Question about Cameras
Not functioning About 2 years old. Never used before. Put new batteries. But does not turn on!
  • Cameras Master
  • 5,412 Answers
What exactly is 'it' ? If a camera, make, model, lens etc would be helpful
Posted on Dec 03, 2016
I stored my honda vfr 800 for two years. When I tried to start it, it would not start. It used to work alright before storage. It is quite new. What might be wrong with it?
Have you charges the battery? Is it turning over at normal rate. Have you put fresh fuel in it. 2 year old fuel will present a problem.
Mine would die and it turned out that the regulator / rectifier was shot also it buggered the alternator so need all new bits.
Common misconception is that it's just a faulty battery but can be more serious. Get a sparky to check it out.
Feb 28, 2011 | 1998 Honda VFR 800
I have a Acer laptop and I just bought a new charger for it because I thought that the old had stopped working but the new one isnt working either. The computer says that it is plugged in but not...
Hello:
Maybe your battery is ruined. Batterries tend to lose their capacity after a year or two. It depends on its use and care. If your battery is too old, for sure, you need to replace it.
I hope this helps. Thanks.
Jan 31, 2011 | Computers & Internet
I have a TI-83 graphing calculator and it keeps reporting 'Low Battery'. We replaced the 4 AAA batteries with a fresh set and got the same message. The calculator is less than 2 yrs old. Do I need to...
There can be two causes to this problem. One, the batteries that you put in may be expired. Some batteries have expiration dates on them (i.e. Duracell). If the year on it has expired or is coming near to expiring, you may have to put newer batteries in there that are longer lasting in years. Even if the expiration year is far-off, you still may need to put newer batteries in the bay. Two, your hypothesis of changing the lithium battery are correct. I read in the manual that you should change it every 3 or 4 years. The lithium battery is the back-up battery and it is like a memory card for you calculator. Whenever you put a new fresh set of batteries in the bay, the lithium battery saves your information while you are inserting the batteries in the bay. When you turn on the calculator again, it saves your functions that you've had in there. Hope this clears up your confusion! Reply back if you are still seeing the message.
Jan 15, 2011 | Texas Instruments TI-83 Plus Calculator
I have a motorola AXU4100 radio. Every time I use it to talk it shuts off.
It is likely your battery pack is not fully charged or it is in need of a new battery. It takes more energy to transmit than to receive. Pressing the PTT uses quite a bit of power and will easily shut down a radio needing a battery (or charge). If you feel you battery is still good (less than 2 years old), you might check your charger to see if it is functioning correctly.
Best regards.
Jun 11, 2010 | Motorola AXU4100 (10 Channels) 2-Way Radio
Battery or Charger bad?
If you persistently leave the batteries discharged, it is unlikely that they will be able to hold a full charge. You should re-charge your batteries at least once a month, even if unused. Put it on your calendar. BTW 2 years old is hardly 'brand new'.
May 26, 2017 | Sharp VL-E630U Camcorder
My K800i battery dies very quick
Dear Friend,
                 U are saying that u have bought this mobile 2 yrs back so check wither ur battery has been expired and change it.Otherwise switch off ur mobile and put it in charge and check it out the normal standby for any mobile is 2 to 3 hrs.Kindly check it and revert back
Regards,
Aysaam
May 06, 2009 | Sony Ericsson K800i Cellular Phone
Suddenly turning off
Your battery is dead. You'll need to return it to Garmin for repairs. Mine did the exact same thing. Functioned fine in the cradle - showed full battery - but shut off immediately upon removal. They know about the problem and shipped me a new unit for free.
Nov 28, 2007 | Garmin Edge 305HR GPS Receiver
Motor does not start.
electric shaver hq5812 charges,light is on but does not cut efficiently
Aug 25, 2007 | Philips Philishave HQ5812 Electric Shaver
ERROR C-2
Try replacing the battery - if it too is five years old, it's probably worn out.
Jun 24, 2017 | Konica Revio KD-300Z Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
