Question about Tablets & eReaders
I have a few gaskets i dont know what they go to. and do the cork gaskets require sealant? what if i put sealant on the valve cover gaskets before i knew that i had to replace the valve stem seals
I would like to know if there ios a visual guide to show which gaskets i have have where they go and how to install them.
Valve cover Gaskets do not require using sealant usually you can use small dabs of sealant to hold the gasket in place while it is installed
Posted on Dec 03, 2016
Testimonial: "thanks joseph, is there a description and installation guide for the gaskets?"
My kindle is frozen at pause screen
had this the other day with a kindel. check the charger is working or change to another usb and leave on for 10min, then press the power button. if this does not work you will need to prise off the screen cover and undo the 10 torx screws and use a something like a kitchen knife not sharp and prise the top of gently as there is 4 clips holding down the board and screen, when its out remove the battery its a push the pins in on the sides and pull away. leave it unplugged for a few seconds then plug back in, now while its out plug the charger in, it will have an amber led show at the charging port area you will see it blink about a minute after charger is plugged in, now press the power button and it should turn on now (button is in the same place as the case ) leave it on charge out of casing and when charged and the led is green replace in case remove power lead and put the power connection on the board in first to the case and push down on the corners you will hear it click, then screw the case back down. (remember when the screen cover is off put it to one side and make sure nothing gets onto the sticky side) when all back together with the screws put the screen cover back on. and you are done.
Aug 12, 2017 | Tablets & eReaders
How do i fix my asus tablet its froozen on screen cant turn it off
Take a flat object like a butter knife, start near a corner and pop the back cover loose...then work your way around removing the cover, pull the battery out, press and hold the power button for a few seconds, put the battery back in, put the cover back on, turn the tablet back on.
Feb 17, 2015 | ASUS MeMO Pad HD 7
I dont know my pin and i never put one in
You cannot change the pin unless you have the current pin. If you have never entered a pin before then someone might have entered a pin as a joke on you. You could try and ask your 'friends?'
Feb 17, 2014 | Samsung Galaxy Tab Tablet PC
Dont can enter to internet on my new tablet
To do internet you need:
1. browser
2. wireless internet connection with
2a. login access. (some places don't require this)
Look at the wifi signal indicator. If the signal is too weak the internet won't work.
(Or you may have it turned off. Go to Settings, find WiFi, and make sure it is on.)
Jan 04, 2014 | Supersonic SC-1007JB - 7 MID w Android OS
One side of my nextbook 7 se is non responcive
Sorry, but this will require a new screen and a new digitizer. Might be cheaper to just buy a new one and put this on ebay to sell as parts/non working.
Nov 05, 2013 | Nextbook Premium 7 Capacitive Touch...
Being a silver surfer i dont understand terminology
This requires you to do some "fancy foot work". You need to take several steps:
Step 1: Using a DVD Transfer Program on your PC, Import and convert the DVD to a format the Kindle can understand. I use: Amersoft DVD Ripper
Step 2: Once converted - transfer the converted DVD file to the Kindle
Step 3: Enjoy
Mar 31, 2013 | Amazon Kindle Fire HD
Does anyone know how to root the Coby Kryos 8 inch MID-8127 tablet?
You do not have to be a guinea pig. But I imagine technology has not changed that much since you had the 7 inch tablet and I would give it a try, since there probably is no other way to solve this.
Jun 14, 2017 | Coby Tablets & eReaders
My ibm t 22 or 23 not sure i can look but nyway it wont boot says windows 32 system file missing or corrupt i dont know how to get it to ny thing except a menu that says try last working config and a few...
You have a corrupt boot sector. Use your system/restore disc to get back in and boot then run CHKDSK/F to check for and try and fix any errors.
Hope that helps.
Jan 23, 2011 | IBM Tablets & eReaders
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
