Question about Boating
I have a 15 hp mercury outboard motor that will start only with carb cleaner for about five seconds then shut itself off. I've tried spark plus new fuel and severa other things. Help!
Make sure there is fuel reaching the carburetor if there is, it sounds like it needs a cleaning most likely a stuck needle and seat, its not the correct fix but tap on the bowl of the carb moderately with a solid object it may free up the stuck needle. if this does, I would still service the carb to prevent an unreliable engine.
Posted on Dec 03, 2016
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Jun 25, 2015 | Mercury Marine 15hp & 20hp 4 Stroke...
What pins on the ignition switch are energized when when you turn the key on a 2003 mercury 15 hp 4 stroke outboard?
Red is Battery +
Red/purple is ignition
Yellow/red is startermotor
Black/yellow is motor kill
Black is ground
To have ignition, black/yellow wire must be disconnected
On is red/purple on bat+
To start Yellow/red on batt+
To kill: black/yellow on ground
Jul 29, 2017 | Boating
Have 115 Hp mercury outboard motor missing at full throttle and on idle. At mid throttle it is running fine. Any Idea what the problem could be. Thanks, Milton
Have your spark plugs changed AND carbs cleaned and adjusted.
Usually that can also be caused by a seized advance system ( plate under the flywheel, commanded to turn with the throttle linkage... )
Aug 16, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
1976 115 hp mercury outboard motor manual
fuel goes in at connector then to fuel pump then to carbs ! remove connector off fuel line and prime fuel up so you know you got fuel ! then reconnect to engine and prime up again till you see filter filling and bulb should harden , then remove a drain screw from carb bowl and prime again and see if fuel comes out of all carb drains ! if yes then start engine with or in water with kill lanyard on if ok then good ! not then check sparks on all plugs putting them against the head for earth and crank to check ! if ok then i would remove carbs and clean the jets etc ! compressions 100psi or more on all cylinders ! less means recon pistons etc !
Jul 28, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
Carburetor runs too rich
sounds like you need to get the carburater cleaned and install a new set of spark plugs
Jul 08, 2010 | 2003 Mercury Mariner
I have 15 hp mercury hasnt been ran in two year tryin t sell when i first tryed to start it the motor would start run 1 to 2 seconds and die out thought primer bulb was bad went and bought new one then it...
my uncle told me to take the spark plugs out to check if they were dry and if they were to take a spray bottle and put gas in it and spray inside the pluggs and give it full throttle. The motor started on the seconed try.
Jan 15, 2010 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
95 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
