Question about Camping, Backpacking & Hiking
Brita water filte - Camping, Backpacking & Hiking
Tip
Brita Memo Replacement Unit failed then order a FREE replacement !
Create an account at Brita then go here you will receive you new Brita Memo Replacement Unit within 10 days.
https://www.brita.net/uk/replacement_parts.html?L=1
Usually the battery in this unit will last about four years however if you register your details with a valid email all BRITA products will come with a 2 year manufacture guarantee... but should any part of it break, we will send you a replacement part absolutely FREE
Don't bother trying to replace the CR1616 battery yourself it is a sealed unit and once the seal is broken you can replace the battery but it will fail very soon with steam ingress even if you superglue it.!!
USER REGISTRATION required valid e-mail
BRITA MEMO how it works
CARTRIDGE REMINDER via email every four weeks
Here is to cleaner water in your kettle and the means to know when to change the Filter.!!
on Mar 02, 2010 | Brita 35516 Pitcher
Vkj476 BReville hot cup with variable dispense. How do you change the filted britta filter
The Breville VKJ476 Hot Cup with Variable Dispenser does not require a filter so will not take a Brita filter.
Mar 21, 2013 | Breville Hot Cup With Variable Dispenser...
How can i separate the two parts of the reservoir to wash it without breaking it?
I just figured out how to separate the two parts of the Brita Ultramax water reservoir so they can be cleaned!!!
Empty the Brita of water. Whatever water is not removed through the spigot will drain out if you turn the filter upside down. Then let the two parts air dry for an hour or so. Now hold the two parts between the thumbs and middle fingers on each end, press your middle fingers against your thumbs. Then slide your middle fingers up, and the white part lifts out of the clear bottom! Yay!! Now the clear reservoir can be CLEANED!!
Mar 24, 2011 | Brita 35530 UltraMax Digital Water...
Too much carbon in water
Sounds like a bad batch of filters. Stop using them and return them to Brita for analysis and replacement
Feb 16, 2009 | Brita 35516 Pitcher
Brita filter needs replacement, but is stuck. any advice?
Hold filter cartridge in one hand and slowly turn on water. The water pressure will push the cartridge out of the housing.
Jan 09, 2009 | Brita 35516 Pitcher
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
Camping, Backpacking & Hiking Logo
93 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
