Question about Water Water Heaters
We have the ProMax, 75 gal w/h. Water was shooting out of the t and p relief valve pipe. I turned the water off so water doesn't continue to shoot all over. Will the unit reset itself?
  • 2,598 Answers
The relief valve saved the system from exploding, check or renew the thermostat to make sure the power is off before boiling.
Posted on Dec 03, 2016
How to change out copper piping from release valve
If the release valve referred to is the pressure release valve, then a water leak out the attached vent pipe is an indication that the valve is failing. To change the valve, the water must be allowed to cool (turn off AC power or gas) and the water level inside the tank must be lowered (drained) to below the level of the pressure relief valve. Once this is accomplished the vent pipe is unscrewed from the relief valve and the pressure relief valve is unscrewed from the water tank. A new pressure relief valve with a sealant on the threads, is then screwed and tightened into place with the outlet port facing downward. The vent pipe is attached to the new valve and the tank refilled with water. A hot water facet must be opened to allow air to exit while filling. Upon becoming full (water will begin to flow from facet), turn off the facet and restore AC power or gas, therefore allowing the water heater to heat up. When the first hot water is utilized there may be some air expelled from the facet.
Sep 13, 2015 | Water Water Heaters
Relief valve buzzing noise
Add an extrol expansion tank to the piping. You can get one for about thirty dollars from the hardware store.
Apr 06, 2014 | Rheem 82V40-2 Fury Electric Residential...
Water dripping from blowpipe
It is normal for water to drip out sometimes from the pressure relief valve outlet pipe. If it drips continuously then open and shut the pressure relief valve several times so the pressure relief valve shuts off properly.
If this does not fix the dripping problem then the pressure relief valve is faulty and needs to be replaced.
Apr 02, 2013 | Water Heaters
Atwood Hot Water heater wont' shut off
sounds like defective thermostat/gas valve
Aug 05, 2012 | RTO Atwood Water Heater - 6 Gal LP
I fill the tank up, but it seems too light to be full, so I drain it and it only has about 1 gallon if that in it. Whats wrong?
How are you filling the tank, and is this in an RV or what? Open pressure relief valve when filling and when water comes out pressure relief valve, you know your close to full. If it doesn't come out there when valve is open, check for by-pass valve(s) in wrong position and not filling the tank.
Aug 11, 2011 | RTO Atwood Water Heater - 6 Gal LP
Pressure releif valve leaking
Hot water pressure relief valves serve two functions. The first is to remove high-pressure water from the hot water tank. The second function is to act as a high temperature valve to remove water that exceeds a predetermined point for the valve. Both of these relief settings are preset at the valve factory. Many pressure relief valves will come with a metal tag that identifies these release points. If you're attempting to remove the hot water heater pressure relief valve, pay careful attention to ensure that you replace with the correct valve.
Your hot water heater has a pressure relief valve safety mechanism. When pressure inside the water tank exceeds certain limitations, the valve opens up to allow the pressure to be released. A faulty pressure relief valve will not release excess pressure, which could cause extensive damage to your home. You should test the hot water heater pressure relief valve once every six months to ensure proper operation. If the pressure relief valve fails the test, replace the valve with a new one immediately
Locate the pressure relief valve on your hot water heater. The pressure relief valve has a lever handle on top with a drain pipe attached to it. The pressure relief valve is most often on the side of the water tank toward the top. Newer models of hot water heaters have the pressure relief valve on top of the water tank.
  • Inspect the area around the pressure relief valve for signs of leaking water. If there is leaking water near the relief valve connection, replace the relief valve. If no leaking is evident, proceed with testing the pressure valve.
  • 3
    Examine the area below the pressure relief valve drain pipe. Most water heater closets either have a drain in the floor below the pipe or the pipe is inserted into another pipe to direct the water out of the home. If the end of your drain pipe is not in another pipe or there is no drain in the floor, place a bucket under the drain pipe to catch water when you test the pressure relief valve.
  • 4
    Pull the lever handle on the top of the pressure relief valve up with your fingers. A working lever will lift up without difficulty.You should begin to hear water going through the drain pipe. Slowly release the lever to shut off the pressure relief valve. The pressure relief valve is good. If you did not hear water running through the drain pipe, lower the lever on the pressure relief valve and replace the valve. If the lever is difficult to raise, do not force the lever. Replace the pressure relief valve.
