Question about Plumbing
XP900h pump.rainwater pump. Ran for an hour but next day wouldn't. Will run if assisted with start up by spinning rear fan, removal of pump assembly has same. result.
SOURCE: engine intermitantly stalls
if this a fuel injected car just check to fuel pressure first.
Posted on Oct 24, 2008
  • 140 Answers
SOURCE: 99 chevy suburban intermittenly not starting....fuel pump is runn
Unfortunately the fuel pump can still be bad. The pump has a check valve on it that wears out. The pump will continue to run but, struggles to supply enough fuel to start the engine. You can buy a fuel pressure test gauge from Auto Zone or that type of auto parts store and check the pressure. You can purchase a fuel pump from them too.
Posted on Dec 30, 2008
Sea Breeze
  • 4655 Answers
SOURCE: refrigerator not cooling
You model if the ARB1950C has a defrost timer inside the fresh food compartment and behind the temperature control panel. Need to see if you can manualy turn the timer clockwise until the compressor stops. During that time of 25 minutes the freezer should be in defrost. I believe your timer needs replaced based on how you explained what is happening. The part number for your timer is 67001036 and can be found at the links below. If it stays longer that 25 minutes then it's sticking in the defrost section of the defrost timer and will need to be replaced. If your refrigerator does not restart after about 25 minutes then slowly turn the timer through the opening in the plastic cover. There may be a plug covering the hole to make the hole not so visible. If you should have problems fell free to let me know, Thanks Sea Breeze
Posted on Aug 17, 2009
SOURCE: 97 gmc pickup, 5.7 eng, fuel pump not operating,
What you need to do is check you fuel pressure. Go to a local auto parts store and buy a fuel injection pressure tester. The pressure fitting is on the top of the motor its a 3/8 ish sized metal line and has a screw on fitting like a tire valve does. This line comes up from the back of the motor to the right of the distributor and goes down into the intake. Make sure to have a rag handy to catch the fuel seepage. After you connect the pressure tester turn the key on and off three times and read the gage you should have atleast 58 pounds of pressure. If you have 56 pounds it won't run because the fuel injectors are a poppit valve style and need atleast 58 pounds of pressure to operate.
Posted on Sep 12, 2009
SOURCE: Engine dies when hitting big bump
Yeah, I'd also think wiring, but do a check under the Distributor cap anyhow
Float stuck closed, something in the fuel filter got joggled around?
Posted on Nov 19, 2009
Big rainwater tank ran dry and so electric Onga pump that normally pumps water from big tank to little overhead tank kept failing. Have since refilled big rainwater tank, but pump keeps failing. Have
Release AIR lock. Air has got trapped in the pump hence it cannot create necessary level of suction. The way normally you do this by filling the water path of the pump with water and get the air released.
Oct 12, 2014 | Plumbing
Fiirst started with a buzzing noise, then next load wouldn't spin proper, then not at all, unplugged washer to reset, tried a small load and it won't run water now,after running 10 to 15 minut
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp that connects the trap assembly to the pump and clean it out.
If helped, pl say so.
Apr 01, 2013 | Frigidaire Washing Machines
The car dies out, it will turn over but wont start, it ran one day then wouldn't
It is probably one of three things. It isn't getting a proper spark, proper fuel, or proper compression. Good luck!--------------------------------------------------------------------------
VAS 5054A
Dec 17, 2012 | 2006 Kia Optima
Vitara 1.6 16v 96' wont start
There are multiple reasons. Need to start the process of elimination. First things first, the cheapest thing to check is the battery. I've had several vehicles which displayed the same thing: ran one day, wouldn't start the next. Fortunately, they just needed a battery.
After that, could be other issues: alternator, starter, possible timing component issues, fuel pump.
I know this is vague, but, the it is sort of a loaded question.
Dec 18, 2011 | Suzuki Vitara Cars & Trucks
I have a 1996 Sebring Convertible that ran perfect one day and the next day wouldn't start. It is getting fuel, the battery turns it over fine and if I shoot Starting Fluid into the air intake, it will...
There's a computer controlled circuit that will kill fuel pressure on some cars right at the last inlet valve at the fuel rail.A bad key or ignition can cause this. don-ohio
Aug 26, 2011 | 1995 Chrysler Sebring
Heater will not start. When plugged in, it just produces a buzzing sound. Kerosene is full, and fuses are good. What can I do?
Check for power to fan motor.....if there is power and motor does not go then the motor is bad...
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
Feb 04, 2011 | Reddy Heater-70,000 BTU Kerosene w/T'stat
6.5 tubbo diesel died and wont start back
Sounds like the fuel pump got air in the system. You may have to bleed out the air. Then it will run. Check the fuel tank for fuel first.
Nov 23, 2017 | 1998 GMC Sierra
Master 110 torpedo heater will not start , kerosene type
Odds are, your air pump is locked up. Remove the cover on the back of the fan motor, remove the pump cover and carefully remove the air pump rotor and blades. If the motor spins freely and will start when plugged in, the pump housing plates probably have a bit of corrosion on them. Lightly clean the pump housing end plates with fine grit sandpaper, wipe clean and re-assemble. Should fix the problem. Does the breaker trip when this happens?
Jan 01, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Plumbing Logo
90 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
