Question about Philips 50PF9731D/37 50 in. Plasma Television
TV won't come on
I am getting 6 long red followed by 3 short red flashing
I'm sure you've rectified the problem one way or another at this point, but I had the same issue and was able to fix it. I'm not sure which of these actually worked and I don't dare try to figure out which one, but I went behind the unit with some compressed air and cleaned out all the vents, then I replaced the power cord. Fixed. Philips was absolutely useless when we contacted them about the issue.
Posted on Aug 02, 2009
    President:
  • 1,077 Answers
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other part inside from being damaged. The flashing red light should no doubt be an error trouble code. But, I don't have the actual Service Manual for your TV model to tell you what the code means. Most protection mode problems are a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The common part to go bad for flat panel screens circuit board that powers the screen. Most manufactures call it a Backlight Inverter Board.
But, I can't say what is 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. You can again try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light flasing codes, circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15 by searching on the internet with the part number.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 21, 2009
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Feb 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
I lost my codes
USING THE RMC10 REMOTE WITH AN UNLISTED DEVICE.
MANUAL CODE SEARCH:
If your product does not respond after you have tried all the codes for your brand, or if
your brand is not listed, try searching for your code by following these steps:
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the CODE SEARCH button until the red indicator stays on, then
release the CODE SEARCH button.
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red Indicator
blinks off once.
4. Face the remote control directly to the device you want to control (TV, VCR etc).
5. Press the ON/OFF button repeatedly (up to 300 times) until the device to be
controlled changes channel. The red indicator blinks off with each button press.
6. Press and release ENTER to install the code.
Most users will store VCR codes under the VCR button, Cable codes under CABLE,
etc. If (for example) you want to store a VCR code under CABLE, first follow the
procedure for Direct Code Entry (previous page) and press CABLE in step 2 of Direct
Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the
steps above for Code Search (or Brand Search, below). Note: If the device does not
have a CHANNEL UP button, use PLAY (VCR only) or POWER instead. Code Search
starts from the currently stored three digit number under that mode.
AUTO CODE SEARCH:
your brand is not listed, try searching for your code by following these steps.
2 Press and hold the CODE SEARCH button until the red indicator stays on, then
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red indicator
blinks off once.
5. Press the ON/OFF button down till the Red Indicator Light stays on.
6. The red led indicator will keep on flashing till your device (TV, VCR etc) turns off.
7. Press and release enter to Install the code.
CODE RETRIEVAL:
1. Manually turn on the device (TV, VCR etc) to be controlled.
2. Press and hold the CODE SEARCH button until the red Indicator stays on, then
release the CODE SEARCH.
3. Press the device control (TV, VCR etc) you want to control.
4. Press the CODE SEARCH button again and the red indicator should blink once.
5. Follow the sequence of (0-9)and press once for each number button until the
Indicator flashes one time.
6. Repeat the procedure 5 till 3 correct codes are confirmed.
7. If the red indicator light flashes, than you have entered an incorrect number, and
please follow the sequence (0-9).
also here is your manual. For your remote.
http://www.sentryindustries.com/pdf/instructions/RMC10_Instructions.pdf
please rate me, or recommend me it will be most helpful in letting me and other know how im doing.
Oct 03, 2009 | Sentry SE-RMC10 Remote Control
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Flasing red light where the on light is
I have a philips pf50 9630a/37 tv may come on or it may not unplug it and take a chance then comes the 6 steady red flashes followed by 3 rapid red flashes the screen had been completely replaced by philips a year and a half ago
Mar 22, 2009 | Philips 50PF7321D 50 in. Plasma HDTV
Sony KP-51WS500 will not turn on
I believe the problem is either in the G board ( power supply) or the D Board ( high voltage) as the 3 blinks indicate the G board, and 7 indicates the D board and 6 indicates the +5 line a and b boards. So with that many codes its most likely the G board (power supply) You can get a new replacement G board at the following link which comes with free tech support to help you plug the baord in which is very easy. Its listed under the Sony parts category and its the A-1316-566-A sony G board, Here is the link.
http://servicemanuals.vstore.ca/
Aug 12, 2008 | Sony KP-51WS500 51" Rear Projection...
Tv just shut off and red light is flashing
Most Sony 6-blink codes for projection TVs follow this pattern:
6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
Mar 07, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Screen Turns Red and then TV shuts off
you red crt is shorting out.tap the neck of the red crt lightly to try to remove the short.if no go also inspect the neck board.
Oct 22, 2007 | Sony KP-51HW40 51" Rear Projection...
Philips 50PF9731D/37 50 in. Plasma Television Logo
359 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
