thermostat or relay.
Mar 11, 2009 | Carrier Heating & Cooling
Master 160,000 btu will not stay lit
pull out flame sensor and sand. Re install and call for heat
Jan 21, 2009 | Master Heaters 160-IF
Heating & Cooling Logo
47 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
