Question about Maytag Washing Machines
I have a maytag front load washer,two years old, E01 and F08 code, the machine is running, will not shut off and the door will not unlock. I unplug it but door is still locked.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
After unplugging the machine, I would start by trying to suck the water out using a wet/dry vac attached to the drain hose going into your wall. You can even use your hand to form the adapter between the hoses. It may take several tries to empty it depending on the size of the vacuum, but it sounds like quite a bit of water in the tub. If this does not work, my guess is that your drain is clogged on the other side of the pump. To clear this, you (and others just needing to know about error codes) should be able to find the error troubleshooting guide the service company refers to taped to the back, inside rear of the machine. You will need to remove the panel at the bottom of the machine by removing some screws and lifting the panel up and out. Use a flashlight to see if the guide is still taped to the inside of the machine. It will give you great information on the error codes. The drain pump assembly is to your right on the Epic series, and possibly other models. If the error codes suggest you have a drain pump issue or clog, you will need several buckets and towels to drain the water. I used two full buckets and did not have water visible in the window. Good luck! My drain pump was bad, and replacing it was easy.
Posted on Dec 04, 2016
What do error codes e06 and e01 mean?
E01 and e06 codes - Fixya
Aug 19, 2012 - e01 and e06 codes washer will not do anything other than lock the door. - Whirlpool Duet: WFW94HEXW Laundry : question. ... Error message E06 onWhirlpool. Unplug the machine and wait 10 minutes before restarting it.
Aug 24, 2015 | Maytag Washing Machines
Throwing code E08. How do I fix it
I Googled my washer to look up some stuff i couldn't find for my own washer other than here and i did not see E08 as an error code in my manual or on any of the other websites but i did see F08 followed by E01 which was a water supply error:: and you have to check for proper water supply:: check the hoses and the faucets to be sure that the screens are not clogged and the hoses are not kinked to clear the code touch the power button once then touch the power button again to restart the washer if the code appears again the manual says to call for service to send out a service tech.
Jan 09, 2014 | Maytag MHW3000BW Maxima X Front Load...
Maytag Maxima washer error codes E01 F08
Mine was resolved after changing the Symmons slide valve at the inlet to the hoses. This valve is spring loaded and does not work if not exercised as open and close on regular basis. My hot water supply was completely shut off and cold water remained open at all time. Check the incoming water pressure by unscrewing the hoses from washer and check water outlet by filling the bucket from both sources. Symmons slide valve at the wall is W-400 and was 25 years old.
Aug 16, 2012 | Maytag Washing Machines
Purchased a Maytag Maxima washer two weeks ago--beginning to think it's ****. Have been trying to was a load of laundry for 2 1/2 hours now and can't get the washer to spin the load dry. Have tried...
I just bought the same washer and there is a problem with the steam sensing device. Check for code in time window. mine has a F08 and E01. Repairman coming in 2 days.
Feb 18, 2011 | Maytag Washing Machines
Front load washer. Door will not unlock get error code "do" or FL. Door lock light is not on but door is locked and wont unlock. You csn hear a buzz as the lock energizes but does not unlock. Allready...
Sturdy little door, isn't it? Make sure you don't have extra water in the machine, as this will cause the door to not unlock. With that done,unplug your washer. If you can get the top of the machine off and reach down the front of the washer, you should see the latch mechanism. Push this down. Door should unlock. Now. Buy a new latch assemby.
Mar 16, 2010 | Maytag MAH8700A Front Load Washer
Neptune front load washer showing code LO. Door
You can try either prying the door open and then replacig the door switch which is probably what caused the problem in the first place. Or try unplugging the machine for several hours, press and hold power button for a few seconds, wait half hour more, plug back in to see if it resets itself.
Nov 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
46 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
