I have a white line to the right side of the paper when printing black.
  • 19,396 Answers
This can be caused by a mechanic fault, or by a fault concerning the encoder strip, that is the part that determines the position of the ink carriage while printing.
The encoder strip is the plastic strip running aside the traction belt behind the ink carriage, and it can be cleaned using soft cotton and isopropyl alcohol.
If the problem is mechanical then the printer must be fixed by a technician.
Also ensure that there is no dirt or foreign object inside the printer, in the area behind the ink carriage.
Regards.
Posted on Jul 20, 2009
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
Thick black vertical line appears on the right hand side of the page
PLACE A PLAIN PIECE OF WHITE PAPER IN MACHINE AND TAKE A COPY. IF NO LINES ARE ON IT THEN THE LINES ARE COMING FROM THE MACHINE THAT IS SENDING TO YOU BUT IF U DO HAVE THE LINES THEN PRINT HEAD IS PROBABLY FAULTY OR DIRTY.
Sep 13, 2010 | Brother FAX-1020e Plain Paper Thermal...
DARK LINES/SHADES APPEARING ON BACK OF PRINTS
when the print-out shows lines or streaks on the back of the paper when printing single sidedly, this usually means that the fusing unit is dirty or broken. another possible broken part may be the photoconductor unit.
Apr 20, 2010 | Canon iR 2016i Black and White Copier
Brother HL-2040 series printer prints but puts a line through the words on the right side of there paper, its like it prints a white line on the right side of the paper erasing the words
Your printer needs cleaning. Clean with q tip and alcohol make sure printer is unplugged Do not drip alcohol inside the printer wait til it dries before restarting.
Jul 11, 2009 | Office Equipment & Supplies
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Black lines on the right side of every copy
depending on what the lines look like it could be the charge roller or transfer roller.
A defect on the charge roll appears as black areas on the front of the test page, and as light gray areas on the test page.
A defect on the PC drum of the toner cartridge appears as white areas on a dark, full–coverage test print and as black areas on the "text only" test page.
I have also seen a line with a 'ridge' on the paper. This will appear almost like an embossed line. This was caused by the fuser roller being scored by debris.
Jan 12, 2009 | Dell 1710 Laser Printer
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
Quality of printing
For the black line check the toner cartridge roller (usually covered by a movable flap) to see if there is a black line on it. If not, then check the transfer belt (looks similar to a conveyor belt) for a line (probably not black in color, possibly white or grayish). If either of these parts have a line your best option is to replace that part. You could try cleaning VERY gently with a dry lint-free cloth but this may only clear up a little of the issue.
As for the fold, try running a paper path test, usually found under test, information, or diagnostic menu option on the printer itself. Try to find anything in the paper path that may catch the paper and cause it to fold.
Hope this helps!
Nov 27, 2007 | HP Color LaserJet 2600n Printer
Black line down right side of paper
On the ADF check the twink mark on glass scanning mirror
Oct 15, 2007 | HP LaserJet 3055 All-In-One Printer
20 people viewed this question
k24674
