Question about LG Televison & Video
LG 55 inch tv vertical lines, ive replaced the t-con board and cleaned the ribbons with use of an eraser and the lines continue, what is next thing to check?
The TV is about 15 months old so just outside of warranty and ive pulled it appart and cleaned the ribbons attaching to the tcon board with use of a new pencil eraser and reattached and the lines still continue, The lines seem to follow the color that appears on the tv.
    Top Expert:
  • LG Master
  • 73,619 Answers
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Posted on Dec 03, 2016
LG 55LM4600-UC LED TV I have was squirted with a squirt gun. Would replacing the t-con board fix this tv? Please read further details.
when water shorts out something it overloads a lot of other components so the best advice is to take it in for a proper diagnosis.
you just replace a board but another board is damaged it might just blow the board you replaced and that would prove nothing
Jan 09, 2017 | LG Televison & Video
LG vertical line
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 15, 2016 | LG 47LV5500 47 Class LED TV with SmartTV,...
I have an LG 2009 60ps60 plasma TV with multi color vertical lines on the left side of screen. Is there a board I can change to correct this problem??
1. Identify the TCON board.
2. Reset the Left side ribbon cables on the T-CON board
3. Replace CON board if you find a spare
Apr 13, 2016 | LG Televison & Video
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
Where do the two ribbon cables that come off the main board and run down to center of the frame on my LG 55 inch tv model # 55lm7600-ua I only see a place to attach one of the cables.
I changed the t-con and ribbons on the 55" model precedeing this one and both ribbons terminated at the t-con board, check that it is not hidden beneath a large aluminum square metal plate
Dec 02, 2015 | LG Televison & Video
I have vertical lines showing up , I opened up the tv and I wiggled the connection ribben between the t-con and main board and the lines seems to be better but not 100% fixed what you suggest me to do?
Try one more thing, remove all the connections to t-con board the and clean the terminal of the wire. you can use an eraser for that. with the eraser rub the contacts on the end of the wires. do not use eraser on the sockets which is on the boards.you have clean only the wire. after cleaning connect it back and check. if then also the is lines there is line then you need a new t con board. There is also a chance of panel fault but it can only confirmed by replacing the t con board.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience
http://electro-medical.blogspot.com/
Nov 17, 2015 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a single purple/pink line running vertically on my 40 inch samsung lcd tv 720p it goes away usually after awhile but comes back ive tried just about everything i know to make it go away permantly...
The tv board that call the T-CON decodering board is the caused.This board sit at the middle of the bottom of the LCD screen panel.Check the cableling connections or the T-CON decodering board is dying.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
Mar 29, 2011 | Televison & Video
A black line running verticall down the middle of
There is no invertor board on a plasma tv. The fault is the X address buffer board. This is located on the bottom of the screen and runs horizontally the whole width of the screen. If you remove the heatsink plate that covers the x address boards and you need to look at the screen ribbon at the same position as where the bar is (in the middle).Vary gently lift the Xbuffer ribbon lock and gently take out the ribbon.Clean the contacts very carefully with a fibre pen or an electrical cleaning fluid.Insert ribbon back and heatsink and check.Here is a picture of the board and ribbon
a 1 inch bar is associates with 1 ribbon fault. So if the bar was 3 inches in from the left of the screen, the faulty ribbon will be 3 inches in from the right working from behind the TV. If cleaning dont cure the fault, then the Buffer IC will be blown and order a new centre buffer board (you can buy off Ebay)
Feb 17, 2010 | LG 42PG20 42 in. Plasma HDTV
Televison & Video Logo
Computer Repairing
Computer Repairing