  • Now with all that said if you have a closed loop water supply system and you have a pressure vessal/expantion tank it may have gone bad and is making the TP valve leak. you can call your water provider to see if you have closed loop system.
    Feb 04, 2011 | Whirlpool Water Heaters
    We have a brand new rheem 40 gal elec water heater, after installation we have water leaking from the base of the relief valve, pooling up in the plastic fitting and making it way over the side all over...
    Water heater should be set in a drip pan.
    Otherwise, put 1 gallon bucket under TP release pipe to catch water.
    When you say relief valve, I assum you are talking about brass valve located on top of tank or near top of tank. This is TP valve and a pipe connects to this valve and runs down to within 6" of bottom of tank. TP valve has a small lever on it.
    If you are talking about tank drain valve located at bottom of tank, then add a comment.
    Following information is for TP valve.
    Dripping TP valve can be caused by 3 different thing:
    1) Obstruction inside TP valve. Open TP valve for a moment to flush away particles and slowly lower lever back down. See if water stops dripping, if not, then replace TP valve
    2) Defective TP valve: replace TP valve. Turn off electricity to water heater. Let heater cool for several hours so you do not get scalded. Close shut off valve located above tank on cold side. Open tub spout to relieve pressure, open tank drain or open TP valve and empty water below TP valve level. If TP is located on top of tank, not much water has to be drained. Tank is under press when hot, so be careful. Put teflon tape on new valve and install with big pipe wrench by turning clockwise until TP valve is very tight.
    3) Overheating tank. TP valve is temperature-pressure valve. If tank water is over 150 degrees, the TP valve starts drizzling hot water to relieve tank pressure.
    Lower tank pressure two different ways:
    a) turn down thermostat
    b) install expansion tank on incoming cold water line
    Dec 19, 2010 | Rheem Water Heater Pressure Relief Valve
    I have a Rheem Steller natural gas hot water service. There is a continuous dribble of water from the pressure valve overflow, even when the heater is not heating. I have tried easing the valve a few...
    Yes, Turn the knob on the gas valve to off. Turn off the incoming water line into the water heater. If you have a valve on the outlet turn it off too. Open the drain at the bottom of the heater to drain a little water from heater. You can then lift the lever on the temperature/pressusre relief valve to let a little air in to release the vacuum and let the tank drain. If the relief is in the side let it drain a bit longer so the water level is below the outlet. Be sure to re-install the down pipe on the relief valve on the new valve. You should drain the a few gallons of water at least once a year from your heater, and you should exercise your temperature relief valve once a year to be sure it will function. If your new valve leaks suspect your temperature control allowing the water to get too hot.
    Oct 03, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
    You can buy a replacement relief valve at any hardware or home improvement store. It's real name is a T&P valve or temperature and pressure relief valve. It always has a 3/4" inlet and outlet. It is a very easy procedure to replace. You will need a bucket, teflon pipe thread tape, and a 3/4" x 6" black iron or galvanized pipe nipple. To start the valve replacement, turn off the shuttoff valve on the cold water line. Then open the handle on the relief valve and drain water into the bucket, that is, unless you have a pvc pipe coming off of it into a drain floor, then just drain it without the bucket. Be careful, the water is hot! When the water level gets below the relief valve, it will stop draining. Then remove the pvc pipe, if applicable, and thread in the 6" pipe nipple to use as a leverage tool to remove the valve from the water tank. Turn it counter clockwise to remove. Then put teflon tape on the new valve, going from left to right with the valve threads facing downward. Wrap about 3-4 layers all around the threads. Then twist the new valve into the water tank clockwise and using the pipe nipple tighten by hand until very snug and outlet is facing downward, as before. Remove the pipe nipple and install pvc pipe, if applicable. Leave valve handle open and turn on the cold water until the valve starts spitting, then close the relief valve and let it fill up the tank. If you did it correctly, you are now finished! Good luck!
    Jun 14, 2010 | Water Heaters
    Atwood g6A-7E wont turn off keeps heating water till tmp drips
    Some dripping at pressure relief valve is normal, but are you saying it continues to run excessively hot? Does water in trailer feel extra hot?
    The ECO, and/or Thermostat, should cut the power/flame before it gets too excessive.
    Apr 03, 2010 | RTO Atwood Water Heater - 6 Gal LP
    Water Heaters Logo
    47 people viewed this question
    Top Water Heaters Experts
    D. E. Hev
    Are you a Water Heater Expert? Answer questions, earn points and help others
