Generally I believe that the sub tension regulates the length of the tail left after the machine cuts. Rather than adjust the sub tension, I would 'slightly' tighten the screw on the bobbin case and see if that solves the problem. If you were not having the problem before, there may be lint or tiny piece of fuzz under the spring on the bobbin case or a piece of thread hung up in your upper tension. Good Luck!
